Question about InFocus IN2116 Projector 3000 Ansi WXGA 1280X800 Contrast ratio 21001 Dual Dsubinput Carry cas Projector Screen
How to open the infocus IN2116 projector ?
I was able to pull out the bulb assembly fine. But my color wheel has issues and I need to open the complete box of the projector. I have opened up all the screws, but I still cant pull it apart. I have tried hard and I see that at the top center near the button panel its attached to something, I cant see a screw or anything that can be removed. I am stuck. please help me.
shawninsari
  • 11 Answers
SOURCE: InFocus LP650 will not come on
Sounds like ballast unit, try avalontc.com
Posted on Aug 06, 2008
cammykins
  • 149 Answers
SOURCE: Infocus 4805 blinking red light problem
My first questions is:
Is this the first lamp you have placed into your Infocus pj? If not, did you reset the hours when you did it last time? Otherwise that can also confuse the projectors internal system thinking there is NOT a new lamp in there and there for make it stop working once the clock hours are expired and over the 3000-6000 suggested hour life.
Let me know so I can help trouble shoot other possible problems.
Posted on Oct 27, 2008
SOURCE: Infocus screenplay 4805 projector
check the wireing in the new bulb . My new one had the wires in the wrong holes like if there are 4 slots in the connector then my orignal was in slots 1 and 4 the new one was in slots 1 and 3 so I took the wire out and put it in the #4 slot and put it in and unpluged the machine and did a reset and restart and it came on green. Hope this helps.
Posted on Jan 28, 2009
  • 167 Answers
SOURCE: Color wheel in my InFocus ScreenPlay 4805 projector
The 4805 Color wheel part number is 525-0146-00
You can buy it from AV SOLUTIONS in NY
As far as if it's worth it... That's up to you.
Posted on Nov 29, 2009
projdoc
  • 2237 Answers
SOURCE: infocus lp790 projector repair center
check the infocus website, but chances are, you'll have to send it in to projector doctor.
Posted on Mar 09, 2010
I need a service manual for infocus 2100 series
Check their website. You may be able to find the instructions on there.
Mar 15, 2014 | InFocus IN2100 - IN2116 Multimedia...
Turns on for about 30 seconds and then turns off
You should check first the fw version. Tha last fw version is v 2.78.30. if the fw is updated it, check the power supply part number, must be P5E84-8101 because the P5E84-8100 have a problem. InFocus IN2116 Projector
Jan 02, 2014 | InFocus Corp. InFocus IN2116 DLP...
Just replaced burnt out bulb in Infocus 4805 projector. Great picture with new bulb but only black and white. Is this a bulb issue or something else in the projector?
This is most likely the color wheel. When the bulb blows, it can damage the color wheel. The color wheel is a wheel composed of thin layers of colored glass that spins in front of the projected image. It is possible to repair it with super glue, but the best way is to try to find a new one to buy.
Dec 29, 2010 | InFocus ScreenPlay 4805 Multimedia...
I have an infocus 4805 screenplay projector and i was using it when there was a pop and then i lost all color in my projector now its only black and white the bulb filter is clean what do i do.
Your projector is DLP technology. It employs a "color wheel" to provide colors other than blank/white. That "pop" you heard unfortunately may have been a malfunction of the color wheel mechanism, probably the motor. (It runs at very high RPM)
Sounds like you may have to find a shop to service your projector.
Aug 15, 2010 | InFocus ScreenPlay 4805 Multimedia...
Replaced bulb in infocus 777 and background is red not black
Its not the bulb. I have repaired a few of these with color issues. and its caused by short wires that nearly pull out of were there plugged in at. A big fail on the part of the manufacturer.
you have to open it up and check all the wire connectors. Even a plug thats slightly pulled out can cause issues.
Feb 12, 2009 | InFocus ScreenPlay 777 Multimedia...
Nov 07, 2008 | InFocus ScreenPlay 4805 Multimedia...
Color wheel
Bid on a used Infocus 4805 on Ebay...So far thet is the cheapest and best fix for a color wheel
Jul 22, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus 540 lamp didnt strike keep trying
if mains is ok and fan running ok, could be a bulb service issue, all lcd projectors have an internal lamp life counter which counts down and once the lamp has reached the end of its life it will not fire up and a new bulb will be required.
Dec 01, 2007 | InFocus LP 600 Multimedia Projector
Infocus SP4805 color wheel
The best I could do is a used one on ebay it closes in 1 day and 3 hours..1 bid at 299.00 you would have spare parts bulb etc this way. Best wishes Kevin
Here is the ebay
Item number: 110217533628
Sep 20, 2007 | InFocus ScreenPlay 4805 Multimedia...
InFocus IN2116 Projector 3000 Ansi WXGA 1280X800 Contrast ratio 21001 Dual Dsubinput Carry cas Projector Screen Logo
106 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
