Question about Garden
I have a model 917270810 19.5 hp 6 speed mower. I am not able to lower the mower so blades engage.Worked great when I put it away last fall.Art
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 81 Answers
SOURCE: Mower wants to stall when blades are engaged
Usually when the motor stalls when blades are engaged on any mower it is the carb that needs cleaned and rebuilt. The motor isn't getting enough gas to handle the load.
Posted on Jun 23, 2009
wadembly
  • 475 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 130 Answers
SOURCE: change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Posted on Jul 22, 2009
  • 257 Answers
SOURCE: Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Posted on Aug 15, 2009
When i engage blade it dies like belt is to tight.worked fine last time used
The belt may not be the problem. When you engage the blade, the engine is doing more, thus needing more gas, your problem is the carburetor.
Oct 04, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
When i push the arm up to engage the blades, they don't engage
CHECK BELT, WITH MOWER OFF ! . HAVE SOMEONE MOVE HANDLE UP-DOWN AS YOU WATCH THE BELT, IT SHOULD FEEL TIGHT WHEN DECK IS LOWERED .. JAY
Sep 10, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My tractor keeps shutting off when i engage the mower blades
It would depend on what model, but could either be a deck drive problem or safety switch. With tractor off, I'd check the blades for free movement with no binding. If this is ok, then I would suspect the seat switch. The mower will not run with the deck engaged, and no operator present. It could be the seat switch is not making, so when you engage the deck it kills the motor. Test switch
Aug 27, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Mower cuts off when blade is engaged.
Not familiar with this model, but a thought, check for a kill switch.
Apr 27, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan 38" 15.5 hp lawn mower cuts off when blades engaged.
you have a bad blad saftey swich that all it is replace that and youll be good to go
Oct 01, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Engage blades makes noises
Sounds like the bearings are going out in one or both of your blade spindles. With the belt off,(and engine, of course) engage the lever on the dash. That will release the blade brake so the blades will be free to turn. Spin each one by hand. It will be easy to tell if the bearings are bad.
Jun 06, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Craftsman 20HP , can't stop freewheeling,
Sounds like your problem is the key in your rear wheel is missing or sheared, you have to remove the wheel @ tire assembly ,pull rubber cap off then clip to remove if one of the keys is sheared or gone it will go into gear and the brake will work ,but they will only stop the shaft without the key it will not move or brake becuase its not attached if you know what I mean.
May 11, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Toro timecutter spits and sputters when blades are engaged
Did you drain the fuel before you put it away? If not then you should drain the fuel and clean the carb. Gas when in lawn mowers and any other small gas engine will turn into a slim in a way and will block the carb. Drain the fuel and clean the carb system will run great when that is done
Feb 19, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
