Setting of USB boot
As there is no option for USB boot in the BIOS setting scrren for my Fujitsu A6110 laptop, would any one provide me with help?
  • Computers & ... Master
  • 5,660 Answers
Http://support.fujitsupc.com/CS/Portal/supportsearch.do
A6110/A6120 BIOS Guide
Boot Menu
Nope. No option for booting from USB
1. Floppy Disk Drive
2. Drive0: (Harddrive)
3) CD/DVD Drive
4) NETWORK
5.
6.
7.
Excluded from Boot Order:
USB MEMORY
USB Harddrive
Back before USB thumbdrives (Flash Drive, whatever), came on the scene; the Floppy Drive was used. Then the Optical Drive came out.
(CD/DVD drive)
Transfer the boot data to floppy disks, or a CD/DVD disk.
Make sure they are bootable..........
Regards,
joecoolvette
Posted on May 06, 2013
Teis
  • 340 Answers
SOURCE: lenovo bios password
I found a homepage with a load of Backdoor passwords, - one of them will bypass you forgotten BIOS password. If you dont know your type, you´ll have to try them all out, or untill you hit the right one:
http://www.computerhope.com/issues/ch000451.htm
Good Luck
/Teis -> dont forget to vote before you leave :-)
Posted on Dec 11, 2008
Jackal913
  • 14 Answers
SOURCE: Boot to USB?
most of the newer motherboards have an option to boot from usb, I have 2 1 laptop a Dell XPS 2010 will boot automaticly to USB if it is plugged in and has the option in the bios for boot seqence, and a desktop a dell XPS 720 it will alsi do the same, see if you can find a live copy of XP or the OS of your choise and you can boot from DVDR I have a copy of XP Lite Portable that boots from USB and runs fine
Posted on Nov 04, 2007
SOURCE: "USB Device Not Recognized" - any usb device
is vista sensitive than xp??
Posted on Apr 10, 2008
  • 148 Answers
SOURCE: boot from usb
Sounds like the boot order menu is what you have. Set the boot order menu to try other devices before the hard drive. (Example: CD/DVD drive, floppy; if present, USB devices, hard drive). You should have a default key for accessing the boot menu (usually f11 or f12). Hit this key and choose the USB option. Make sure the device you want to boot to is already connected before you turn on the laptop.
Posted on Mar 02, 2009
romsky79
  • 822 Answers
SOURCE: I have an Acer AOA 150 can't boot from usb
some bios setup don't have usb boot setting.pls check your bios first if there is USB enable.
Posted on May 06, 2009
Usb boot
If the BIOS does not list the USB devise in the Boot start up then You cannot boot up the laptop with an USB device.
It maybe possible with a BIOS upgrade, check the Fujitsu WEB site.
May 06, 2013 | Fujitsu LifeBook A6110 PC Notebook
Usb boot
Start your PC and press F2 several times until the Bios menu comes up. Then select boot order or bootable device options and allow for usb devices to boot. Make sure the USB device in the boot order is moved to be in front of the HDD so it checks for it first and thus will load your linux distro from your usb drive.
Jun 25, 2012 | Fujitsu Siemens Fujitsu St-5010 St-5010d...
Reboot from usb
If you mean that you want to boot from USB, please note that older laptops may not support that option.
Go to BIOS and check settings to make sure USB Boot is enabled, and that your USB drive is set to First Boot Device, or something along those lines. Also if you provide model number it would help us help you.
Jun 18, 2012 | Acer Computers & Internet
Can't boot from USB on motherboard "ASUS p5s-mx se". No issue on BIOS Setup menu !
Start and pres Del /F 2 /F10 for Setup bios .Change the boot sequence.
Usb drive 1st
Hard disk 2nd
BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2
Phoenix BIOS setup and help
And make a boot-able pen drive.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Hope it helps.
Jan 19, 2011 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Bios password unlock for a6110
There are some advices from guys suffering from the same thing with you.
I did not tried myself, but may help to you.
regards.
Aug 17, 2010 | Fujitsu LifeBook A6110 Notebook
May 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Fujitsu nightmare
ok try setting bios back to HDD first boot, then when it can't find the operating system it should then give the option to boot from the cd again. If it still don't work then look for default settings in bios and set it then change it back again, you could be stuck in bios loop. But i'll open the window ready for you.
Jan 16, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
237 people viewed this question
David Payne
David Payne
