Question about Canon Office Equipment & Supplies
Canon pixma mg5200
Cannot print the magenta color. begins printing then fads out
  • Canon Master
  • 32,281 Answers
It appears the magenta cartridge has nearly run out.
Posted on May 06, 2013
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
SOURCE: Printer will not use the magenta color
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Posted on Oct 20, 2008
frcs68
  • 1605 Answers
SOURCE: canon Pixma 4500 when printing
the Magenta ink cartridge is leaking. replace with a new one.
clean the ink cradle before insert eh new one.
Posted on Nov 12, 2008
  • 4 Answers
SOURCE: canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Posted on Mar 06, 2009
  • 23 Answers
SOURCE: one color is not printing properly ( magenta )
use a qtip and clean teh wipeoff area where the cartridge goes...
that and clean all around where the stripe may develop...
Posted on Jul 29, 2009
My Canon Pixma MG5200 will not print E-MAILS or browser items
When you rightclick on the side you want to print, choose print and some times you have to chose printer.
Aug 10, 2014 | Canon Large Black Pixma Mg 5200 Compatible...
Canon mg5200 only prints photos
I have an MP540 and it says..."The PIXMA MP540 runs on five ink cartridges, with a photo black as well as a pigmented black for text printing" so it sounds like pigmented is for text and dye for pics. So maybe your default settings are showing high quality, photo or the paper type is causing the printer to select high quality...just a thought!
Parts Of BMW.
May 30, 2012 | Canon Large Black Pixma Mg 5200 Compatible...
* After refile ink yellow color does not print at all.(ip 2772) * How to setup CIS system for canon Pixma ip 2772. which contains PG810/CL811 cartridges ?
I refilled Canon cartridge CL-811. I filled all 3 colors. Magenta Cyan Yelloware flowing well,. Even if I wipe the cart on paper tissue, 3 colors are coming out (pink magenta and Yellow).but while printing yellow colour isnot printing,. Any idea how I can fix the problem?
Jan 20, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Color photos printing very faded
Some nozzles could be burned out on the printhead, and you need to make sure you have no photo inks installed where regular inks should be. Photo magenta prints much lighter than regular magenta.
Aug 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Magenta Ink Streaking
that printer color cartridge is a problem... buy a new one.... color ink
Jun 16, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printer not printing magenta
ok...try a test page first, with printer off the computer completely
and..check for newest printer drivers here
Mar 16, 2008 | Canon PIXMA MP130 All-In-One InkJet...
112 people viewed this question
old marine
old marine
