Question about Klimaire Heating & Cooling
System won't run
I have an '09 toyota camry and the navigation system won't work, tried to hard start the system by disconnecting the battery but it still won't work. Does anyone know how to fix this?
I think you will need to access the Nav System with a professional
scanner or scan tool & then use manufacture trouble charts, to even know what the system is supposed to do, & how to diagnose it
Hopefully a repair shop, if they want the job,otherwise blow out
your wallet at a dealer
Mar 27, 2013 | 2009 Toyota Camry
P0411 secondary air injection incorrect flow on porsche boxster 1998
You have a code to go by & you know codes are
used to diagnose the systems with the fault
It won't go away by it's self & running fine to you
is no guarantee that it will for long or not cause damage
Get it repaired
You can use the internet to research codes & their causes
Nov 13, 2012 | 1998 Porsche Boxster
1990 Buick LaSabre, limited V-6 3.8 overheating, replaced fan, & thermostat & cooling temp sensor. runs rich and fan won't come on?
on that motor they are prone to blowen head gaskets you need to do pressure check of the cooling system
Jul 26, 2012 | 2000 Buick LeSabre
Should the engine be running when adding coolant to my 2003 cadillac cts
If you just drained it & are refilling,then yes,the engine
should run & warm up until the thermostat opens & you
keep adding.
If it isn't hot & circulating thru the entire system, you won't
get it close to full with the rad cap off
Jun 10, 2012 | 2003 Cadillac CTS
The 'theft system' light does not turn off with the key in the run position on my 1999 chevy cavalier. car won't start, it won't even crank over. the battery and the starter are brand
try locking your car with the key and unlocking it with the key, leave it for 30 second or so between the locking and unlocking , the car thinks some one has tampered with it
Mar 18, 2012 | 1998 Chevrolet Cavalier
How do I reset the security theft on a 1990 pontiac bonneville
This link will help you out. Has alot of information on the system.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Dec 22, 2011 | Cadillac DeVille Cars & Trucks
The CD won't spin
there are lens cleaner cds with liquid cleaner. get that kit & run this cd with cleaner on its brushes. if still not working unplug the system & open the cover & see there is lens on cd drive unit. clean upper surface gently with soft cloth. if not working then replace the cd drive mechanism.
Aug 25, 2011 | Bose & Wave& Music System
I'm having trouble with the evap system and was wanting to know where to start the car is running fine But the light is always on and I was going to check the fuel tank
You really need to study & understand EVAP Systems
You can do that by going to & using YOU TUBE VIDEO
Then you need 3 things
You should have a factory service manual for your vehicle,
to see what the system contains
That is an expensive, but in my world necessary thing to have,
The Helm.Com manuals -- not some parts store or book store generic
useless book
Then a professional scan tool or scan tool software for your laptop
& an EVAP Smoke Machine,are the other two things
You won't have any of the three,so, if you have a code & only
if you can narrow it down to a solenoid that commonly fails I
would say spend the money & take a change on gettin it right
I won't tell anyone that for another six months because codes do not
tell you what is wrong 95% of the time. Not why we get codes
Codes are to tell you a System,only a system has a malfuntion
Then the code number sort of points you in some direction
For the uneducated OBD2 folks & that includes some professional
repair shops,dealers and the like they are lost,from there,without
trouble charts,vehicle data & as I said the correct test equipment
& last the ability to know how to use it. Now that is a subject for
another day you don't even want to know about.
Aug 04, 2011 | 2008 Chevrolet Uplander
I have Windows Vista and Internet Explorer 9. Skype was fine and now won't even open. A small box comes up saying 'Skype has stopped working'. I have checked for updates. Help please!
Try this, (Vista & Win 7)
1. Close Skype
2. Exit the Skype icon from the system tray(at the bottom right of the screen)
3. Ensure that "Show hidden files and folders" is switch is check & enabled
(i). Start-> type "Run" & press Enter
(ii). Type "control folders" & click OK
(iii). Select the View tab & ensure the relevant entry is enabled
4. Locate the shared.xml file
(i). Start-> type "Run" & Press Enter
(ii). Type "%appdata%\skype" & click OK
(iii). Delete the "shared.xml file" - (without quotes)
Restart Skype, a new shared.xml file will be created.
Hope it will help.
Jun 02, 2011 | Computers & Internet
My woofer is 18' 600w rms power. so what is the
Basically you cannot break you woofer with too powerful amp, but you can break it using too weak amp. This is because if you don't have enough watts going to you woofer the cones movement isn't controlled properly. I'm usually using +20% to the woofers RMS and peak power. This will also make the amp last longer because you won't use it at it's peak performance all the time. If possible use manufacturer whose prising policy matches your woofers manufacturers, that way you won't end up with "2000w peak power" cheap amp with real output of 30w. and in the other end cheap woofer won't handle expensive amp with real 600w rms so well, you need to find a midlle way here. Hard to say without knowing the make and model of the woofer.
This is a taste question for some people, and I haven't build a system to match so powerful woofer ever in my life. But I'm pretty sure you won't go wrong with this one.
May 20, 2011 | Audio Players & Recorders
Heating & Cooling Logo
Top Klimaire Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Klimaire Heating and Cooling Expert? Answer questions, earn points and help others
