Question about Belkin F5D7132 Repeater
Factory reset sitecom
I dont have software how to set up my repeater
I'm trying to reset my advent 01 series 321 laptop to factory settings i have windoes xp but i dont have a disk it's not the computer im on
When you start it, repeatedly press F10 and see if you get a recovery message then follow instructions.
Mar 18, 2014 | Advent Computers & Internet
I got a problem in connecting my samsung galaxy GT-7500 to sitecom extender 300N .. I have tried to change the IP address but it doesn't work with me . Any help plz?
Which modes are you trying to use this Sitecom? If you have the Sitecom as your Access Point (AP Mode), then you would need a LAN connection to your internet gateway (DSL, Cable Modem, etc). I didn't see any LAN hook up so I assume you are trying to use it as a wireless repeater. So you need to configure the unit differently. The 3rd mode is called Bridge mode. Again, you need to have a LAN hook up to your local network with a router or network switch.
Because your Tablet is connecting to the Sitecom okay, which mean that you either have the Sitecom setting for AP mode or Bridge mode. And the reason it didn't give you access to internet because there is no internet gateway connection to the Sitecom (LAN). I hope this answer your question (or confuse you totally).
Feb 15, 2013 | Computers & Internet
Can not access sitecom 300n with factory preset 192.168.0.234 or find trouble shoot in manual
open Network Connectdisable the wlan adapter first. open Network Connections from Control Panel and disable the wlan adapter first.Then Open Properties of the (wired) LocalArea Connection. Scroll down to TCP/IP and Change the Properties: IP=192.168.0.2 and Subnet Mask=255.255.255.0. Then connect the Sitecom using the wire (UTP). You should be able to browse with an internet browser to 192.168.0.234 now. After setting up the Sitecom disconnect the wire and enable the wlan adapter again.
May 15, 2010 | Computers & Internet
My Sitecom 300N repeater resularly loses its connection to my BT homehub. I think this is when the H homehub goes down sometimes. Resetting the Sitecom from scratch is a pain but resolves the problem. 3...
I also had this problem when the BTHomeHub goes down, power loss etc. I seem to have fixed the problem by changing the wireless config in the homehub to use a fixed channel, (the default is automatic which means it changes each time it restarts). This has been running trouble free for a couple of weeks through a number of power outages.
Can't help with Qs 2&3, get the same problems but less of an issue now that the thing works all the time.
May 16, 2010 | Computers & Internet
I selected an MAC adress in the software of my WL312Sitecom router.I guess the wrong one because now I can't access 192.168.0.1
Reset the router via the little hole in back/underneath. Then simply set it up again, properly. Below is a link for the manual it has a step by step walk through for setup to help you. www.sitecom.com/showdownload.php?id=3779
Mar 05, 2010 | Sitecom (WL -004) Wireless Adapter
I have a Sitecom WL330 wireless repeater
Hi I'm having the exact same problem with a Sitecom WL330 and a BT business hub. Just get unidentified network when trying to connect. Did you resolve your problem? and if so how?
Thanks
Jan 16, 2010 | Computers & Internet
Wireless extender
OK.
It's pretty easy:
1) turn on both devices
2) connect to sitecom device.
- you may have to manually set your IP address. (from network resources control panel, TCP/IP tab. Check the istructions, cause you have to choose an address in the same subnet of the sitecom range extender. I mean, the first three numbers must be the same, and the last number of the address must be different, between 3 and 255).
- now you can type the sitecom address into the address bar of your browser (allow pop ups from that address!). The defaut user name is admin, as well the default password.
3) Ok, now you're connected and you just have to set this way in the basic settings:
working mode: universal repeater
now click on site survey and remember the ssid of your main network, and the channel number.
channel: type the channel number of your network (IT MAY CHANGE WHEN YOU TURN OFF\ON THE ROUTER!! so you'll have to change it maybe every day..... **** sitecom device, I HATE IT)
ssid: the ssid of your main network.
4) click apply.
Of course if your WLAN is protected you must set the rigth password and encription algorithm...
Now it should work.. but remember, everyday you will have to change the channel, and sometimes ou will have to reset it, from he toolbo tab.
IT,S BETTER NOT TO BUY THIS DEVICE, cause even the latest firmware is not working properly.
Jul 13, 2008 | Computers & Internet
Problem with sitecom wl-130 connection
I think I have the solution: you have to click on the basic settings tab, then n "site survey" button, then (optional) on "refresh" button.
Now you will get the information about your network, and you just have to check the channel number of the signal from your main router. then you have to set that channel in the "channel" button of the basic settings tab. You also have to choose Universal repeater as working mode of the sitecom device, instead of Access Point.
Hope it helps.
By the way, all these settings should be automatic in such a device.... But this sitecom range extender is ****.
I suggest everybody is reading: DON,T BUY THIS ITEM!!!! Spend 10 bucks more and get a working one!!!
Jun 01, 2008 | Computers & Internet
Belkin F5D7132  Repeater Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
