Question about Electrolux ICON Professional EDW7505HPS Stainless Steel Built In Dishwasher with Fully Integrated
Er 2 Thermistor
Dishwasher won't work error message 2 and won't quit beeping!
  • Electrolux Master
  • 15,941 Answers
There is a water temp sensor in the unit. That sensor has failed.
Posted on May 12, 2013
How long do Ecoquest purifier plates last?
The "Replace Plate" message comes on for more than just the plate. Is the fan still running when it displays (Replace Plate"? The squeaking noise would be coming from the fan. I don't know what all it works for. It does display when the plate contacts are dirty, when a wire to the plates is loose or corroded, when the bulb is bad or loose and when the ozone generator quits. I have encountered all of those. Plates should last a couple of years, depending what's going on in the indoor environment. Before you go any farther, call (336) 499-2505 - they give away information and will help you solve your specific problem.
Jun 11, 2012 | Ecoquest Fresh Air Air Purifier
Perform cleaning on EcoQuest Fresh Air won't go away after pushing reset button
If you did not thoroughly clean the contacts for the ozone plate, the "Perform Cleaning" light will not reset.
May 05, 2012 | Ecoquest Fresh Air Air Purifier
My Fresh Air Eqo Quest shut off yesterday and I can't get it to go back on. I have hit the reset button, I unplugged and replugged, I even cleaned everything. It won't turn back on. Is there a...
There is a fuse in where the AC cord plugs into the purifier. Remove the back cover, and you should be able to remove the fuse by prying the fuse cover off with at straight screwdriver. It takes a 1.6 amp fuse for 120Volts
Jun 06, 2011 | Ecoquest Fresh Air Air Purifier
I have cleaned the filters, and i still get the Clean Filter message. It is running fine, but the red letters Clean Filter are still there... any suggestions???
How did you clean the filters? I run mine through the dishwasher by themselves and it works pretty good. The tops and bottoms of the filters near the edges need to be wiped pretty clean.
Jan 02, 2011 | Brookstone Pure-Ion (506840) Air Purifier
My sister gave me her Brookstone Pure ion Air purifier....The "clean filter" light flashes red....I wiped the filter with a damp cloth...so think it is clean...?....Is this how to clean it? ....and how do...
Wiping it off won't clean the filter. I submerse mine in hot soapy water ( oxiclean w/any favorite multipurpose liquid cleaner.Let it air dry completely before placing it back in unit.I have tried the dishwasher method and it didn't clean it.I also thoroughly wash all crevices of the unit.If red light doesn't go off, reclean the filter(s). It has all ways worked for me.
Sep 23, 2010 | Brookstone Pure-Ion UV Air Purifier
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
Kenmore 85264 Electro Static Air Cleaner
I would recomend calling the 800 number to answer that question. I have this unit too and the instructions do NOT say to soak in Amonia and Vinegar! Good luck with that!
Mar 15, 2008 | Air Purifiers
Electrolux ICON Professional EDW7505HPS Stainless Steel Built In Dishwasher with Fully Integrated Logo
91 people viewed this question
Top Electrolux Air Purifiers Experts
Richard Lane
Are you an Electrolux Air Purifier Expert? Answer questions, earn points and help others
