Question about Pool & Spa
Display code p=
I drained the tub to get ready for spring. Tub had been fine prior to me draining it... we used it all winter with no issues. The Pr (prome mode code) showed on display, then this p= code that flashes with the temp. (which is set to 102 but is flashing 85). The heater is obviously working a little cuz it's not 85 outside! Why won't it heat up completely and what does this code mean???
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
Make sure the spa is not on sleep mode "SLP" or economy mode "ECO". Without knowing what type of spa you have it's hard to diagnose but it's possible your pressure sensor or high limit sensor it temporarily out of balance. If that's the case, it will resolve itself. If the problem persists you have a faulty faulty pressure switch or sensor.
Posted on May 09, 2013
4 Suggested Answers
  • 990 Answers
SOURCE: Dream Maker Hot tub - Display is blank - no #'s - flashes 4 times
Hard to say without being there. Two things to check though. First be sure the new board is the correct one. Many times parts will change and replacements will have special instructions for retrofitting.
The other thing to check is be very sure the plug on the new board lines up with the receptor. On a multi pin plug if the pins don't line up you can get just the problem you describe. I hope this helps, sorry it can't be more.
Posted on Feb 28, 2010
heatman101
  • 43501 Answers
SOURCE: how do you winterize the
Take a look at this manual Pages 40 &41...
Part number 60 is a drain plug and it looks like there are two of them on the left side of the heater when you are facing the front...
removing these plugs should drain the heat exchanger...
That is for the LJ model... if you have the LD then go here for that manual
heatman101
Posted on Dec 26, 2010
njpoolboy
  • 3 Answers
SOURCE: Hot tub heats from 85 to 98, then E05 message. Max
Check the thermal regulator on the heater. It could be compromised. It's like a car's thermostat. If it allows too much water to bypass, the exhaust will get too hot and "voila" e05.
Posted on Sep 22, 2012
My whirlpool awo/d 4506 washing machine is not spinning
When a washer will not spin there are a few common problems and I'll go over the most I see. One, the drain pump is either clogged or the drain pump has failed. If the control senses water in the tub, the control will not allow the unit to spin. Two, worn out tub suspension springs or tub shocks. When the washer goes into spin, there is a lot of force involved and the springs and shocks absorbs these forces. Three, bad pressure sensor. This sensor tells the control how much water is in the tub and if the sensor is bad, the control thinks water is still in tub. Hopefully this can help solve your issue. Good Luck!
May 25, 2016 | Whirlpool Washing Machines
Tip
Hot Tub - Spring cleaning and Maintenance
Spring is a great time to change the water in your hot tub and clean or replace your hot tub filters. Drain and give your hot tub a good thorough cleaning to rid yourself of the winter season. Make sure that you clean your hot tub cover at the same time both the top and the underside. This will help the hot tub cover to last longer and perform better. Hot Tub Spring Cleaning Tips
on Mar 27, 2015 | Pool & Spa
Morgan hot tub
if no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
Jun 30, 2014 | Pool & Spa
Great lakes hot tub
Hi, I am not a hot tub expert and I don't know what PR status is or what PL on the display means . However I did a quick search for you and have a web address that might help you find a solution.
http://www.spacare.com/troubleshootingguideforspaandhottubs.aspx
Hope it helps you
Regards
Steve
Mar 27, 2014 | Garden
Have a terrible smell coming out of my tub drain
I hope you put trap back on,or you need to fill trap with water--that is the water seal for sewer gas
Jan 31, 2011 | Kohler 1107-R-0 ProFlex Bath Tub with...
Tub drain will not stay in up position
Hi it may well do clogged up in drain hole or it may have come loose inside try tighenting up
Dec 20, 2009 | Kohler Model 7202: Drain For PuristĀ® Baths...
Washes fine, drains, will not spin
Well, it sounds like the lid interlock switch is bad. This switch keeps the machine from spinning when the lid is raised. When the switch is bad the washer thinks the lid is up.
Yes, if you have reasonable skills & experience you can fix it yourself.
Look for a hole in the rim under the lid. The switch is under that hole.
May 02, 2009 | Washing Machines
Bath tub drain
You need to replace the overflow cover with the lever on it.You can replace the entire piece or just the faceplate.There is a spring on most of these that holds the lever in place when thrown and that is the piece that is broken causing your issue. Thanks for using Fix Ya.
Mar 02, 2009 | Delta T13420 Chrome Classic Single Handle...
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Pool & Spa Logo
46 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
