Question about Safe International Sentrysafe X055 Security Safe
Sentry override locked keys in safe then batteries died how cn i get in
4 Suggested Answers
tedatcit
  • 89 Answers
SOURCE: Need factory code for Sentry Safe A4887.Bought
for security reason ....only company can reset code.
Posted on Oct 23, 2010
sonaliasnani
SOURCE: i dont have the keys for godrej taurus safe locker and i forgot the lock code
Posted on Aug 07, 2012
kevkatsev
SOURCE: no override key to open the safe and need to change battery
is there a reset button in the sentry safe X055 that i could use to reset the password
Posted on Dec 19, 2012
How to open or override my 1960's sentry Combination safe
Your only solution if you can not find your owners manual it is posted in is to order keys and combination from the serial number on the safe or drill out the locks
Jan 06, 2013 | Sentry FIRE-SAFE Combination Safe DS3431,...
No override key to open the safe and need to change battery
Nov 15, 2012 | Safe International Sentrysafe X055...
Batterys are dead , how do i open it?
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Oct 18, 2012 | Sentry Security Safe with Electronic Lock...
What do you do if the batteries are dead in my Sentry fire safe and can't put code in ?
a1 locksmith advised me to To install batteries, remove cover between knob and keypad.Unlock door with the override key provided in the plastic bag attached to the owner's manual, and open the door using the knob. Remove battery cover located on the inside back of the door by sliding to the right. Insert the four batteries as indicated. Replace the battery cover.
Jul 23, 2012 | Sentry Security Safe with Electronic Lock...
Lost factory code
hi.
the factory code for sentry safes would normally be 00000.
if this does not work you may have to contact Sentry with the safe model and serial number .
these are normally found on a label on the back of the safe, or a label on the front edge of the safe.
contact details for sentry can be found on www.sentrysafe.co.uk
hope this helps
Mar 26, 2011 | Sentry Security Safe with Electronic Lock...
I lost my sentry safe code! what can i do to program the safe! can i do it without the code? please help! thanks
Depending on model, some safes have a key override that can be used to open the safe. Most models do not. Without a key override, probably the only thing you can do is to contact a lock smith, otherwise, start checking each possible code combination until you find the correct code.
If there are valuables in the safe, then take it to a locksmith. Otherwise, it might be cheaper to get another safe.
Jul 14, 2010 | Sentry Fireproof Safe
Yes the key pad has some of the numbers I use gone or not working properly ,can not get it to open , any suggestions Mike
Allot of electronic safes use override keys in case of dead batteries or malfunction. Just note the model # and serial # and call a good locksmith to pick the lock or fit a key
Feb 16, 2010 | Sentry Fireproof Safe
Have a Sentry V260 safe. The #1 button will not register when pressed. All other buttons register except for the #1. And the #1 button is in the combo. How else can I open it or how can I fix this button?
You can do a Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four-bitted key to the right.
5. Open the door.
You can download the user manual here:
http://www.sentrysafe.com/pdfs/OwnersManuals/172967.pdf
Dec 25, 2008 | Sentry Fireproof Safe
The number 1 button will not press
Key override
battery holder.
5. Open the door.
Dec 24, 2008 | Sentry Fireproof Safe
Small floor safe Sentry Model 3877 electronic lock and key
This manual will answer both of your questions.
http://www.sentrysafe.com/pdfs/OwnersManuals/501664.pdf
Feb 21, 2008 | Sentry Fireproof Safe
Safe International Sentrysafe X055 Security Safe Logo
63 people viewed this question
Top Safe International Home Security Experts
Computer Repairing
Computer Repairing
Theo Nikolaidis
Theo Nikolaidis
Are you a Safe International Home Security Expert? Answer questions, earn points and help others
