Question about Balance CP4401 PC Desktop
Need new power supply but having problems finding one.
I have a Balance CP4401 PC Desktop the cooling fan on the Power supply burnt up while I was away and now there is no power to the pc when I try to turn it on theres nothing. I unplugged it and plugged it back in but now all I get is a high pitched squeel. I want to buy a new power supply that will fit in the same case but am having trouble finding one. Could anyone tell me where to look or help me find one. If not a new power supply that would fit in the original case how about showing me a new tower case that I can transfer the mother board and every thing to and has a power supply that will work. I know you can buy barebone kits but I still don't know what kind of power supply I need that the bb kits come with. Johnathon
  • 883 Answers
Power supplies are available many places on the internet, especially on ebay. Try this search on ebay: power +supply +ATX +400W. This is for a 400 watt supply which should be sufficient.
Posted on Aug 10, 2007
SOURCE:
My cd tray broke on my desktop, where can I purchase a new cd drive for a cp4401 Balance
Hi adrake13600...
Any CD/DVD drive will fit in your computer...just make sure it is an IDE and NOT SATA connector for the computer hook up
Please take time to rate me
Sep 10, 2011 | Balance CP4401 PC Desktop
Balance CP4401 pc desktop how do I restore to factory settings?
at the post go into bios and press F9 or you can do a complete reload or recovery as new from comp or disc this will give factory settings.
hope this helps.
Apr 27, 2010 | Balance CP4401 PC Desktop
Type of memory for balance cp4401
Your computer holds a max of 2GB (1GB per slot) of DDR SDRAM, DDR333. Unbuffered, Unregistered.
Refer to:
Balance cp4401 Memory
Thanks for using Fixya.
Feb 10, 2010 | Balance CP4401 PC Desktop
Power down at anytime
That sounds heat related or possibly RAM. Open the side cover and check the CPU fan and heatsink for a dust buildup. You can clean it by gently blowing canned air on the fan and heatsink. While you have the cover off, re-seat the RAM modules. Make sure the PC is unplugged while you do this.
Good luck.
Mar 21, 2009 | Balance CP4401 PC Desktop
Balance Cp4401 Desktop
open the case you will find the power supply fan and/or the cpu fan is not working more than likely the power suply fan
Sep 30, 2008 | Balance CP4401 PC Desktop
Relay switch
Check your Power management settings - either through Control Panel in Windows or go into BIOS. Set for minium or Always on. That should sort your peoblem.
Cheers
Tim
Dec 13, 2007 | Balance CP4401 PC Desktop
Keep shutting off
Make sure that the power cable is seated in the slot properly as well as the wall receptacle.
If you have a spare power cable, try switching it and see if it makes a difference.
If this doesn't help, you'll need to go inside the computer and make sure all the cables from the power supply are seated properly. If the problem still exists, then you'll need a new power supply.
Nov 27, 2007 | Balance CP4401 PC Desktop
New Problem
The manual you need will be on the board manufacturers web page, howevr I will bet you have the case power switch and perhaps the reset switch on the wrong pins on the mother board. To check this, remove the switch leads from the mother board, then use a small screw driver and bridge the pins on the mother board a pair at a time. All of these leads plug on to the board in a line and not across the two lines of pins. when you get the mother board to fire up by this method geet a torch and look closely alongside the pins you will see the letters PWR SW or RS SW. It does not matter what polarity these two sets of leads are plugged onto both will work. The LED lights on the case front will only work if the polarity is correct but it will not do any harm if they are backwords. On the board you should se two sets of pins marked HDD and PWR these are the led light pins you will know you have them right when the usual red and green lights are working at the front of your tower. Regards mistyman
Aug 15, 2007 | Balance CP4401 PC Desktop
Balance CP4401 PC Desktop Logo
106 people viewed this question
Top Balance Computers & Internet Experts
Jaime Hernandez
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
