Cpu upgrade Best Possible CPU upgrade for this.
  • Computers & ... Master
  • 5,660 Answers
A) http://www.fixya.com/support/t18040647-cpu_upgrade
B) http://www.fixya.com/support/t18040647-cpu_upgrade
(Last time I looked, this was the world's largest product support website, and there ARE technicians from AROUND the world; on here!!!!!!!! Do we count as an 'IT techie'? ........Lol!)
In all three of your posts, not once has the laptop manufacturer name, and model number been stated.
Processor (CPU) support depends on;
A) What processor socket is on the motherboard?
B) What motherboard chipset does the motherboard use?
C) What is the processor that is installed now?
With these parameters known, THEN you can think about CPU (Processor) upgrade.
1) CPU (Processor) has to FIT, the processor socket being used.
THIS, is also IF the motherboard HAS a processor socket; and is NOT soldered directly to the motherboard.
2) The motherboard chipset supports the Processor (CPU)
It has to be known if the motherboard chipset will support, the CPU (Processor) that you want to upgrade to.
For older computers the motherboard chipset consists of;
A) Northbridge chip
2) Southbridge chip
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
With this technology the Northbridge chip, of the motherboard chipset; is what determines Processor (CPU) support.
Newer technology, such as used per se by the Intel Core i processors, does NOT use a Northbridge chip.
3) Looking at the existing Processor now, you can determine;
A) Voltage Range: What voltage range does the exisiting Processor use now?
Does the upgrade Processor also fall within this Voltage Range?
B) Core technology, and architecture:
Example:
Existing Processor uses the Conroe Core technology, and the 90nm architecture. (NanoMeter)
Does the upgrade Processor also use the same Core technology, and architecture?
If not is there a BIOS upgrade available?
(The motherboard chipset also comes into play again, here)
Enough of this generic prattle.........
Post the laptop manufacturer name, and model number.
Then I, or someone else can give you the facts; and not generic information.
Post back in a Comment.
Regards,
joecoolvette
http://www.hardwaresecrets.com/article/535
http://en.wikipedia.org/wiki/Northbridge_%28computing%29
Posted on May 06, 2013
Pyrhyc
  • 2028 Answers
SOURCE: Hp 530 notebook cpu upgrade
It's not posible to upgrade to a dual core, the motherboard is a different design. Keep in mind that the processor, motherboard and memory have a matched frequency. If the processor doesn't match the board then it won't recognize it. Since the board does recognize the T2300, it may be that you need to match the memory in order to get it to boot. Match the memory by going to patriotmem.com and entering the model that the T2300 came from, it will tell you the memory frequency. If the memory matches the processor simply will not work with that board.
Posted on Jun 25, 2008
SOURCE: Cpu upgrade for hp 530 laptop
the chip is soldered to the motherboard an i would not mess with that u will end up with a paper weight
Posted on Jul 18, 2008
  • 11 Answers
SOURCE: Upgrading cpu in IBM T30 laptop
1. You must have a processor compatible with motherboard, an Intel Pentium 4M 2.2GHz P/N 91P7209.
2. Download and read pages 81 to 86 and above from the Hardware Maintenance Manual:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-42308
3. Pay close attention to reinstall the fan assembly and apply thermal compound if necessary.
4. Re-assemble all the parts again by following the steps in reverse order of the manual.
NOTE: For future reference, your laptop will change to a 2366-FBx, M6x or 2367-FBx model depending on case.
Posted on May 04, 2009
madhatter639
  • 260 Answers
SOURCE: G35 CPU Upgrade
I haven't tried it myself, but supposedly you can do this. You will have to get a processor that will fit in the socket of your motherboard. I believe it's a Socket PGA 478m. If you're going to go thru with this then I hope you're a person who is confident in disassembling & reassembling your laptop. You don't want to end up with a paper weight when you're done. To be sure that you get a CPU that is compatible with the socket on the board, then I would suggest opening your laptop and taking a look at the CPU and Socket. The CPU socket should be labeled exactly what type it is. I would suggest not getting a CPU that is faster than 2.4 GHz. The faster the CPU the more heat will be generated and your heatsink and fan might not be able to wick away the heat fast enough to keep it from overheating.
Posted on Mar 13, 2010
Testimonial: "This is exactly what I was looking for. Thank you so much."
joelwilcox
  • 1274 Answers
SOURCE: CPU upgrade for ACER rs780hvf
you could upgrade to AMD PHENOM II X4 960T but you should probably try and overclock and save your money.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Posted on Apr 03, 2012
Hello, I'd like to know what compatible cpu upgrades are available for this laptop. Thanks
in laptop the only best way to upgrade is only the RAM/memory and hard drive/hard disk....because if you want to upgrade the cpu it self is not possible for the old laptop because of the new pin slot that is available in the market....and only the expert/certified technician can do this...
Sep 14, 2015 | Toshiba Satellite L645D-S4056 laptop
BEST GRAPHICS CARD FOR MS-6585
WHATS THE CPU AMD OR INTELL AND SERIES OF CPU? AMD USES ATI VIDEO CARD INTELL NVIDIA CARD. IF USEING THE NEW APU/CPU COMBO THAT AMD HAS PUT OUT YOU NEED A R-7 OR BETTER ATI VIDIO CARD
May 22, 2014 | ATI Computers & Internet
Is it possible to upgrade the OS on my E3300 Intel Celeron CPU
You can think in downloading a "cleaning" software like clean master and so.I don't recommend you any other OS since if XP is running slow, other ones wold probably run slow too.But my major advice, would be to upgrade your cpu.
Apr 12, 2017 | Computers & Internet
Upgrading the Cpu of a ASUS X54C-BBK21
If you google this, you'll see other people have upgraded to i5/i7, if you currently have a Core series processor with the correct socket, this page on the Asus site only shows the X54C going as high as an i3 but apparently it is possible to upgrade the CPU on certain versions of the X54C.Check this link http://community.spiceworks.com/topic/433227-asus-x54c-bbk9-upgrade-cpu-to-i5-i7
Dec 13, 2013 | ASUS X54C-BBK21 15.6 Laptop PDC 2.2GHz 8GB...
My friend have Gateway DX4800-05e computer. We wanted to upgrade CPU which was 2.5GHz (E5200) We bought same socket, same family cpu 3.2GHz. Now stupid Vista freezes as soon as you see desktop and you...
Well for one thing, just because it is the same family cpu doesn't mean it is compatible. Check the drivers for the processor and make sure you delete the one from your old cpu. The faster the cpu also drains more power from your power supply. I doubt its the problem but still could be possible. My best bet is to find the drivers for vista online, for the correct cpu. If problem still persists, try putting your old cpu back in and see if it still freezes.
May 12, 2011 | Computers & Internet
Upgrade CPU
about the only place you will find a 754 cpu is on ebay because they stoped makeing the 754 soc cpu years ago.You can get a good system at walmart for 300-500 dollars depending on what you wanted.
May 01, 2010 | Intel Motherboard
Gigabyte ga-81915 pmd motherboard/precott 3.6 cpu/upgrade cpu?
the best and cheapest up grade is RAM.
Make sure you have all the memory your machine can handle.
A quick look say it can handle Core™ 2 Extreme QX9770(3.2GHz,12 MB)
And it has a PCI-express slot so you have a big chiose of video cards.Are you using the machine for gaming?
Jan 10, 2010 | Intel Motherboard
Cpu upgrade
To upgrade the cpu, you will still need to use the same type of cpu. A socket 478 motherboard will not work with a socket 775 processor. The pin configuration is different.
Dec 21, 2007 | Toshiba Satellite A105-S4004 Notebook
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
