Question about Car Audio & Video
I was given a subwoofer and box but do not know
I was given a subwoofer and box but do not know where to go from here in terms of hooking it up in my car. It is a Rockford fosgate punch p112s4.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
First youll need an amp. Depending on what size the sub is a 500 watt rms amp can hold up to about a 300 watt kicker. If your looking for something bigger u can get a 1000 watt amp and hook up two 300 watt kickers. To hook up the amp youll need a car amp power cable, power control cable, speaker wire, amd a car amp ground wire. They usually sell kits that run aboyt 40 bucks. The power cable goes to the batter as well as the ground cable. The power control cable goes to the back of the head unit. (You will kost likely need a more modern headunit if urs is stock). Once this is done put the sub in the box (i recomend super glue because metal nails take away from the bass). Put the speaker wire to the speaker positive on left negative on right. Same with the amp. And now ur bumpin ;)
Posted on May 10, 2013
5 Suggested Answers
SOURCE: Rockford Fosgate Amp Repair Guild
I would love to get a copy of that repair guide you made. Could you please
Posted on Sep 02, 2007
  • 4 Answers
SOURCE: How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Posted on Dec 03, 2008
blueextc3221
  • 15935 Answers
SOURCE: not a problem just a question
  • 100 watts RMS x 2 at 4 ohms
  • 200 watts RMS x 2 at 2 ohms
  • 400 watts RMS x 1 at 4 ohms in bridged mode
  • stereo or bridged mono output
  • 4-ohm stable in bridged mode
  • Tri-Way capable
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
  • wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
  • MOSFET power supply and output devices
  • MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
  • TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
  • Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
  • NOMAD — advanced protection circuitry for "intelligent" shutdown protection
  • speaker- and preamp-level inputs
  • 11-1/8"W x 2-3/8"H x 9-7/8"D
  • Wire your sub in bridged mode (4 ohm mono)
    + to + on amplifier
    - to - on amplifier
    (using bridging terminals)
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Posted on Apr 25, 2009
    • 182 Answers
    SOURCE: Rockford Fosgate Punch 800 A2 shorting out.
    replace the inputs on ur amp
    Posted on Jun 29, 2009
    Box specs for 1 fosgate hx2 12 for a jeep wrangler
    go to the rockford fosgate site they will have info you need.
    Oct 07, 2012 | Rockford Fosgate Punch HX2 RFD1212 Car...
    I have a old 2001 rockford fosgate 2 channel p5002 model in great condition just need to know how many watts is it and which subwoofers are compatible to this amp? thanks
    Your amp is rated at 500 watts. Here is the break down of your wattage.
    125x2 at 4 ohms
    250x2 at 2 ohms
    500x1 at bridged 4 ohms
    When hooking up the amp make sure to use 4 gauge power and ground wire.
    Jan 07, 2011 | Rockford Fosgate Punch P5002 Car Audio...
    I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
    Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
    Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
    How do you take the dustcap off a p210d2 rockford fosgate subwoofer
    You can do this, and I'll tell you how, but I'd like to know why you'd want to do such a thing - you won't get as much bass out of the speaker, due to the voicecoil vent that is present on most subwoofers. This vent would make the box "leaky" and the bass would be seriously impaired.
    Looking at the speaker, it doesn't look easy at all.
    My usual method is to use a scalpel, and cut (carefully!!) around the dustcap, until it is removed. Sometimes, it's easier to make a starting hole with a scalpel, then use scissors.
    Jan 10, 2010 | Rockford Fosgate Punch Stage 2 P210D2...
    I HAVE A ROCKFORD FOSGATE PUNCH 12" UNGLUED AROUND EDGE THE THICK PAPER RING IS SORD OF WORN OFF SPEAKER IS IN WORKING CONDITION, WHAT WILL IT COST TO REGLUE?
    This can't be glued. common problem.
    You will have to find a speaker repairer who can replace the foam surround or just buy a new sub.
    Jul 25, 2008 | Rockford Fosgate Punch Stage P110 S4 Car...
    Sub hook ups
    There's a lot more factors involved than that.
    • Power capability of the subs
    • Type/size of the sub box
    • Allotted space in the vehicle for the sub box
    • Voice coil impedance of the subs versus the capability of the amp
    • Etc.
    Jun 19, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
    Car Audio & Video Logo
    73 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
