Question about GE Microwave Ovens
How many watts does the GE Jes733WY001 have
Just want to know how many watts it has. Says nowhere on the unit itself.
My GE stainless steel 1100 watt microwave starts beeping out of the blue and the display panel shuts off and when I open the door it resets itself and then starts to beep when I close the door again.
Try removing the power cord for about a minute, push all the touch pad 'buttons' and then plug it back in. If this doesn't work it sounds like you may have a bad door interlock switch or a bad PCM .. Good luck !
Feb 11, 2015 | GE XL1800 1100 Watts Microwave Oven
The dial on our GE JVM1790WK01 microwave turns freely but does nothing. I checked the knob for damage, none found and the shaft turns freely with a slight bump as it goes around, but does nothing.
turntable problem? it's probably the motor itself. it's easily removed under the bottom panel. you'll need the pricey ge orig. part; as they use a odd 21volt motor. good luck.
Aug 06, 2011 | GE JVM1790 1000 Watts Convection /...
This microwave GE JES834 800 watts, turns on all by itself , and continmues to turn on
Hi.
Put a cup of water in the unit (if you haven't already). This will tell you if it's actually 'cooknig' or not....... Probably not..... A bad door switch can actually turn on/off lights and fans just from building vibration...... If it does heat the water, the magnetron has most likely been damaged from running empty (no load) and it's usually more cost effective to replace the unit.
Sep 11, 2009 | GE JES834 800 Watts Microwave Oven
Surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
Power level
The numbers DO NOT equal a certain power level Erin. They equal a percentage! This is very confusing. Even the factory reps. can't explain it adequately. I recently replaced my old 600 watt oven with a GE 1100 watt model. The 600 watt unit came with a great cookbook. (I searched the internet but couldn't find one for the GE oven and the factory was no help!) A chicken recipe in the 600 cookbook said cook on high for 30 minutes. Since 600 is approx. half of 1100, I cooked on high for 15 minutes. Result: Uncooked chicken...
The next time I cooked 30 minutes on 50% power (button 5) and It came out OK. I have since used 50% power with meats in cooking bags with good results. Remember to check for correct temp. with a meat thermometer when oven stops. Trial and error is your best test at this point I'm afraid. Also you may want to type "Microwave Conversion Chart" into your browser. You will get some additional information from this. But read carefully!
Ray
Nov 16, 2008 | GE XL1800 1100 Watts Microwave Oven
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Instruction manual
I have found that GE dosn't support their products very well. As a technician I have researched this as I also have a GE Microwave. Sadly there are no cookbooks for this unit either. I have found (don't hold me as an expert on this) that you can generally use your 600 or 700 watt recipes in the 1100 watt unit by using cooking level 5. (50%) Also type "Microwave conversions" in your browser for other ideas. Hope that helps.
Ray
Nov 13, 2008 | Microwave Ovens
Too HOT to touch
how old is this, check the intake and extract vents for obstructions
Aug 30, 2008 | GE JVM1790 1000 Watts Convection /...
No heat in GE XL1800 1100 Watts microwave
model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
Jun 21, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
116 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
