Question about Canon PIXMA MP830 All-In-One InkJet Printer
Scanner seems stuck and causes error
The printer got an error code initially (5010, I THINK), when I tried receiving a fax. So I turned it off, and back on and I constantly get an error saying 'Release the scanner lock switch and turn the power off and back on'. I never touched the scanner lock switch and it is in the unlocked position. The scanner head was moved all the way to the right for a while, then one of the times it moved back to it's home position to the left. But, I still get the error. I've tried moving the scanner lock switch to the locked position, then back to unlock and I still get the same error. The printer is useless while in this error mode. Any thoughts?
  • 2 more comments
  • rreynard Aug 11, 2007
    Unfortunately, the problem occurs whether or not the computer is connected. It is an error that happens right during power-on and self-check of the printer itself. And, once the printer is in this state, the only button that works is the power button.
    By the way, the initial error code that I saw the first time the printer 'got stuck' never appeared again. I only get the error to unlock the scan head.
    I was hoping that opening it up would be the last resort. I looked at doing this originally and didn't see any easy way of getting access to the electronics inside the scanner module. I'm an EE, so I'm comfortable working on the inside, but, as I said, I was hoping it would be a last resort. I'm more worried about breaking a plastic clip when trying to get inside and the scanner never really going back together tightly.
    Is there any way to force a factory hard reset of the printer through the system mode (referenced to when looking how to force the printer to print on CD/DVD's and changing to EUR mode), or through a button-hold combination?
  • rreynard Aug 13, 2007
    Turns out that the machine was still in warrantee (2 days over, but Canon said that they would honor it). So, I took it to an authorized service center. I was told that they see quite a few of these scanners failing (more than any other part of the machine). Said that they were going to replace the scanning unit.
    Thanks for taking the time to read my posts and giving tips! That is what makes the web so great.
  • Anonymous Mar 14, 2014
    Hi, I have a B200 error and I am attempting to isolate whether the issue is the logic board/ printhead or both for an MX850.
    The following parameters apply when switching the printer on at the top panel on/off switch:
    (i) B200 error appears;
    (ii) If I open the scanner bed with the power off and physically remove the printhead and switch printer on with the cradle lock handle down and lower the scanner bed, I do not receive the B200 error.
    Question: Does this establish the fault lies with the printhead or could it still be the logic board?
    That is, with the printhead removed, if the logic board is faulty will still give a B200 error?
    A related question is what is the standard technical procedure for isolating the printhead as the faulty mechanism?
    With thanks, Tim
  • 883 Answers
You can always try to install the printer on a friend's pc as a test of the printer...do you have the install cd? if not try canon's site to download it.
Posted on Aug 10, 2007
  • Marty marty Aug 11, 2007
    open the scanner. locate the scanner lock switch. now locate the wires attached to the scanner lock switch. touch these wires together, creating a switching effect. now turn on scanner.
  • Marty marty Aug 12, 2007
    you can always try to find the button-hold combination by pressing 3 buttons simultaneously that are located far from each other...I know that works for SHARP copiers. Try all combinations....it can't hurt it now.
What are the error codes on my printer,5010 & 6100?
The 5010 error indicates a scanner error. The scanner unit cannot detect the home position, or the scanner unit warming-up is not done properly at power-on. On the LCD, "Scanner is not operating correctly." is displayed.
The 6100 error indicates a logic board error. The check sum value is incorrect in the ROM check at hard-power-on.
Fixing these errors is more expensive than replacing the printer. Sorry.
Fixing F
Feb 05, 2015 | Canon PIXMA MP830 All-In-One InkJet...
Scanning error on mp 830 - code 5010. What is
Hi, did some research for you and this is what I found:
Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
In response to your query, please be advised that the error code "5010" indicates there is a scanner error and the printer will require service.
If the printer was bought recently you can contact the dealer and check the replacement program.
If you are outside the replacement policy, please find below a list of authorized service centers for your device and some packaging instructions:
The following office peripheral products: A3 and portable printers which are still under warranty, Laser Beam Printers, PC/FC Copiers, Multifunctional Devices and Fax machines benefit from on-site service.
On-site service can be arranged by dialing 0870 400 2080, or by contacting
Canon Ireland Ltd (Fax, Multifunctional and PCFC Copiers)
Arena Road
Sandyford Industrial Estate
Dublin 18
Tel: 01 205 2400
Fax: 01 295 8141
Web: http://www.canon.ie
Sep 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error 5010
On a Canon machine 5010 is a scanner error, stuck, light burned out, etc.
Sep 09, 2009 | Office Equipment & Supplies
I got an error message 5010 when I was trying to fax, but can't find in the manual I have what 5010 is and how to resolve it. Thanks you!
5010 is a scanner error that you can get if the scanner lock is locked, and also if you put a heavy book on the glass and stop the scanner. Canon only sells the scan assembly as a whole unit around $150.00
Aug 20, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Mp460 problem
The 5010 error is a scanner error, the lamp is dead, or the scan assembly is stuck. There are no parts, only whole scanner assembly replacement. You get a one year warranty with Canon, after that it could be a $200.00 repair.
Jul 02, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Printer will not print, error code 5010 is
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 5010 for cannon mp460 printer
Hello, The error 5010 refers to a scanner issue, make sure all the connectors are seated and all flat cables running to the scanner unit are firmly seated, turn printer back on and the error should clear. I hope this helps.
Nov 10, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon mp-830 error code 5010
That code is a scanner error. The scanner unit can not detect the home position or the scanner unit warming up is not done properly at power on. Most of the time the Scanner unit needs to be replaced.
Nov 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Startup
I've heard that that error code means it's pretty much bricked out of the box (I think to scanner failure). Return it if possible.
Jan 20, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Error code 5010
I got the error code 5010 today (scanner lock switch). I called Canon. The printer's electrical circuitry (brain) needs to be refreshed. This is similar to wireless routers and other devices. They directed me as follows: 1. power OFF the printer 2. Unplug the printer's power cord from the electrical source. 3. Wait AT LEAST 1 minute - no less than 1 minute. 4. After 1 minute, plug-in the printer to the electrical source. Turn on the printer - wait for it to warm up as usual and it should be ok. Mine worked perfectly after the above steps. - Hope this helps.
Jan 12, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
1,301 people viewed this question
old marine
old marine
