Question about Epson Powerlite Home Cinema 5010 3d Home Theater Projector
Horizontal lines traveling upward during use. It takes about 25 seconds to travel the entire length of the screen.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 40 Answers
Tap it lightly with your hand. dont hit it hard just tap it. clean the lense and make sure everything is connected properly
Posted on May 09, 2013
I have Travellers Cheques, and during my last visit in Europe, I was told that they are not in use any more. What can I do with them?
  • Take your traveler's checks to a bank or currency exchange. ...
  • Countersign the checks that to want to cash on the line provided. ...
  • Give the traveler's checks that you are cashing to the exchange teller or cashier. ...
  • Provide a photo identification card when requested to complete your transaction.
Dec 08, 2016 | GPS
Dark horizontal line traveling across the screen vertically
on tube tvs bestto go on main bord look for hairline craks on soldering ok redo them nice it will light up happend to mine also older model thx nick
Feb 06, 2008 | Sony FD Trinitron KD-34XBR960 34" TV
What is the rolling offset using 45 deg bends
The formula for 45 degree bends is offset" x 1.414 equals the travel distance in inches. Example: to calculate the offset of a line 6 1/4", in other words move the line over. Turm 1/4 into decimal form (1 divided by 4=.25). Calculate: (6.25 x 1.414= 8.8375). To convert the decimal form of .8375 to a fraction multiply it by 16 (16/16=1") example: .8375 x 16=13.4 , 13 is the numerator, 16 is the denominator which gives you a fraction of 13/16". That gives you your travel distance center to center of a 6 1/4" offset= 8 13/16" travel distance. For accuracy in your measurement, you must subtract the fitting allowance (how much space the fittings take up in the measurement) from your overall travel distance. It sounds like a lot of steps, but using this formula gives you dead on accuracy in pipe fitting. If you know your travel distance and wish to find the offset, multiply x .707. Hope this helps.
Feb 12, 2015 | Plumbing
I have the Epson GT2500 scanner. There is a black line down the middle of every page that I scan
There is a speck of dirt or some such on the ADF Scan glass not the flatbed iteself. As the paper travels over the glass the speck of dirt is being seen by the scanner making a "line" appear on the entire length of the scan.
Feb 16, 2011 | Epson GT-2500 Flatbed Scanner
Agasta ant starts at one edge of a placemant, 29.6 cm wide. she travels at 1.40 cm/sec at 52.o degree from one edge. how long will it take her to get across the width?
draw a right triangle. The bottom of the triangle is 29.6 cm and the angle is 52 degrees (from the other edge). note: triangle not to scale.
|52 \
|_____38\ 52|
29.6
Therefore the inside of the angle is 38 (90-52) and the opp angle is also 52 (90-38)
sine = opp / hyp therefore hyp = opp / sine
length of hypotenuse is: 29.6 * sine 52 deg.
therefore the length of the hypotenuse is 23.32511 cm. the ant travels 1.4 cm / sec so the ant travels to the other edge in 16.66 seconds.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
A rock climber throws a small first aid kit to another climber who is higher up the mountain. The initial velocity of the kit is 18 m/s at an angle of 74° above the horizontal. At the instant when the...
Depends on how long it has been travelling. If it is horizontal when it's been caught then ot must have reached zero velocity. No matter the angle gravity works at 1m/s/s. Do the math.
Sep 18, 2009 | NorStar Operational Software Category E...
Lines on copy/scan/fax
You have something on your "scanner glass", the narrow piece of glass that the scanner "looks" through during adf use. Get some window cleaner or rubbing alcohol and clean it with a damp cloth. Often, it's correction fluid (Liquid Paper). A little dot is all it takes because the paper is traveling across the dot, effectively drawing a line down the length of the page.
Aug 04, 2009 | HP Office Equipment & Supplies
JVC Model no: AV-48WP34 Projection Problems
OK, problem seems in convergence section of TV and can be confirmed by testing voltage supply as mentioned in schematics.
You can download service manual copy from Manual Zone for small fee and it has schematics, exploded views. board location, part numbers info.
Let me know if you need further help.
Thanks.
May 07, 2009 | JVC Televison & Video
Horizontal lines on NEC plasma
Intermittent horizontal deflection
Resoldered the pins of horizontal deflection transformer
Picture is horizontally narrowed and deformed
Capacitor C2913 (390nF, 250V) on the deflector PCB had lost capacity
Geometric distortion, Pillow, and picture enlarged horizontaly
The problem was a short from GND to pin 11 inside IC301 (TDA8350Q). This pin is the output of amplifier for geometric correction signal. Replace IC301
Nov 26, 2007 | Televison & Video
Horizontal lines traveling up screen
Sounds like a ground loop on the video signal. Try using a ground lift on your computer and or your projector.
Jan 09, 2007 | Sanyo PLV 70 Multimedia Projector
Epson Powerlite Home Cinema 5010 3d Home Theater Projector Logo
118 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
