Cannot print magenta
All maintenance is complete and all cartrages are new
  • 32,281 Answers
Most likely the magenta print head nozzles are blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Posted on May 06, 2013
jackboy
  • 2985 Answers
SOURCE: Magenta does not print
Can you find the bits and piece to make a orubt head clearing pump like this illustration? If you can take the cartridsge out fit the pump and suck out any ink in the chamger. Then empty the pumt and fill with Windex or propanol alcohol dilute with distilled water to 10%[or windex] and pump this through back and forth untill it shoes clear- put the cart back and see what happens Also download this utility www.ssclg.com set it up for your printer Also take a look at www.fixyourownprinter.com
Posted on May 27, 2007
  • 23 Answers
SOURCE: one color is not printing properly ( magenta )
use a qtip and clean teh wipeoff area where the cartridge goes...
that and clean all around where the stripe may develop...
Posted on Jul 29, 2009
  • 73 Answers
SOURCE: replaced the magenta cartrage. arror check Ink
The Error "Check INK U140"
Causes : Possible causes are as follows :
* The ink tank may not be installed properly (The lamp on the ink tank is off).
Install the appropriate ink tank.
* The ink tank not be compatible with this machine. (The lamp on the ink tank is off).
Install the appropriate Ink tank.
The machine will not print of the wrong type of ink tank is used or if it is installed incorrectly.
Be sure to install the ink tanks in the proper order. The proper arrangement from the left to right is Black - (CLI-8BK), Black -(PGI-5BK), Yellow - (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Replacing Tanks
1) Ensure that the machine is on.
2) Raise the Scanning Unit (Printer Cover) until it stops.
The Paper Output tray will open automatically and the Print Holder moves to the center.
Impoprtant : If the Scanning Unit (PRinter Cover) is left open for more than 10 minutes, The Print Head Holder moves to the right. Close and reopen the Scanning Unit(Printer Cover) to return the Print Head Holder to the center.
3) OPen the Inner Cover.
4) Press the Open button to open the Paper Output tray if it does not open automatically and remove the ink tank whoe lamp is flashing red fast. Do not touch the Print Head Lock Lvever. Remove only the ink tank.
Important : * Handle the ink tanks carefully to avoid staining clothing or the surrounding area.
* Discard empty ink tanks according to the locakl laws and regulations regarding disposal of consumables.
Note : Be sure to replace ink tanks one by one when replacing more than one ink tank.
5) Prepare a replacement tank.
a) Remove the new tank ink from its packaging, then pull the orange tape so that the protective film does not remain on air hole. Then remove the film.
b) Remove the orange protective cap from the bottom of the ink tank and discard it.
6) Install the ink .
a) Install the ink tank into the Print Head.
b) Press on the Push button on the ink tank until the ink tank snaps firmly into place.
c) Ensure that the ink tank clicks into place and then its lamp lights red.
Important : Make sure to install all the ink tanks to enable printing. The machine cannot be used unless all the ink tanks are installed.
7) Close the Inner Cover.
Note: Ensure that the Inner Cover is closed, Printing will not occur if the Inner Cover is open.
Hope this help. PLease rate my response.
Thanks
have a good day.
Posted on Nov 27, 2009
SOURCE: will not print red, changed magenta cartrage still
I have the same problem, any luck?
Posted on Feb 02, 2010
tbreeze47
  • 3083 Answers
SOURCE: Magenta will not work after
The following web blog explains this problem, and the possible solutions:
http://www.askmehelpdesk.com/printers/brother-mfc240c-problems-after-refilling-cartridges-166407.html
Since you didn't mention if the cartridge was refilled or factory replacement, I will refer you to the blog for your options.
Good luck, and hope this helps.
Posted on Oct 15, 2010
Photos are coming out Orange
Clean your print head under the ink maintenance / cleaning. Then test print. All your colors should pass this test. Your magenta is not complete.
Nov 21, 2013 | Brother DCPJ315W AllInOne Inkjet Printer
Magenta cartrage is 25 % full but will not print
try printing the Supplies Status Page and the DEMO page. if no magenta on either page, then it sounds like the scanner assembly is dirty. this is the lowest position scanner; it can be partially seen from inside the cartridge cavity. Typically a 1-1/2 (ish) hour repair.
Dec 23, 2012 | HP LaserJet 2605dn Printer
I'm having a problem with the ink magenta on an IP4500 Canon Printer, it's not printing any magenta even with new cartridges and I've done all the maintenance checks!! Help!
there are small metal spring contacts between the cartridge holder and the cartridge itself, these send the signals to the print head via the cartridge holder. Over time, as a print cartridge moves from side to side during printing these flatten out and no longer come into contact with the cartridge. Find the contacts behind your magenta colour cartridge and re-tension the spring metal contacts so they once again contact the metal faces on the cartridge. They maybe hard to find as they will be in the place where the cartridge goes, use the flat copper faces on the cartridge to give you a clue as to the position of the contacts in the holder.
Apr 16, 2012 | Canon iP4500 Photo Printer
Will not print red, changed magenta cartrage still
I have the same problem. I also replaced the magenta cartridge. After extensive on line chat support with HP, it was determined to be a hardware problem, which they said they would fix for $299! Or "Trade Up" to a different LaserJet for $399, which is $50 more than it sells for with a rebate on their website. I am pursuing more options with their "Commercial Solutions Center" 1-800-HPINVENT (1-800-474-6836) This wasn't sucha great invention...
Jul 13, 2009 | HP LaserJet CM1017 MFP All-In-One Color...
I'm using an Epson 1400 for dye sublimation and have installed a bag feed system. The 1400 is alerting that the cartrages are not the correct cartrages for this printer and will not let me print. Is there...
Hi I know if you go into Start, Control Panel, printers & Faxes, epson 1400, right click printing preferences, maintenance, speed & progress, and click on Disable Epson Status Monitor - this stops the printer 'thinking' the cartridges are running out... Joy
Jul 01, 2009 | Epson Office Equipment & Supplies
Magenta not working when printing colors
try to wipe it in a wet cloth to remove the clogs on the nozzle that avoid it from jetting...load again your catridge on the carrier or cartridge holder....
and run maintenance page on it ...go to your printer panel and select maintenance and then select clean printhead..to print a maintenance page..or maybe your magenta has have a low ink condition..
thank you for using fixya..
good luck..
May 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Epson c84 ink cartrages
Hello Carla, can you manually clean the heads where the ink delivers the printer. Try using the printers own program first then do a manual clean with proper cleaning solution if this will not work.
Mar 10, 2008 | Epson Stylus C84 InkJet Printer
27 people viewed this question
k24674
jasbo
jasbo
