Marantz Remote not working
Brand new Marantz receiver and remote does not work
SOURCE: Marantz Remote control model RC-18SR
Does the SOURCE ON\OFF button still work? If so, you can still use the remote to turn the receiver on and off by first pressing the AMP button (so that the remote window says AMP) and then pressing the SOURCE ON\OFF button.
Posted on Mar 12, 2008
  • 6 Answers
SOURCE: Martantz SR 3000 - Are there any remote codes
Click here for Comcast Remotes Five Didgit Codes hope it works for you did for me.
Posted on Sep 10, 2008
  • 336 Answers
SOURCE: Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Posted on Feb 13, 2009
  • 4 Answers
SOURCE: Marantz 6200
Your unit's micro IC, is in need of a reset.Un-plug the unit and locate the semi large yellow capactor on the main board. (r-h side facing front) Now flip the unit over and look thru the vent holes in that same area and locate the two solder pins. Short them out with a thin metal object, like a straightened out paper clip or wire, and turn it over (just discharge the cap and remove your wire) this will default all settings and restore normal operation.
Posted on May 27, 2009
kerguney
  • 577 Answers
SOURCE: I have a Marantz SR
You have a nice piece of Stereo...I believe you have mistakenly selected the" display mode OFF" function..,Here is the info that you can reactivate it..
If you need a soft User Manual here is the link for it too..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)...please insert some words in "
My Testimonials "
Hope this helps!
" display mode OFF"
You can select the display mode for the front display
of the SR7001.To select this mode, press the DISPLAY on the remote control or the front panel.When this button is pressed, the display mode is switched in the following sequence.Input Mode ? Surround Mode ? Auto display OFF ? Display OFF ? Normal Mode ? Input Mode Normal Mode: Displays the selected input function. If the function has been renamed using the Function Rename feature (see page 26), the renamed name appears on the display. Input Mode: Displays the input mode set via the Function Input Setup feature (see page 25). Surround Mode: Displays the status of the selected surround mode. Auto Display Off mode: The display is off. But, if you make a change to the unit such as the input or surround mode, the display will show that change, then go back to off after about 3 seconds. When changing the volume, it is not displayed. Display Off mode: The display is off completely. Note: • Only the DISP indicator will be illuminated on thefront display in display off condition
http://www.scribd.com/doc/53431794/Marantz-SR-8001-Owners-Manual
Posted on Jun 23, 2011
How to use harmony 300 with Marantz SR780 receiver. Original remote not working, can't use to teach the codes. Any suggestions?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily....
http://electro-medical.blogspot.com/
Dec 22, 2016 | Marantz Televison & Video
I have a Marantz SR5000 receiver that stopped responding to the remote control. seems like the remote is working properly. The receiver also works fine besides the fact that it stopped responding to the...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Aug 22, 2011 | Marantz SR-5000
Can't turn on and off without manually going to unit. Have remote rc18sr. System still rocks, however went online to try for a new remote, i guess this is obsolete.
Marantz RC18SR Remote Control RC-18SR
Item condition: Used
Time left: 21h 0m 48s (Feb 17, 201111:51:43 PST)
http://cgi.ebay.com/Marantz-RC18SR-Remote-Control-RC-18SR-/180627142815?pt=LH_DefaultDomain_0&hash=item2a0e37789f
Marantz RC18SR Remote Control RC-18SR Item condition: Used Time left: 21h 0m 48s (Feb 17, 201111:51:43 PST)
Feb 16, 2011 | Marantz AV-560 Receiver
The remote does not work
Hello my Marantz dv4100, didnt respond to my remotecontroll, Remote was working. remote from my philips dvd722 works fine with this Marantz-dvd too.
i found 2 solderings at the back of the front circuitboard in remotecontroll receiver optounit at the left side of dvd-display, pins 1 & 2 needed resoldering, had cracks in solderings. after that it was working fine again.
hope this helps u too.. good luck!
Dec 23, 2010 | Marantz DV4100P DVD Player
Marantz SR-18ex remote control number
If you mean the model number, that is: RC-18SR
Jan 10, 2009 | Marantz SR-18EX Receiver
Do you know the remote code for the Marantz SR-18ex receiver? I want to control it from my Comcast remote and can't locate a remote control number.
The stock remote for the SR-18EX is the RC-18SR - that's the one it shipped with when new. You can also use the RC-2000, RC2000 MkII, and I have an aftermarket RC-1400 that works perfectly with my SR-18EX, AND offers 15 macros instead of the standard 4 you get with the stock remote.
Marantz model 5500 AV Surround Receiver
Hi, hope this helps, try (1-800-remotes), these guys have a wide selection.
Oct 22, 2008 | Marantz SR5500 Receiver
96 people viewed this question
 Grubhead
Grubhead
