Dell inspirion 6000
Won't power up and cops lock
flashing
    New Friend:
    Problem Solver:
  • 7 Answers
Remove the battery and try another power adapter Dell inspirion 6000 - 4_21_2014_1_38_00_pm.jpg
Posted on Apr 21, 2014
nick_helpap
  • 334 Answers
SOURCE: Bios password locked
yes try flashing it see if that does it
Posted on Oct 13, 2008
shakeelm
  • 224 Answers
SOURCE: Dell inspirion 6000 is in a continuous reboot mode
I believe you can fix this problem without having to lose your files and also without having to reinstall your operating system.
In order to fix this issue you will need your windows XP cd.
Place the Windows XP cd into the optical drive and restart your machine. You need to boot from your Windows XP CD and at the prompt, press "R" for repair to get inot the Windows Console.
At that prompt, select 1 for your windows instalatin directory.
type "FIXMBR" at the prompt and restart your machine.
If this does not work, repeat the above process and instead of typing "FIXMBR", type "CHKDSK /R" and let it run to fix problems. It may take some time but once done, restart your machine and you should be back in action. Good luck...
Posted on Mar 08, 2009
PCTechOnline
  • 532 Answers
SOURCE: dell inspirion 1525 will not boot upon power
This is a Hard Drive error. If your unit is under one year old, you can get the drive replaced by Dell.
The drive can be accessed outside the laptop to retrieve the data, but it may fail all together very soon.
If you have no data on it, just get a new Hard drive installed. Dell should be able to replace the drive and start the system restore for you.
Posted on Mar 28, 2010
Testimonial: "thanks for help"
  • 2567 Answers
SOURCE: i have a dell inspirion 1545 the power light is
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Oct 07, 2010
  • 165 Answers
SOURCE: my dell inspirion 1525's screen is black numerical
Hi Friend, In this case if the caps lock is flashing blue and the other 2 LED's are solid blue, this is an indication that there is something wrong with the memory (RAM) itself.
So I would recommend you to please reseat the memory card of the system. I am also sending you the link that will assist you in reseating the memory
http://support.dell.com/support/edocs/systems/ins1525/en/SM/memory.htm#wp1180987
Please reseat the memories. Please let me know if it is of any help.
Posted on Dec 11, 2010
Dell inspirion 6000 is showing "loading PBR2.....done. NTLDR IS MISSING.HOW TO FIX
Use the Restoration Disk. When asked choose Repair.
(Non-Destructive Installation)
You are missing basic Windows files. Boot loader files.
Also you may have to prepare to replace the harddrive. May have bad Sectors on it.
Means I would copy off all personal information, after getting that laptop going again, or you may lose it.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/NTLDR
http://computer.howstuffworks.com/hard-disk.htm
http://computer.howstuffworks.com/hard-disk7.htm
Dec 19, 2012 | Dell Inspiron 6000 Notebook
How to get caps lock working on dell inspirion 580
The only thing you can try is get a can of compressed air, attach straw and blast under the Caps Lock key in hopes it is dirt buildup that can be removed, If there is no change the only option is replace the keyboard. Go to www.ebay.com Type make and model of laptop, refine search to keyboard.
May 27, 2012 | Dell Inspiron Computers & Internet
My CD/DVD drive won't read/play DVDs and it won't write DVDs either. It used to do this fine, but it doesn't anymore. It will still play and write CDs, but not DVDs. I have tried EVERYTHING to...
You probably will need to replace the optical drive (CD/DVD drive) in your laptop. Go to Google and search for "Dell Inspirion 6000 CD/DVD drive" to find a replacement.
To be sure it's the CD/DVD drive that's defective and not your operating system software, you could also try to boot from a boot-able DVD disk.
Jun 23, 2011 | Dell Inspiron 6000 Notebook
I just installed RAM into my dell inspirion 6000 and had the caps lock and mum lock lights flash then the computer shuts off. I read the manual and I did install the RAM properly (removing the battery...
Please provide everything on the sticker of the memory. When you bought the RAM, was it a pair or did you buy individual sticks? Your system can only support a maximum of 2 GB of PC5300 DDR2 RAM, split over two 1 GB sticks of RAM per slot. If you have tried exceeding this, it will not work, and even if it were to, it would eventually cause irreparable damage to your system.
Good Luck,
NOLA Tech
Jan 29, 2010 | Dell Inspiron 6000 Notebook
Dell inspirion 6000 a green light flashes and it does not turn on
It's either:
the lcd
video (GPU)
motherboard
lcd cable.
It's really hard to say without being there in person. I'd recommend having a local tech check it out.
Jun 15, 2009 | Dell Inspiron 8000 Notebook
Dell Inspirion not recognizing both memory slots
MAKE SURE BOTH SLOTS ARE ENABLED. ALSO MAKE SURE THERE IS NO CONFLICT FOR THEM IN DEVICE MANAGER
Dec 10, 2008 | Dell Inspiron 6000 Notebook
Oct 13, 2008 | Dell Inspiron 6000 Notebook
Inspiron 6000
Your instalation is screwed. Get the original disks that came with the laptop and reinstall everything and you should be good to go. Dont forget to change the bios settings to boot from cdrom/dvdrom first so as when you power up, it loads from the cd, not the hard drive.
Sep 18, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
