Question about Refrigerators
Maytag MFI 2269 leaks water from freezer comp. gasket
Water intermittently leaks from the gasket of the freezer compartment door (bottom freezer compartment. Ice also builds up on the floor of the freezer compartment. I can see no drain holes in the freezer compartment. Seems like it may be a defrost related issue, but what.
3 Suggested Answers
  • 1073 Answers
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
Maytag317
  • 1136 Answers
SOURCE: Ice build up in freezer compartment until water flows onto floor.
Hi, Is this a wwhirlpool brand fridge?
The drain is plugged in the freezer section. If I could get model #,I can get you ezact instructions.
If the floor panel in the freezer has screws holding it in, remove the fllor panel. Now you will need to remove the rear panel inside the freezer as well.
If this is a Whirlpool brand, there is an after market drain heat strip that you will need to add to the defrost heater.
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 30, 2009
Maytag fridge side by side freezer door leaks water
If the insulation in the door has blown, it cannot be replaced. If there is a dispenser in the door, look at all the plastic parts for any splits or leaks. To test if it is the dispenser, turn off the water supply for a few days. If the water stops collecting in the door it's a good sign.
Apr 22, 2014 | Maytag MZD2766GES Side by Side...
MAYTAG DOUBLE DOOR REFRIG
THE PROBLEM IS WITH THE AUTO DEFROST (IF THE FEATURE IS AVAILABLE) OR ELSE YOU HAVE TO MANUALLY DEFROST IT REGULARLY
Sep 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
How to access drain hole for maytag model mf12269vem3
please check your ice maker to make sure it is not jammed up water can leak into fridge
Nov 01, 2013 | Freezers
Water on floor - french door refrigerator with freezer below
Yes the bottom compartment does have a drain opening but to see it you will need to remove the rear panel covering the evaporator inside the back wall of the freezer compartment. See item location number 11 on page 3 of the parts list. That will need to be removed so you can reach the drain inside the freezer compartment. The fresh food section also has a drain. Here is a=> AFF2534FEB4 Parts List and AFF2534FEB4 User Manual I am here to answer any questions you may have, Thanks Sea Breeze
Leaking Refrigerators
Jul 23, 2013 | Whirlpool Amana Refrigerator Water Filter...
Maytag mff2258vew2 french door bottom freezer leaks
The cabinet heater in freezer is may not be working and causing condensation on the walls of the freezer. Have it checked by a service man.. also make sure the refrigerator is level. and it is not over packed with food. Newer models must have a certain amount of space for the air to circulate.
Oct 04, 2017 | Maytag Refrigerators
Maytag freezer water leak
Fridge has a design issue. Duckbill drain valve clogs. They have a new ptrap drain replacement but you have to ask for it, as customer service will deny a problem exists. Here is the service bulletin which was supposed to be for internal use only! https://docs.google.com/file/d/0BzIiBNwRIV4NNWJNNmx0andROGs/edit
Jan 15, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Water filter compartment leaking
If you have already replaced the filter and you can see the housing is still leaking, You have to replace the housing and water tank as an assembly (12956202). Make sure you verify it's the filter housing leaking, and not a fitting at the water valve which is right behind the plastic cover around and below the filter housing.
Apr 28, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag Freezer
sounds like you need a new door gasket
Aug 15, 2007 | Magic Chef 11.8 cu. ft. / 334 liter...
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
