Question about Orbit Watermaster 6 Station Dual Program Sprinkler Timer 57196
Watermaster 57161 how to replace bad solenoid
Orbit 57161 water sprinkler
follow directions battery is installed first. if nothing lights up the unit may defective, transformer is faulty or wired incorrectly.
Controller will not power up:
1.
Fuse has been blown.
2.
Transformer not plugged into an operational
AC outlet
Mar 29, 2018 | Water Computers & Internet
Need Instructions for Watermaster Model 57090
Try Googling (watermaster)(57090)(manual) without parens.
Aug 17, 2017 | Hardware & Accessories
When i turn the system to run hear a click in the pump relay but system does not come on
Turning the dial to run should not send any electrical current anywhere it simply is set to come on at the scheduled time. If your turning the dial to run and attempting to start the valve manually and a click the pump or valve solenoid clicks, the flow control may be closed, the water is off or the valve has failed to open. Try opening the bleeder screw to see if the valve opens this way. If so, try replacing the solenoid if no, replace the valve.
Aug 29, 2013 | Orbit Irrigation 57009 WaterMaster Pump...
I have a watermaster timer and the fuse keeps blowing. It's kept indoor so it's not getting wet. What would you recommend checking?
Watermaster timer has 24V AC transformer that plugs into outlet.
I don't know if the transformer is causing problem, or is circuit has a problem.
1) Use cheap circuit analyzer from home center to check outlet for problems.
2) If possible, replace Watermaster transformer with 24V AC transformer available from home center doorbell section.
3) Move transformer to another outlet and see if problem persists.
4) Actions above can give some indication if transformer or circuit are causing problem. If circuit is suspect, move wire to another circuit breaker, and/or replace circuit breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Apr 14, 2011 | Hardware & Accessories
I have a Orbit 57161 Sprinkler System 6-Station Standard Indoor Mounted Control Timer with rainbird sprinklers the issue that I have is the sprinklers stay on and don;t turn off.what do i do?
Manual:
http://www.orbitonline.com/lib/media/57114-14%20rF_Eng.pdf
Website:
http://www.orbitonline.com/products/Timers/02/01/19/671/
Tech service 1-800-488-6156
Timer has 4 year warranty
The manual has troubleshooting
Looking through the manual I can see potential trouble areas:
-Water pressure too high > 60 psi is ordinary household pressure > order Brady BTG pressure gauge that connects to hose
-Overlapping times are 'stacked' by timer ... but 'more than one start time' is listed as cause of stations turning on when not supposed to >> reset and re-program timer, make chart of on-off times
-Weak or missing AA batteries >> clean terminal inside timer and replace batteries
-Hard water deposits or unfiltered water clogging water valve (water softeners frequently have this problem) >>> see if vinegar or CLR cleaner can help flush water valve >>> add sediment filter in front of timer
-Fuse blown
-Bad solenoid
-A combination of problems listed above with sediment -or- solenoid as main suspects
Oct 04, 2010 | Orbit Sprinkler System Power Source...
Looking for manual Orbit Watermaster 57012 Controller.
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57004-57006-57008-57012-before-2002-Sprinkler-Controller-Owners-Manual.pdf
Jan 10, 2010 | MicroBoards Orbit (ORB-4201-01) Burner
Off power Orbit watermaster 57196
I am having the same problem, did anyone find the solution to ths?
Jul 07, 2009 | Garden
Orbit Watermaster 6 Station Dual Program Sprinkler Timer 57196 Logo
20 people viewed this question
Top Orbit Video Cameras Experts
richie46
Tom Chichester
Tony Parsons
Tony Parsons
Are you an Orbit Video Camera Expert? Answer questions, earn points and help others
