Question about Chevrolet Vehicle Parts & Accessories
Power failure Power drain, won't start, accelerates slow.
    Scholar:
  • 117 Answers
Start with a check on how much fuel pressure is in the system. Low pressure will make it hard to start and not run well. Also a plugged catalectic converter will do the same
Posted on Nov 02, 2013
My fisher and paykel smart drive 9 5.5kg won't power up
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If there is no power it can be due to a failure of the power supply.
Jan 15, 2013 | Fisher and Paykel Washing Machines
1996 Nissan sentra slow turn over but won't start
check your battery sound like it's not getting enough power
Sep 22, 2012 | 1996 Nissan Sentra
Car won't start. Sounds like the engine flooded. Not the starter. Also loses power going uphill and when accelerating.
Check Engine Light flashing when accelerating ,severe engine misfire . Something in the ignition system is breaking down under a load . If the starter engages an spins the engine when you turn the key to start an it doesn't start an run , it has no spark or fuel pressure . If you don't know this or how to diagnose .suggest you take your vehicle to a qualified repair shop . Pull two plug wires off the top of the same coil an crank the engine , if you do not see a spark jump from one coil tower to the other you have an ignition system problem . ignition module or crankshaft position sensor
Flashing check engine light CarMD
Nov 16, 2017 | 2000 Pontiac Bonneville
1990 Dodge Dakota 4 cylinder, 2.5 l engine was losing power and now won't start.
Have you checked it for fault codes, this is an electronic engine control system test. Follow the link to see how to do the teasting at home.
Sep 13, 2012 | Cars & Trucks
Battery completed drained, now won't start up even with A/C power
If it is not opening with AC power that is the not fault of battery instead of main chip on the motherboard, so you need to check it and take it a very good laptop technician.
Good Luck
Aug 21, 2012 | Medion MD 96340 PC Notebook
2003 buick century won't start -replaced battery, no clicking noise
Check for power on the large wire at the starter. There should be power all the time. Check for power on the small wi at the starter. There should be power with the key in the crank position. If both of the above are true than the starter is likely bad.
Jul 23, 2012 | 2003 Buick Century
I have a Compaq M700 lap top. power failure , Won't boot up ?
You need to find out if the power supply was damaged, it would have been the first to take a hit, remove the main battery to see if it will boot because a bad one will load the system down in some cases. One trick that might work, unplug power supply from laptop and remove main battery, now press and hold power for 2 minutes to drain off residual voltage and reset the processor, finally install everything back and power up.
May 03, 2012 | Compaq ARMADA M700 PIII500 MHZ LAPTOP...
My packard bell zg 5 won't start after the battery has drained. When I plugged the charger in, the battery indicator only keeps on blinking and won't start.
Try removing the battery and then connecting the power adapter and see if the laptop will start normally with no battery installed - if it does, then you should get a replacement battery.
Jan 05, 2012 | Computers & Internet
COMPRESSOR WON''T START
Possible failure of the compressor motor, failure of the main relay or the capacitor or there is fault in the pressure switch or the thermostat.
You will need to check the circuit to confirm , check the path of the main line and see the reason for the power loss to the compressor.
use a clamp testor to measure the current of the motor to confirm if the drain is high.
Sep 05, 2011 | Refrigerators
Dell e310 won't start after power failure ,orange
First up, don't buy a Dell again unless you like old **** with horrible support.
On Topic
- Did you pull out the keyboard and try another USB port (if it is an USB keyboard), or try another keyboard.
- If that doesn't work try clearing the CMOS (remove power plug, power on (to empty capasitors), either remove the CMOS battery and power on, or find a jumper to reset the CMOS. (since this is a Dell a that might not exist but check the manual).
Jun 25, 2011 | Dell Dimension E310 PC Desktop
Vehicle Parts & Accessories Logo
18 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
