Question about Electronics - Others
Battery Kids' four wheeler battery keeps blowing fuse.
    Top Expert:
  • Electronics ... Master
  • 49,277 Answers
Check for dead short/broken wire touching the earth somewhere.
Posted on May 05, 2013
  • 1 more comment
  • Isaac Allen May 06, 2013
    I checked all wires no broken wires anywhere.
  • Bill Boyd May 06, 2013
    Batteries do not blow fuses. It is the current flowing directly to earth that does that. Check the motor is OK. Check that you have connected the battery correctly. Check that the speed control is not faulty.
    Ok I\'ll check that stuff but I had the battery disconnected sitting in bench and put the fuse in and it blew it. It was put in the right way also, so I\'ll have to check the things you recommended then, thanks,
My 06 Kawasaki 4 wheeler. Backfires when light switch is on going down highway. Is it battery related ?
Problem with Brute Force, please save my 4-wheeler from shop ...
www.kawieriders.com > ... > Kawasaki Brute Force/Prairie/Bayou
Nov 16, 2011 - Problem with Brute Force, please save my 4-wheeler from shop! ....2007 kawasaki 750 4 wheeler backfire problem ... should I save for my brute force 750? moe, Kawasaki Brute Force/Prairie/Bayou, 3, 10-18-2010 06:55 PM. Backfire thru exhaust
Feb 24, 2011
Low RPM Backfire Through Carb
May 24, 2010
four wheeler keeps backfiring
May 9, 2010
06 brute force 750 poping and backfire
Feb 18, 2010
More results from www.kawieriders.com
Oct 08, 2015 | kawasaki Motorcycles
Wont start or stay running unless battery charger is on it
some four wheelers require a battery to run correctly. sounds like you need a new one.
Mar 26, 2014 | ATVs
Peg perego 4 wheeler
is it a 12v or 6v four wheeler?
Jun 27, 2013 | Toys
The 30 amp fuse on my bikes solenoid keeps blowing
Hi you have a grounded wire remove the fuse use a ohm meter or battery powered test light test the outgoing lead and to the frame if it lights up or registers on the meter backtract to see if the wire is grounded insulation worn off or pinched on the frame.
Jan 10, 2013 | Honda Deauville NTV 650 Motorcycles
2005 Ford Excursion V10 keeps blowing starter fuse
How is the cable that goes from the battery to the starter?it's the positive cable.Check the part also that connects to the battery.
Aug 01, 2017 | Cars & Trucks
2007 arctic cat 650-H1 and the speedometer doesn't work, it keeps flashing volts. We replaced the battery & checked all fuses, what else could be causing it to malfunction
get a polaris battery or the largest possible battery to fit battery compartment or re locate battery box and install a lawn tractor battery
Feb 28, 2011 | RTO 200cc Full Size Four Wheeler ATV
My son has a 700 twin sportsman peg-perego four wheeler. Weve charged thae battery . But when we hook it up the four wheeler will only go really slow as if the battery is dying or dead. Does it need a new...
check the battery with a multimeter and see if its showing 12 volts or more, if it is showing volts but not 12 or more then put it on the charger for about 8 hours, then check the battery again if it still hasn't went up check the voltage of the charger with the multimeter and make sure that the charger is putting out 13.8 volts or more, iif it isn't then you need a new charger, if it is then you need a new battery
Nov 30, 2010 | Peg Perego 12v Battery
My kids 110cc 4-wheeler won't start. I put a new
did you check the coil for the spark plug, its obviously wiring somewhere, i say replace it all, its cheap to do that, and saves time fighting it
Feb 11, 2010 | RTO 110cc Basic Manual ATV # ATD-125C
Electronics - Others Logo
313 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
