Question about Fiesta Classic 26,000 BTU Grill
Regulator model 718 made in Italy
Need to replace my old regulator on my gas grill, 2 burner, 13000 BTU/burner. i need to buy one. HELP
2 Suggested Answers
  • 54 Answers
SOURCE: Blue Ember Gas Grill: I need a replacement for the grease pan and grease...
First of all check this list your grill may be recalled! http://www.cpsc.gov/cpscpub/prerel/prhtml09/09283.html the Grease pan is at http://www.appliancefactoryparts.com/gasgrillparts/brands/fiesta the cup is at http://www.appliancefactoryparts.com/gasgrillparts/brands/fiesta
Posted on May 20, 2010
Viking grill burner low flame
If this burner has tube type, You can loosen a screw in the front of burner and slide open air rater vent just a little just make sure not to open to far. blue-ish/orange flame is what your looking for
Apr 10, 2015 | Viking 500 Series VGBQ53002RELSS 30"...
Pilot stays lit, burner comes on but only a portion of the burner area has flames.
remove burn tray clean out all burners sounds like all sooted up then check gas pressure to see if adequate gas pressure
Sep 13, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
The regulator has a hissing leak when tank is attached to grill Grill is Master Forge 2-burner gas grill, Model # MFA350CNP The leak was noticed because the grill would not heat to beyond 250 degrees....
You will need the replace the grill's Hose/Regulator Assembly. You can pick one up at any hardware store or home center that sells grills and accessories for about $30.00. Take your old one with you for comparison purposes.
After you install the new one, be sure to check it for leaks, as described in the grill's Owner's Manual. Also, and this is very important. When opening the gas tank valve, open it Very, Very Slowly (slow motion, slow). If you don't, the regulator will lock up and no gas will flow to the burners.
Hope this helped you and thanks for choosing FixYa. Happy Grilling!!
Sep 07, 2011 | Grilling
I am renting a condo with an old Weber Grill - 2 burner / LP (I think it is a Genesis Silver A ('00-01) model . I have very little gas pressure at the burner tubes. - Front tube flickers on/off with...
Yes the best option for just for you is to buy a new burner,tube kit and a new manifold kit because all the things that you said you removed from the burner must have caused alot of rust on the burner and if you keep welding the burner there will still be linkage after awhile so the best thing is just for u replace the burner.
Jan 15, 2011 | Weber Genesis Silver A Grill
Can i drill out LP hole in cap for NG
Yes you can, but only if you know the BTU rating of the burners. Then you need to know what size drill bit to use to drill each orifice. Plus you will need to eliminate the LP regulator when you hook it up to your house's already regulated natural gas line. When you hook up any gas appliance, it needs to have it's own shut off valve installed on the gas line. I also like to install a quick-disconnect adapter after the shut off so I can release the hose from the grill and put the grill away when it's not in use. I have LP/Nat gas conversion charts available to look up drill sizes if you need to know more details. Keep in mind, that if the grill does not state the individual burner BTU ratings, but only the total BTU rating, you will have to divide that rating by the number of burners. Douglas
Sep 05, 2010 | Weber Genesis Silver C Grill
How do I reconvert my Natural Gas BBQ BACK to LPG?
You will need to replace the nat gas orifices with propane ones, as propane orifices have smaller holes than nat gas ones. If you can't find a conversion kit for your grill, take it to a local propane co and have them convert it for you. What I do is drill out the existing orifices on the grill and install a spud, then redrill the spud with the smaller hole for LP-Gas. Then you will need to buy a regulator and hose and a 20# propane cylinder, if you don't have one. You can get those things from the propane co too. Call around first and see if anyone can help you.
NOTE: If your grill data plate isn't marked with the BTU rating of each burner, look at the nat gas orifices and see if there is a number stamped on it. I can reference this number to tell you what BTU rating they are drilled for and use that to redrill for propane. If they are not stamped with a number, then I would use my nat gas orifice drills to gauge what hole size it is. Hopefully you can find a local propane co that carries these orifice drill kits and orifice spuds to get the job done. You didn't mention the grill brand or model #, so I can't help with specifics until I know what you have. I may be able to find a conversion kit online if I knew that info.
Douglas
Jun 13, 2010 | Grilling
Converting weber natural gas grill to LP Gas
You will need to replace the orifices and install a propane regulator and hose. Plus, of course, you'll need to buy a 20# cylinder. I looked up your grill serial # and found a parts explosion for your grill. Here is the link: http://www.weber.com/PublicSchematic/view.aspx?model=6821001
If you click on the "additional parts" link, they have the conversion kits listed, but none of them are available anymore. As a propane guy, your best bet is to take it to a local propane co and have them convert it to propane for you. They will drill out your existing orifices and install spuds, and then re-drill smaller holes for the appropriate BTU rating for each burner. Then they can install the regulator and hose and even sell you a new and full 20# cylinder. Call around first and see which one can help you, as not all have serviceman that can do this particular job. Hope this helps. Douglas
Jun 06, 2010 | Weber Genesis Silver B Grill
Not enough heat being generated
First things first. Make sure you didn't simply just the tank valve on too fast, causing the excess flow valve to cut-off gas to a trickle. Close tank valve, disconnect and reconnect and then open tank valve very slowly.
If that doesn't solve the issue, seeing that you already replaced the regulator, then it's possible it wasn't converted properly. If he didn't change the orifices, leaving in the nat gas ones, then your flames would be large lazy yellow flames. If that's not the case, then it's possible he might have put in the incorrect size LP orifices based on a wrong figuring of BTU rating per burner. See if you can you find the BTU rating on the grill? How many burners are there? Does it state the BTU rating of each burner. If they are different sizes we will need to know BTU specifics for each burner, but if all are the same size, we can divide the total BTU by the # of burners for BTU rating per burner. Orifices have a # stamped on them, so see if you can read the #'s on the existing orifices. If he used the nat gas orifices and drilled them larger and installed a spud, which he redrilled for LP orifice size, then that stamped # won't matter. Something like this is a lot easier to trouble shoot in person! Using a small mirror, see what you can figure out on those orifices and we'll try to determine if they are correctly sized. Hope this helps.
Douglas
May 23, 2010 | Viking BQC300T3 Gas Grill
Bbq regulator
should be able to get some help at your local hardware or home & garden store!
May 31, 2009 | Weber Baby Q Grill
Char Broil commercial grill won't heat pass 300 degrees
I had a similar problem and thought the propane kept running out....come to find out it was a defective regulator. $21 at the local ACE store as running to LOWES and trying to get a point across to a 17 yr old summer help college kid for a intermittent problem seemed more challenging then it was worth. Would barely light the burners and would not get over 200 degrees. Ripped it apart...blew through all the orfices including the regulator put it all back together and would work for a while then fail again. Good luck!
May 30, 2008 | Char-Broil Commercial Stainless Steel...
Fiesta Classic 26,000 BTU Grill Logo
109 people viewed this question
Top Fiesta Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Fiesta Grilling Expert? Answer questions, earn points and help others
