Question about Dewalt 20 V MAX* Lithium Ion 3/8 In. Impact Wrench Kit with Hog Ring Tool Only
My husband has a dewalt 20 v lithium ion drill HOw do i get the bit out to put in another one?
  • 193 Answers
SOURCE: dewalt DW988 drill chuck
lock the drill in a vise so you can work on it. Then try working a very small screw driver tip into the jaws as you at the same time back up the jaws. They may be jamed against each other.
Posted on Nov 22, 2008
rowdy45176
  • 2176 Answers
SOURCE: How to change the drill bit for a Dewalt DW995
That tool comes standard with a keyless chuck so all you should have to do is grip the collar and turn it to loosen bit. If it is stuck you might try a rag of some sort on the collar and use the motor to loosen it up. Let me know if you need more help.
Posted on Jun 23, 2009
  • 8 Answers
SOURCE: removing the dewalt DC925 'rohm' chuck
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
Posted on Dec 10, 2009
  • 382 Answers
SOURCE: Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Posted on Jan 06, 2010
Testimonial: "Thanks for your help! It looks like there is still some live left on the brushes...I guess I was just overly concerned! :)"
  • 885 Answers
SOURCE: broken dewalt battery 18v lithium ion
When a Dewalt charger is showing a fast blinking red light it means the battery is no longer chargeable. It may be because of a bad cell or short inside the battery. Whatever the reason the charger will not charge the battery and it needs to be replaced.
Posted on Jan 30, 2012
Battery compatibility : drill DCK277C2m and battery DCB205
No it only fits the models it is designed to fit. Go on eBay to check this.
Aug 22, 2017 | Dewalt Drills
Does somebody have a schematic of the PCB inside of Dewalt 18v lithium ion battery. In particular, the P/N of the power transistor. Thank You
You'll have to contact Dewalt for that info--this is a reach---also I was unaware that there was a circuit board inside a 18V lithium ion batt---GL
Dec 20, 2016 | Dewalt Drills
Drill tipped over on bench and ran battery completely dead. Put battery in charger and it does not even light up. Not charging?
I would suggest getting your battery tested at one of our Factory Service Centers. Please click the link provided and search using your zip/postal code or city and state. DEWALT com
Mar 07, 2015 | Dewalt 20v Max Cordless Lithium-ion...
I have a 20 volt dewalt lithium ion drill and the chuck will not release
have to wonder whixh it is header ists Craftsman then the question says dewalt.
Aug 15, 2014 | Craftsman 20 Volt Lithium Ion Kit Drill,...
I have 2 DeWalt Lithium-ion batteries Apprx. 4 years old, charged 3 times...won't charge now
Either bad batteries or a bad charger. You can use a multimeter to test for DC voltage output in the charger.
May 03, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
How do I remove the chuck of a DC910KL dewalt cordless drill?
you can go to my profile page and under tips there are detailed instructions for this. Let me know if you need more assistance.
Mar 09, 2011 | Dewalt DC910KL Heavy-Duty 1/2" 28V Nano...
Is the green light supposed to flash while charging lithium batteries> just got the p113 charger but no instructions in the dang box
I have used alot of battery type drills and other action tools . Ryobi is on the lower end of the market as opposed to Milwaulkee and Dewalt . But my experience with battery operated tool charging equipment is that if the light is green and it's blinking , I would say it's charging . When the light goes off or stays on . I would say it's charged . Leaving the battery or batteries in the charging unit for 24 hours will not hurt the battery . My solution here is put it in the charger , and check it 12 hours later !
Electrician by Trade
Feb 20, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
We are only managing to drill 4 x 6mm holes in paveing slabs, drill is 18v and only 1month old.
Ryobi is one of the cheapest drills. They are good for small projects. You need to upgrade to a better drill like milwalkie or Dewalt. Seems if you are drilling in concrete you need a corded hammerdrill. This will get the job done.
Dec 08, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Dewalt 20 V MAX* Lithium Ion 3/8 In. Impact Wrench Kit with Hog Ring Tool Only Logo
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
