Question about Klimaire Heating & Cooling
P5 error code - Klimaire Heating & Cooling
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
Shows error P5
Does owner's manual have list of error codes? If not; go online with company. If it's a download they need to correct it.
Jun 06, 2014 | bigfishgames.com
P5 error code floorstanding AC Changhong
cara menangani erorr P5 pada ac floor standing changhong????trims infonya
Jan 09, 2014 | Heating & Cooling
Error code p5 on Mitsubishi ducted mini split
Use Bing or Google and search for the error code and your brand of a/c unit...there are answers and sometimes videos to every problem out there if you search.
May 18, 2013 | Heating & Cooling
Our machine is stopping during the wash cycle and giving the error code f51..???
Hi
F51 error is a rotor position sensor error. This error appears when rotor position sensor is faulty or due to a faulty control board. Look underneath the tub and check the motor, check for RPS on the right side (follow the brown wires) and under the motors rotor disk. Use allen wrench to remove the rotor and then the four bolts holding the motor stator to the tub can be removed. You would need to check the motor by running Motor test. Please follow the steps ---
1. Unplug washer or disconnect power.
2. Check to see if basket will turn freely.
3. If basket turns freely, go to step 4. If basket does not turn freely, determine what is causing the mechanical
friction or lock up.
4. Remove the console to access the machine/ motor control assembly.
5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6.
If visual checks fail, reconnect P5 and P10 and repeat step 1.
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range.
If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to next step.
7. Tilt machine forward to access the bottom of the machine and the drive motor area. See Figure 1 on page 6-13. Remove the motor bolt, then the motor cover to access the motor connections.
8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9.
If visual check fails, reconnect the electrical connections, reassemble stator and motor cover and repeat step 1.
9. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector. See Figures 2 and 4, pages 6-13 and 6-16. If there is continuity, go to step 11. If there is no continuity, replace the lower machine harness.
10. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector. If there is continuity, replace the drive motor. If there is no continuity, replace the lower machine harness.
11. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test in step 1 to verify repair.
12. If the Diagnostics motor test in step 1 failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Motor Diagnostics in step 1 to verify repair.
Hope this helps... Please post back if you need more information.
Daniel
Nov 16, 2010 | Kenmore Oasis HE 27082 Top Load Washer
We are getting a F51 code on our washer. What does that mean?
Hi
Nov 16, 2010 | Maytag Bravos MTW6600T Top Load Washer
I'm getting a F 51 code during the washing cycle and does not clear.
Hi
F51 error is a rotor position sensor error. This is a hardware error either due to a faulty rotor position sensor or due to a faulty control board. Motor is located directly underneath the tub. The RPS board is mounted on the right side (follow the brown wires) and under the motors rotor disk. An Allen wrench is used to remove the rotor and then the four bolts holding the motor stator to the tub can be removed. You would need to check the motor by running Motor test. Please follow the steps from the service manual given below---
Please post back if you need more details. Hope this helps...
Daniel
Aug 30, 2010 | Whirlpool Washing Machines
Z4MPLUS P3/P5 ERROR I found some problem in Zebra Z4m plus printer like error p3/p5.please give me solution for that
The display shows P3/P5 ERROR? You can try to load firmware, download the file from www.zebra.com press the keys - and +, turn the printer and you see FIRMWARE DOWNLOAD in screen, download the file through the parallel port.
Roberto Martinez
Jun 01, 2009 | Zebra Z4Mplus Label Printer
Washer stops washing and gives a p5 trouble code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2009 | Kenmore Elite 45986 Front Load Washer
Heating & Cooling Logo
55 people viewed this question
Top Klimaire Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Klimaire Heating and Cooling Expert? Answer questions, earn points and help others
