Question about Simplicity 9,500 BTU 3-in-1 Portable Air Conditioner SPAC9507
Mode button not working
Mode button not workgin
How do I get my Samsung fridge model #rs25hs5000bc off demo mode? I tried holding down energy saver and power freezer but doesn't work.
IT is three buttons not two. Cooling Off mode (also called Shop mode), is designed for use by retailers when they display refrigerators on the shop floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and the refrigerator and freezer do not get cold. To start Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button for 5 seconds during normal operation. The refrigerator chime sounds and O-FF appears on the display. To cancel Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button again for 5 seconds, until the chime sounds. Cooling Off mode is only available on refrigerators sold in the U.S. Instructions are on page 20=> HERE
APPLIANCE911
Apr 12, 2016 | Samsung Refrigerators
Adjust volume on bluetooth mini speaker PSNANO PS-38
Quoted from the instruction manual:
"+/>>'" In TF/Bluetooth mode when short press this button: next song; long press: Volume up. Don't work in AUX mode.
"'<<\-" In TF/Bluetooth mode when short press this button: previous song; long press: Volume down. Don't work in AUX mode.
">''" In TF mode, short press this button: Play/Pause; In Bluetooth mode, short press this button: Play/Pause/Answer/End/Cancel dial/Pair. In Bluetooth mode, double click: Last number redial; long press for 2 seconds: reject calls. In TF/AUX mode, press it will be TF card and AUX exchange.
Aug 04, 2013 | Lands Phones
Drivers
wifi aintina ko check kare
Jun 04, 2013 | i-mate Ultimate 8150 Smartphone
I have a Panasonic DMC-LX2 digital camera, I'm based in the UK. Has worked fine for a couple of years, but 2 weeks ago, when powered up, none of the buttons work. Screen is illuminated, lens emerges OK,...
I just got identical situation today, and I have no clue at all. However, I figure that the camera is actually working busy like someone is holding the "UP" button continuously. To see this, power on your camera at any mode except the "Scene mode". After it's on, turn the mode select knob to "Scene mode". I saw my camera menu flashing like crazy. When you press any button, the menu should stop running. But once you don't press the button, the menu start running again.
Please let me know if you have any update.
Sep 21, 2010 | Cameras
I have a dish network satellite dish and the remote control codes don't work for my sylvania lc320ss9 lcd tv. Are there any codes that will work?
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the TV Mode button on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Jul 04, 2010 | Sylvania LC320SS9 32 in. LCD TV
My tv its dont working whit dish network remote control
Jul 02, 2010 | Element Electronics FLX3210 32 in. LCD TV
Dish network code for a viore, volume/power not working
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Apr 05, 2010 | Toymax Viore 42 in. Plasma TV
Audio off
Stop buying those junk phones.
I brought one in lightinthebox.com and it was broken just in a couple of days. The saler refused to answer email, gave me a fake US phone number, then refused to replace it. Pirate products are everywhere in China and they are kept being out ported. However, Chinese are not able to make qualified things.
Apr 20, 2009 | Dual Electronics CECT P168 Cellular Phone
Need remote code for 22lv505 for dish network
Your code is 750....... Program the remote control in TV mode and then in VCR **repeating the steps** (or AUX - press 1 before entering the DVD code) mode.
How to program your dish network remote for your tv:
1. Use the device’s buttons or its remote control to turn on thedevice.
2. Press and hold the mode button for the device you want the remote to control, for about three seconds. When all the other mode buttons light up, let go of the mode button - that mode button should now be flashing. For example, hold the TV mode button for a TV until all of the other mode buttons light. When you let go, the TV mode light will flash.
3. Only for the AUX mode, Use a number button to enter 1 for a second VCR or DVD player
4. Use the number buttons to enter one of the device codes that I have given you.
5. Only for Limited Mode, Press 1.
Limited Mode- allow you to only use the remote to Power, Mute, and adjust Volume on your tv.
You cannot change the tv channel when the remote is in limited mode. You can only power on your
VCR in limited mode
****Note: Skip this step if you do not want to use Limited Mode.****
________________________________________________________________
6. Press the POUND (#) button. If you entered the code correctly, the mode button flashes three times.
7. Press the blank POWER button to test if the code works for the device. If it does, the device should turn off.
8. Turn the device back on and try some other buttons to make sure they work. Sometimes, the blank POWER button works when other buttons don’t. If the code works for other buttons
** Stop Here**
Let me know if this helps..
1388f48.jpg If I have helped you, dont forget to rate!!!
Jan 03, 2009 | Toshiba 22LV505 22 in. LCD TV
Dish Remote
I was given code numbers for the Olevia TV, 506 and 127....... they dont work for my 32" in my bedroom.
Nov 16, 2007 | Televison & Video
Simplicity 9,500 BTU 3-in-1 Portable Air Conditioner SPAC9507 Logo
22 people viewed this question
Top Simplicity Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Simplicity Heating and Cooling Expert? Answer questions, earn points and help others
