Question about HP Pavilion Computers & Internet
Hp pavillion zv6233nr
I have a problem with my laptop, it turns off after about 30 minutes of use with the power cord attached, I use the ac cord because of a dead battery.....what could be causing this?
  • HP Master
  • 32,281 Answers
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Rechargeable batteries will fail if stored in a discharged state for long periods.
Posted on May 06, 2013
kjanx
  • 194 Answers
SOURCE: HP Pavillion ze1000 laptop will not power up
that could be one of many problems. bad power supply, loose power connector, zapped motherboard. that model as i recall, had those problems,
Posted on Feb 02, 2008
myob247
  • 1342 Answers
SOURCE: HP Pavilion ze2000
Seems to be a common problem with this laptop.
Read other users comments Here
Posted on Apr 20, 2008
  • 334 Answers
SOURCE: HP Pavillion dv2500 laptop won't turn on
Kinda strange. Not turning on indicates a hardware problem, you made software changes. If the software changes caused a problem, it would start, just not boot to windows. I would first tryy to reset the laptop. Unplug it and remove the battery, hold down the power button for 60 seconds, then try again. If still no go, start removing hardware one at a time, hard drive, rem, wireless card, dvd rom. You may have a bad hard drive. Your pc should boot to bios if there is no hard drive installed. If that happens, run a diagnostic on your hard drive from your bios. Let me know if you need anything else.
seth
Posted on Jul 29, 2009
  • 12 Answers
SOURCE: HP Pavillion HDX 9000- No Power
Sandytoo,
Sometimes the AC port on the motherboard can become loose or disconnected and will cause the powercord to not charge to the batteries or run power to the motherboard. If you changed out the Power adapter and that didn't help, then this would be my best assumption. The AC connection on the motherboard can be replaced pretty easy by someone knowledgable in motherboard repair with sodering. Most of the time with this issue, a motherboard replacement is not required, Even though its alot easier to just replace the board. Most Repair places will probably talk you into replacing the board, even though its really not necessary, with this issue.
Posted on Sep 22, 2009
parrotheadpc
  • 2600 Answers
SOURCE: the PC doesn't start. led is not blue when power cord plugged
Below is a link to the service and maintenance guide. This will serve as a reference for disassembly. It is free to use, copy and print. It is in PDF format. I would check the voltage at the tip of the adapter to make sure it is putting out the proper voltage. I have seen plenty if failures with the HP laptops at the DC jack area, in most cases these jacks are connected to the motherboard by a cable and plug, which makes them easier to service than the soldered type. Here is your guide........
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01550099/c01550099.pdf
Posted on Jan 13, 2010
I have an HP Pavillion dv9000. I RARELY use it, but my screen is blank. The power and lcd lights come on, but the screen is blank. I've taken the battery out, connected the power cord and turned the...
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Test with an external monitor attached to the laptop. If you get display on the external monitor, then this confirms the case.
Aug 21, 2010 | HP Pavilion dv9000z Notebook
My hp pavillion was no power, please give an advise.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
To verify this, unplug your laptop & try to run it on battery only. Watch out how long it will stay on (if at all). If it didn't work on battery alone, or worked but for a very short time, then your battery is defective.
Apr 19, 2010 | HP Pavilion dv1000 Notebook
seth
Jul 29, 2009 | HP Pavilion dv2610us Notebook
HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Jun 01, 2009 | HP Pavilion dv9700t Notebook PC
H P Pavillion dv 9700, problem : screen is black like in sleep mode. I shut off, removed battery reinstalled battery, turned back on could hear the windows sound coming on but screen is still...
Try this -- it is called a Power Drain Procedure -- HP technical support helped me with this --
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Jul 08, 2008 | Computers & Internet
Ac cord
And the problem is??
If nothing else, go to ebay. cheap prices, plenty to choose from.
If money doesn't matter and you're in a hurry, purchase a high quality "universal" power adapter, such as ICE. Make sure it carries 90 watts and can handle the appropriate amperage.
Good luck
Feb 08, 2008 | HP Pavillion ZV6000 Notebook
Charging issues
if you can get a hold of a 12 volt cigarrette lighter car power cord, try and see if the lapper starts then,
if it does, then the power adapter maybe bad
Feb 02, 2008 | HP Pavillion ZV6000 Notebook
Feb 02, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
