Question about Frigidaire GLTF2940ES Front Load Washer
Technika loading washing machine service manual
Machine has stoppped mid wash, will not do anything at all.
  • Official Brand Answer
  • 4,342 Answers
Hello notnan24 - Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. If you noticed a humming noise, it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Posted on May 06, 2013
  • 3 Answers
SOURCE: Frigidare front load washer warranty
The usual factory warrenty periord on the Frigidare Affinity washer is 1 Year from date of purchase. You can find your Model number and serial number of your washer on the inside of the door. It is on a white label towards the bottom of the dorr.
Posted on Nov 12, 2007
huuum
  • 750 Answers
SOURCE: smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Posted on Oct 06, 2008
  • 196 Answers
SOURCE: Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Posted on Nov 12, 2008
SOURCE: frigidaire washing machine no spin cycle
I had the same problem with my Frigidaire Affinity front load washer. It would go through the wash cycle but would not do the final spin cycle that takes the access water out of the clothes. It would actually cut off when it got to be 6 minutes left. I checked the hoses, belt, motor and pump but all were functioning properly. I even cleaned out the filter thats located in front of the water pump. It was full of coins and other debris but it still didnt fix the problem. I called the repairman and he concluded that the control board was bad and would have to be relaced. The board is $200 and labor $140. It will cost you $340 dollars to correct this problem unless you know how to replace the control board yourself. Only had the washer for 3 years. I wouldnt expect something like that to occur within that short period of time.
Posted on Sep 22, 2009
  • 38 Answers
SOURCE: burning smell during spin cycle on frigidaire washing machine
Open lid as you would load clothes and hold the inner drum with all the holes in it. Give it a manual turn left, then right. If it spins in both ways the main bearing is gone. This is not a DIY because the new bearing has to be pressed on at a machine shop, or an appliance repair shop.
Posted on Dec 29, 2009
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    What is error E:00 in Bosch maxx 6 washing machine?
    error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
    Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    How to Identify Bosch Washing Machine Error Codes
    How to Identify an Error Code on Bosch Washing Machine
    Washing Machine Error Codes Front Load and Top Load Washers
    Download instruction manuals
    Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
    Doesn't work. Why does it stop mid-cycle?
    washing machine stopped mid cycle, won't drain : DIY - Reddit
    https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
    RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
    Troubleshoot - washer stops mid cycle, won't drain or spin ...
    ? 1:58
    https://www.youtube.com/watch?v=6Gc0ZgLD6a4
    Jun 20, 2012 - Uploaded by searspartsdirect
    Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
    Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
    Why does my washer stop half way through cycle - Ken
    Dec 18, 2015 | Washing Machines
    BEKO 6108 XE door does not lock and machine won't do anything
    might be a knackerd interlock on the door...
    cheers
    Mar 04, 2015 | Beko Washing Machines
    Washer still stops spinning at 7 minutes after clutch cleaning
    When you did your Clutch Maintenance how much rust was present on the One-Way Roller Clutches, the Spinner Shaft Coupler did you series use upper One-Way Roller Clutches bearing ring?
    How long ago was the Clutch maintenance performed
    Any error codes with the ""stopps spinning at 7 minutes""?
    What is the Series number of your FAV6800A?
    Did you ues this Clutch Fix post to clean up and check that the One-Way Roller clutches are locking up solid in the CCW/Spin direction for both the Clutch Pulley mounted One-Way Roller Clutches if you series machine uses the Upper Bearing Ring?
    If so then I would take that same wash load and run Quick Spin Test page 14 of the Service Manual. You may have to center the wash basket load (balance) before you start the test.
    Will the machine step thru the all the RPM rages from 90 RPM to 85. which = 850RPM.
    If not try the same test with out the load.
    Let's rule Outer Tub Bearing drag........Rich
    Jun 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
    LG WM2233H stop worrking in mid cycle, no displya
    This has happened to me when the power has gone out. It doesn't display anything and all you can do is restart the cycle.
    Jan 17, 2010 | LG WM2487H Front Load Washer
    Frigidaire GLTF2940ES Front Load Washer Logo
    158 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
