Question about Nixon The Rubber Re-Run - One Size - Black
Display is messed, did the battery die?
The watch was acting weird for a while, always changing time on its own, and then one day it just went blank. Every section on the screen is visible but the lights or nothing will come on and nothing happens when you push the buttons. I do not want to send it away if it is only the battery, but i do not want to void the warranty at the same time! help!
2 Suggested Answers
SOURCE: I have a Nixon LowDown
Hey, this just happened to my nixon watch (I have the nixon housing - same setup as the lowdown) and what you have to do is simply hold in the light display button for about 3 seconds and the display won't disappear after the light times out.
hope this helps :)
Posted on May 10, 2011
Changed the battery and have the time set but can't figure out how to set the day and month.
If you are setting a car radio, they almost always use the seek(right/left) and tune(up/down) as the toggle switches.Try using the ones that you did not use to set time to get you to the month/day screen. Good luck.
Aug 15, 2015 | Watches
Casio pathfinder battery operated watch keeps blanking out display?
Your watch is solar powered, so I think it isn't charged lately. At a low charge, the watch goes into saving mode by switching off the display (while keeping the time, date, etc.). To charge the watch leave it in a brightly lit spot for a day or two. That should be enough to make the watch function as normal again.
For more information, you can download the manual of your watch here (direct download link):
Timepieces Watches Manuals CASIO
Jun 11, 2014 | Casio Pathfinder PAG60-1AV Watch
Set the time on a 3-button Armitron All Sport 45/6963
I have the same watch. I've figured out how change in and out of 24 hour time.
1. press and hold "ST/STP" until the month/day screen is visible.
2. while holding "ST/STP", press "MODE". A 'p' visible below the month/day indicates 12 hour mode. The absence of a 'p' indicates 24 hour mode.
Manual for 4-button version is here, but all the directions are applicable. https://www.armitron.com/images/upload/XNAPE01.pdf
Nov 05, 2012 | Armitron Watches
I didn't wear my Michele CSX 36 w/ diamond watch for a few days..When I went to put it on the time was wrong. So I tried to correct it and now it has not kept accurate time w/in a 24 hr period. Fo
I am pretty 100 percent sure that Michele CSX 36 diamonds only comes with a swiss quartz movement not an automatic movement.
So the problem seems to be that the battery is dying and need to be replaced. Stopping and going is usually a sign of a battery dying in a swiss quartz movement.
So it should be nothing major and just a battery.
Jan 23, 2012 | Michele CSX Diamond watch
The display went blank, changing battery didn't bring it back to life. I have 2 of these watches and have successfully changed batteries before, despite the tricky process. is this watch dead?
Unless the new battery is dead that would explain it, but assuming the battery is good it indicates a failure in the electronic module and should be considered done.
Jun 27, 2011 | Watches
After I changed a battery on R0614ZM TERNER watch, the display went berzerck and then blank altogether. Any ideas at all?
Some watches have a "reset" button or combination of buttons that must be pushed to clear all the electronic registries on the watch's little computer after you replace the battery. You might try taking off the watch back and seeing if your watch has this requirement. Even then, it's not always a perfect solution. Last week, I replaced the battery in a watch that had been dead for some time. The watch appeared to come alive again when I put the new battery in, but when I pushed the reset pin (on this movement, it was on the watch movement itself, next to the battery), the entire watch went dead. Nothing I did would wake it up. I removed the battery, waited 30 seconds, then re-inserted the battery. Problem solved; the watch powered up, and I was able to set the time and access all functions again.
On some digital watches from the 1980s, after replacing the batteries, you were supposed to push and hold all the external buttons for a few seconds to reset the watch. I don't think manufacturers still make watches that respond to this, but it is easier to try than taking off the back and re-installing the battery.
May 10, 2011 | Watches
My Puma watch screen went blank?bought it April of 2010 at nike store in chicago? model 910192001? How do I solve this problem. I know its under warranty
If it had been sitting on display for long time the battery might need replacement. I'd take advantage of the warranty and have them replace the whole watch.
Jun 02, 2010 | Watches
My watch is 8 months old and just stopped..the screen still displays the exact time and date that it died..but because it's digital if it was the battery the screen should have gone blank?!!
Best bet is to start by replacing the battery. At 8 months it'll be due for one soon anyway and a new battery may "reboot" it so it runs again. As a battery wears out it doesn't just stop, it may still maintain the display even though it stops keeping time. Also, new "e-ink" displays require no power to maintain the display 0 only to change it.
Apr 28, 2010 | Columbia Digital eBook Watch for Women
Day/Date change
The date on mechanical and automatic watches change normally between 2-4am because this is normally when people sleep. It is not broken or in need of overhaul. It has to change sometime and that is what they have tradionally used as a time for the date to change. Also remember it is normal for an automatic or mechanical watch to loose or gain time friction is the culprit here since the gears do mesh with each other.
Fine watches like Rolex and Omega are beautiful watches but expensive to have cleaned. It should be cleaned about every 10 years or if it starts to loose a lot of time.
Incidently most agree that the Omega speedmaster manual wind (The watch that went to the Moon) is the most accurate of the bunch and is very sought after by collectors!
Apr 10, 2010 | Guess Dress Bracelet 87000L1 Watch for...
My watch to my garmin forerunner 50 started bleeping last week and then it went blank (the watch), changed the battery twice but still not working. can you help?
I have read the instructions for your watch and I found nothing in there that was helpful.
I am having a guess here but perhaps the memory is full (did you see the "Lo mem" warning?
Try downloading the memory to your computer if you can with a blank screen!
As a last resort, go to theri web site and find the "contact us " phone number and ask the maker.
Mar 15, 2010 | Garmin Forerunner 50
Nixon The Rubber Re-Run - One Size - Black Logo
51 people viewed this question
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
