Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Trans bad? wont go forward or backwards... belt good. turning trans pulley.. idk
    Sergeant:
  • Craftsman Expert
  • 417 Answers
Jack up the rear end using the frame. Put a person or cinder block on the seat, and put it in drive. Look for the shafts turning inside the wheels indicating broken keyways.
Posted on Jun 10, 2013
4 Suggested Answers
defadad
  • 351 Answers
SOURCE: hydrostat trans starting to make moaning noise stops pulling
it may be full of dirt etc and has soaked up most of the oil inside the case, if the axle seals are worn and the selector shaft seal is worn I would say that is the problem, if that is the case you may be up for a new trans as I have done a transaxle just recently and the damage inside was extensive and expensive.
you will have to remove the trans and seperate the trans case for inspection
Hope this helps
Posted on May 23, 2009
  • 376 Answers
SOURCE: Ichanged the rear drive belt on my 17 hp
Ok, I see it's and MTD product. Did you replace both belts? The front belt is #954-0280 and the rear belt is # 954-0370. What I would suggest is remove the cover plate between your legs. You'll have to remove the shift knob and two screws. Start the engine, put the gearshift in nuetral and let out on the clutch pedal and observe what's happening. Everything will be working the same as if you were in gear. You should be able to see if there is a problem with one of the belts or the vari-speed pulley. Put the speed selector in 7th (or 6th) gear and push the clutch down then back up, and watch what going on. That's the best I can do without seeing it myself. Hope this helps.
Posted on Jun 22, 2009
  • 6468 Answers
SOURCE: Craftsman LT2000 Automatic wont move forward or backward
when you took off the bag did you pull the lever that allows you to push it around the one that puts the hydro drive in neutral its on the back a couple inches away from the eyelet you can tow with it should be released forward
Posted on Mar 25, 2012
HAVE A 4 YR. OLD REAR WHEEL DR. HONDA MOWER THAT THE REAR WHEELS LOCK UP WHEN PULLING IT BACKWARDS OR TURN REAL HARD.
sounds the belt may be too tight if it is the same belt that has been working maybe a weak spring on the transmission
Aug 17, 2017 | Honda Garden
Toro TimeCutter cranks but when I try to go forward or backward it goes dead and will not move. Funky smellll
Sounds as if you have deck pulley that is bad and locked up and belt is smoking trying to turn, this in turn kills engine due to stress applied to it.
Jul 29, 2017 | Toro Garden
Craftsman mower deck belt tensioner keeps bouncing and shaking the deck
Bad pulley ???? Bent blade shaft,Bad bearing???
May 31, 2014 | Mtd Garden
Jerky movement
there are 2 drive belts that control the transmission. 1 is a variable speed drivebelt going from the engine back to the trans. it is the long one. the shorter belt drives the trans. off of the other variable speed belt. both belts are located under the mower and are not fun to get to. I would bet that one of these belts are slipping and grabbing, giving you the jerky ride. visually inspect for cracks or peeling, then check tensioning system for the belt to make sure they have the correct tension. less likely would be in the geardriven trans. it might act that way if some teeth of the gears inside are worn or broke. one other thing to check if all else looks good.... the variable belt drive pulley expands and contracts to change speed of the transmission input. I have seen these pulleys fail to operate correctly and this could also cause the ride to ****. hope some suggestions here help. R
Aug 23, 2012 | Toro Power Lawn Mower
1997 MTD Riding Mower 18hp 42"cut. Drive belt
I wish to tell dwhandys that this is a great answer, and a great solution. You surely know how to work!
Sep 03, 2011 | Yard Machines Garden
I have a fiat ulysse and the power steering belt
yes, sounds like the pully is no good, may have bad bearings in pulley, replace it.
Jan 03, 2010 | Fiat 124 Cars & Trucks
Our john deere sabre 17.542 hs ride on mower will not go forwards or backwards.We're looking for a diagram of the hydraulic gearbox/diff
If traction drive belt is turning you should check the input drive shaft on top of trans to see if it is turning as well,Traction drive belt is suspect but could be a stripped out input shaft pulley.Make sure the machine tow lever is not pulled out,rear of machine by tow hitch.Also pull rubber caps off of both axle ends to see if one the axles is turning free inside of rim,if so remove wheel and replace axle key.
Nov 15, 2009 | John Deere Garden
Waher maytag
Pull your washer forward then tilt the top backwards until it sits at about a 45 degree angle. There should be a belt and 3 pulleys underneath. Remove the belt (one of the pulleys will move to allow slack) Ignore the moving pulley and the large pulley in the center. The third pulley is your pump. Try to turn it by hand, it should move freely. Presumably, it wont and will need to be replaced.
May 26, 2008 | Amana NAV5800A Top Load Washer
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
87 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
