Hi, I have a Bosch Wfb 2004. The door will not open after running a full cycle. I have taken the top lid off and tried fiddling with the latch mechanism; the horizontal white shaft inside the latch mechanism moves a couple of millimetres left to right but still holds the door latch. When this fault occurred the machine had earlier caused the fuse box to trip. How do i get this door open please?
  • Harvey Chuter May 06, 2013
    I have gave the door locking unit with the solonoid in a tap .the door opened straight away. The plunges must have been sticking. I remember doing similar on car starter motor solonoids.i may see if it comes apart to clean out any corrosion or goo .
    tap the door locking unit.free up the sticking solonoid
My whirlpool LHW0050PQ4 washer door is locked and unable to open, wash cycle is finished. Unplugged overnight and return next day, still locked. Any suggestions?
reset it
push sound for 10 secs
or
open top
spline screws top back
an reach down to the door latch
bottom of latch t is a small loop for your finger to pull/push it down
you can get to it same way from the bottom front cover
unplug unit
3 spline screws on bottom front washer cover
reach up an pull the loop on latch
good time to clean out the trap since your (t)here.
May 13, 2014 | Whirlpool Washing Machines
LD WD1238C Door is Locked shut tried every trick you can think of including giving it a little kick
often on the upper grade washing machines, the components are a little more sophisticated. Possibly once you have removed the top lid, you will see the door latch from the back. some of the latches have a drawstring that you can pull which mechanically releases the door and opens. If you are able to before getting into stripping the wachine, gie it a quick cycle run and let it complete the cycle, Then try and open it. go from there.
May 19, 2010 | LG WD-1280FHD Front Load Washer
Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
May 30, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
The Rinsing aid door keeps opening in my Bosch dishwaser
I believe paddy55 is correct about the rack position affecting the rinse agent door. When the top rack is moved to the higher position, the rack hits the latch on the rinse agent door, causing it to pop open.
Move the rack back to the lower position and see if the door stays closed.
Apr 06, 2008 | Dishwashers
Owners manual for washing machine
i am not able to open the front door of my BOSCH WFB 201 Wahing Machine, please help
Dec 09, 2007 | Washing Machines
Can't close Bosch Dishwasher door
I had same problem and was alarmed at the idea of taking the door apart, so I tried the 2 screwdriver option described below - it works!
Open door and get two small screwdirvers behind each side of the catch inside the top of the door and gently apply pressure. The catch should reset itself on 'open' and allow you to shut the door again.
Thanks to all for their postings and helpful advice!
Nov 10, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
