Question about Sharp CV-P10NC Portable Air Conditioner, 10,000 BTU/hr. at ASHRAE 128 Standard BTU output, 10.0 EER, 12-Hour timer, Reusable slide-out filters, Library Quiet, 4 - Way Air direction, 280 / 260 / 200 / 150 CFM, 2.5 - 60 pints/24 hours Moisture removal CV P10
How to drain Sharp Portable AC
So it's time to break out the AC this year. I decided to drain it for the first time since I bought it last year. In the manual it says to press the power button twice. When I press it twice, the unit turns on and then off. Nothing after that. Can someone tell me what I'm doing wrong? I've done a reset with the unplug, hold power button, plug in process. But it still does not drain. Thanks for any information or suggestions.
  • 33 Answers
SOURCE: LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
Posted on Dec 12, 2008
  • 6 Answers
SOURCE: Sharp Aquos 32 wont turn on
I called up Sharp, and if you are a part of Sharp AQUOS Advantage Program you get free in home service.
They were very nice about it, and I already have a technician coming to my house on Saturday and I called on Wednesday.
I doubt Sharp's policy alot less now!
Posted on Sep 03, 2009
  • 674 Answers
SOURCE: Sharp AF-S125FX air conditionaer doesn't work when I plug it in
Sounds like there is something grounded inside the A/C unit or a fan or the compressor locked up. Could also be a motor winding in the compressor or one of the fans shorted thru.
Posted on May 02, 2010
SOURCE: Hi I have a sharp portable AC unit model CVp 10lc works for 1hour
I have the same problem. I have only used my unit 3 times. It keeps "triping" and shuts off. Also, I smell a plastic burning smell and the plug gets very hot.
Posted on Jun 14, 2010
caroldon
  • 17129 Answers
SOURCE: I have a Sharp model
please check the relay of the comppressor and also the capacitor of the compressor. Check also if there is any issues in the controller section that can bring in the errors.
open and tigten all connectors, take a test on relays to manually switch on fan and compressor to confirm their worrking. the check for the micro controller's functiioning.
Posted on Sep 02, 2010
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Jul 24, 2013 | Haier CPN12XH9 Portable Air Conditioner
Melnor water timer
Melnor is major water timer company, and not off-brand. However, water timers last a couple years, or less, sometimes they last long time but that is not often.
If not drained completely of water, they will break when water freezes.
Copy following link to identify all water timers on market today:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Most timers have 1 year limited warranty for defects in workmanship.
Jun 05, 2013 | Hardware & Accessories
1999 Ford Ranger AC low side pressure reads 100 psi
Was the a/c compressor running when you got this reading?
Feb 03, 2012 | Ford Ranger Cars & Trucks
Danby Portable A/C Model DPAC 11007, purchased Costco May 19, 2007. Platinum Warranty. For the first few years A/C( only) operating it was not necessary (or rarely) to empty the external tank Then last ...
Eugene, first, let me say, yours is one of the best narratives, of what is happening with your ,that I have read in a long time. You didn't leave me guessing as to what was going on.
I believe one of the problems is that you may be operating the AC Cooling & the Dehumidifier at the same time. If this is the case, the dehumidifier is generating heat, when it's operating and the AC cooling side is working at a lower rate, because the dehumidifier is in operation. Discontinue the use of the dehumidifier on extremely hot days and use only the AC Cooling mode. The AC mode also acts somewhat as a dehumidifier. That's why draining the water tank is required for AC mode too.
I would also be prudent to check the exhaust hoses to make sure they are not clogged or have been bent out of shape. Keeping the air intake filter clean is really important, too.
Aside from the air conditioner, other things can be done to help cool the room. Close all drapes or blinds to block the sun from directly heating the room. This is especially true, if the AC unit is sitting in direct sunlight. If you have a ceiling fan, operate it it as fast as you can stand, in a Clockwise direction. This not only keeps air moving, it also helps the AC unit and creates a windchill, that fools your body into thinking it's cooler than it really is. Personally, I have been doing this for years and have saved a ton of money on electric bills during the summer.
I hope I have been able to help you and thanks for choosing FixYa.
Jul 25, 2011 | Heating & Cooling
I bought an amcor 12,000 BTU portable AC two years ago. I used it for a month, never used it last year, and then tried to use it yesterday and it is dead. As in, there's no response when I push any...
When a sett is kep unused for sometime the possibility of faults can vary as when it is in regular use.The best way for a first hand info is to trace the line of power fromthe controller unit to the compressor.Check the line to the compressor, if the control panel is faulty, check compressor relay, check capacitor.
Since it is failure of power, it can also be a wire break.
Sep 01, 2010 | Amcor ALTL-12000E Portable Air Conditioner
This is a stand alone portable 10,000 sharp portable AC
I had the same issue of filling up after a couple hours but mine started making some pretty loud noises as well just before shutting itself down and lighting all three lights. The top drain valve would no longer work and the only way I could drain it was through the bottom (gravity) drain valve. I took the unit apart and found that the simple water pump that is used for draining and the evaporating process had lost the thin filter screen on the bottom and the screen became lodged in the impeller of the pump preventing it from spinning. I removed the worn and broken plastic screen, carefully pushed the impeller back up on the shaft until it bottomed out, and cleaned all the built up sediment off the entire pump. After reassembling everything, the ac unit runs like new again and the noise is completely gone. Cost? $0
I imagine you can just order a new pump from sharp and save the time and effort of cleaning the pump.
Hope this helps!
Jul 27, 2009 | Sharp Heating & Cooling
Portable Air Conditioning unit no longer blows out cold air
Bit late I know, but for others having same issue, ensure that it doesn't need draining - use black tube at bottom left when viewed from behind to drain any excess water.
Jul 01, 2009 | Heating & Cooling
Missing window vent kit
parts@windchaserproducts.com contac them to get a replacement or go on their website to get their contact phone number. http://www.windchaserproducts.com
Jun 01, 2009 | Windchaser PACR90 Portable Air Conditioner
Sharp CV-P10NC Portable Air Conditioner, 10,000 BTU/hr. at ASHRAE 128 Standard BTU output, 10.0 EER, 12-Hour timer, Reusable slide-out filters, Library Quiet, 4 - Way Air direction, 280 / 260 / 200 / 150 CFM, 2.5 - 60 pints/24 hours Moisture removal CV P10 Logo
187 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
