Question about Water Heaters
Damper stuck power damper on Whirlpool gas water heater sticks closed and wont let ignitor ignite.opens with a little helpand is fine until its time for it to light again can i fix this one or do i need to replace whole damper unit?thanks,mallen
  • Water Heaters Master
  • 5,245 Answers
Unknown if this is new installation or older installation that stopped working, so we're guessing
Damper is sold separately. Refer to part numbers in product manual.
http://waterheatertimer.org/pdf/Whirlpool-flue-damper-manual.pdf
http://waterheatertimer.org/Review-Whirlpool-Flue-damper-gas-Water-Heater.html
Call whirlpool Warranty and Service department 1-877-817-6750/ 12 years parts coverage for single-family residential installation when installed by code and information shown in product manual, and maintained as showing in product manual.
Clean air intake located on bottom of unit as shown page 24-25 product manual... the problem might be not enough incoming air supply.
Review manual for correct venting.
Check outlet for 80% rated voltage and for correct polarity, and for ground continuity with manifold tube located under gas control valve.
Troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Call local service technician. Call installer.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on May 06, 2013
SOURCE: Rheem water heater with powerglow ignition wont re-light
I have fixed mine. The problem part is the Ignition Control module. It is made by Robert Shaw part # SP10758. I paid $93 plus shipping.
Works great now. A repairman wanted to sell me a gas valve for $488.
Watch out for these people.....
Posted on Jan 10, 2009
  • 659 Answers
SOURCE: How to install a new temp sensor Whirlpool electric water heater
The instructions for installing the sensor will probably included with the new part. Also, when you receive the part and actually see it, you will probably know where it will go. Sometimes, things like this happen even with new units. I have had bad thermocouples on brand new units right from the factory. It happens and unfortunately it happens to us sometimes. Good luck and if you get the part and still have trouble, contact them again. If you would have bought a GE (Rheem) unit, they would have sent a tech out to your house at no cost. I'm not a fan of Whirlpool water heaters.
Posted on Apr 02, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: pilot light won't stay lit after release of gas valve.tried few t
Most likely it's time to replace the thermocouple, the safety device that makes sure the pilot is lit. New thermocouples are cheap and you can find them at most hardware stores and the big-box places (Home Depot, etc.)
Here is a site with basic information to get you going.
Posted on Apr 08, 2009
SOURCE: Its a 6 year old gas water heater. It was working
Replace the thermocoupler.
Easy fix.
Posted on Jun 23, 2009
  • 54 Answers
SOURCE: aquastar on demand gas water heater wont light
Replace the flame sensor
Posted on Sep 14, 2009
XG40T12HN38U0 rheem gas water heater manual
That is a residential power-damper water heater.
Rheem has use-and-care guides with parts list, but does not post service manuals.
http://waterheatertimer.org/pdf/Power-damper-troubleshoot-parts-manual.pdf
Following links will help with DIY repair.
http://hometips.me/Mar/Whirlpool-flue-damper-manual.pdf
http://hometips.me/Mar/AO-Smith-high-efficiency-flue-damper-manual.pdf
Parts are ordered from Rheem
Jan 17, 2017 | Rheem Water Heaters
MAIN GAS VALVE WILL NOT ALWAYS OPEN
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Rheem does not post service manuals for their products, and tells folks to call service technician
Gene
Aug 17, 2014 | Rheem RUUD G100-200 Comm Water...
Wiring diagram on whirlpool gas water heater
Whirlpool is AO Smith tank-type heater.
Year, model, type of heater not known.
So add a comment and then expert can look up the manual.
You probably have power vent, or dampered water heater, otherwise the only wiring would be for thermopile, thermal reset, and igniter.
Power vent, or dampered, of flow control water heaters plug into outlet, and wires from gas control run to the various components.
Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/Review-AO-Smith-Effex-water-heater.html
Don't forget to add comment and include model number that shows on label located side of tank.
Sep 21, 2012 | Whirlpool 6th Sense 40-Gallon 6-Year Tall...
We have a 10 year old Rheem PVW50 Power Vented water heater that works on gas. The last couple of days it has been giving out problems. It will not maintain hot water in the tank. I restarted it and...
The igniter is glowing, but no gas ignites?
So either the gas is entering combustion chamber and not lighting because igniter is positioned incorrectly -or- no gas is entering combustion chamber because air in gas line or bad gas control valve thermostat or gas line is clogged.
When you 'restart' the water heater, somehow you are getting gas to the burner and it is igniting.
I'm not sure what the flame switch is. If the ECO was cut out, the gas control valve would not send power to the igniter and there would be no gas available for 'restart.'
I would adjust location of igniter, check if gas is entering combustion chamber, clean the gas line to the burner, and bleed gas line for air, but another suspect could be the gas control valve thermostat.
Identifying numbers are usually on side of gas valve.
Open following link to help identify gas valve:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Jul 02, 2011 | Rheem Water Heaters
The electronic ignition on a gas water heater will not heat up and glow red to ignite the gas to heat the water atwood r/v water heater
You won't see any red glow until the burner ignites and burns for a while. Its only an ignitor and flame sensor, not a glow plug style.The ignitor has to provide spark for gas to ignite, then it also senses the flame and keeps gas flow coming. What exactly is happening when you turn it to on?
Jul 18, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Rheem/GE power vent water heater, pilot lites, but not the main
I would check to see if the switch on the blower pressure sensor is closing...When T-stat calls for flame, the circuit starts the blower, then the blower pressure sensor switch closes to allow the main gas valve to be powered.
Jul 08, 2009 | Water Heaters
Nov 06, 2008 | Water Heaters
Water Heaters Logo
142 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
