Question about Dodge Vehicle Parts & Accessories
Dodge remote start
Installed remote starter. Dont have a spare key yet so i did not hook up the bypass module.. Now my truck will not crank and someone said it went to theft mode and locked up. How do i reset the truck to use with out the remote starter till i get the key??? HELP PLEASE!!!
    Problem Solver:
  • 18 Answers
Something is not connected right. The alarm should not inhibit normal day to day use of your transponder key. Recheck connections and be sure no factory connections are loose.
Posted on Nov 23, 2014
5 Suggested Answers
  • 2926 Answers
SOURCE: This was installed in a
The condition you are having is due to a programming issue. When the dealer replaced the instrument cluster, they also disconnected battery power to the vehicle (or at least they better have)
and when the battery power was disconnected, then re-connected after the cluster replacement was completed, your after market remote start was affected. I tried to find a simple solution for you, but there were a lot of gray areas online. What I did find was a number you can call to rectify this problem. There is a procedure you can perform yourself, but it is not exactly clear unless you call the manufacture (that is the low side of aftermarket devices). The number is 1-800-753-0600. This is a support number, and have the model number ready and vehicle info ready when you call.
Posted on Dec 18, 2010
logosc75
  • 625 Answers
SOURCE: i just installed a remote starter on a 1997 chevy
You installed this unit yourself, correct? You mentioned the bypass unit but not the remote starter unit. First, are all of the car's power wires connected...ignition(pink), 2nd ignition(green or white), accessory(orange)? There is a brown but it is radio accessory and not necessary for remote starter installation. Second, make sure that the ground for the XK06 is connected to the pass lock ground wire(black or orange with black) and not chassis ground. Next, check the ground when running(GWR, brown) from the XK06...make sure that it is connected to the remote starters ground when running. Now, it CANNOT be connected during programming, so make sure that you connected it AFTER you programmed the module. You didn't mention the remote starter unit but this wire is blue/white for Directed, light blue for Prestige and blue with black for some Code. Next, make sure that the ignition and starter wires of the XK06 are properly connected to the vehicle or remote starter's ignition and starter wires. You stated that the remote starter starts when you turn the key to accessory on...what about with just putting the key in the ignition(withoput turning the key)?
Posted on Jan 10, 2011
slick42371
  • 42 Answers
SOURCE: car starts then stalls I have installed a Pretige
You have the wrong bypass. The bypass you are using is for universal transponders. You need the Passlock 2 bypass. The passlock is a resistance that is read from your ignition cylinder by the bcm that will allow your truck to start.
Posted on Feb 02, 2011
logosc75
  • 625 Answers
SOURCE: I installed prostart remote starter in 2002 Sonoma,used xpresskit bypass module to bypass passlock 2, truck started with remote ,now won;t start with remote,have to reset and start with truck key
If you are sure that everything is connected properly, then the only explanation could the ground when running from the remote starter to the bypass. If you are using data to data(D2D), switch over to wire to wire. Test the ground when running connection from the remote starter (white) to the ground when running connection of the Xpresskit (blue). You could even go so far as to connect the ground when running of the bypass to constant ground for the test. You CANNOT leave this wire connected to chassis ground.
Also, that vehicle has a second ignition wire(white) that MUST BE power up for remote start. If not, it will trigger the check engine light.
Posted on Oct 02, 2012
Where in halifax nova scotia can i find someone to check my cool start remote
You did not mention the details of your vehicle but the most likely cause is not having a bypass module installed with the remote starter. The reason you may need a bypass module is to replicate the function of the chip that is imbedded in your key.
Jan 14, 2013 | 2-Way Remote Starter
Oct 01, 2012 | Vehicle Parts & Accessories
Transponder for 2006 mitsubishi eclipse for remote starter
Yes, There are two Immobilizer bypass modules on the market that will work with your vehicle without having to sacrifice a key. Xpresskit offers the DBALL and PK9. Both require programming to function properly.
Sep 08, 2012 | Remote Starter with Keyless Entry
Last Year I installed an AVITAL5103 Remote start & Security on My 2002 DODGE RAM 1500 Q.Cab.Everything was working fine,util I instal a new car battery.When I attempt to remote stert ,the starter cra
There are two types of starters for Dodge, if you installed new battery, check to see if the remote start is to ignition module or starter solenoid, then make sure the circuit has not been closed-they go in series circuit!
Nov 29, 2011 | 5103L Security/Remote Start System
I just recently purchased a 1996 cadillac el dorado etc. it starts then shuts right off. i dont know if it is something wrong with the anti theft system. maybe the keys. i need to know how to check this. i...
Heres the deal. When you put a remote starter on this year Cadillac (and about 100 other GM models) you have to bypass the security system. On these vehicles, that chip in your key has to communicate with the ignition/lock cylinder and then the TDM (computer) to allow your starter to start and/or allow the injectors to continue working. So what people will do is "bypass" the key and lock cylinder to fake the TDM into believing it has the correct key chip inserted. This allows you to remotely start a vehicle with an antitheft. My guess is that your TDM has now failed. Since the remote starter (which is hooked directly to starter) works and the key doesnt AND we already know that the system has been altered.... I'd put money on the TDM (theft deterrant module). Check out this link. You'll find an answer to your problem for sure. http://vatspasslockpasskeysecurityhelp.yolasite.com/
Apr 14, 2011 | 1996 Cadillac Eldorado
Avital 4100 remote start in 2000 pathfinder. worked fine. went to dealer for recall of fuel filler tube. while there had new key cut and programmed. the next morning the battery was dead. after jumping the...
if your key has a blue square where the metal meets the plastic on the key, you will need to reprogram the data module used to bypass the theft system, or remove the spare key that is installed and have the dealer reprogram it
Aug 09, 2010 | Nissan Vehicle Parts & Accessories
No start cranks but does not fire has spark. has fuel if bypassed by relay fuses good new fuel pump a year ago has fuel replaced battery froze, has prostart remote start, been in 8 years no issues 2000...
check to see if the security light or anti theft light flashes. if that is the case, sounds like the bypass for the remote starter may be causeing the no start by tripping the anti theft system. Remove remote starter and bypass system and join any cut wires back together that may be cut for remote starter. Try starting, if theft light still flashes leave key in the on position after attempted start for 15 minutes till theft light goes solid, turn off and try again. Repeat process for three times to re-learn factory theft system in vehicle. If problem still persists, then take to your local dealer to reprogram factory theft module in the cluster.
May 31, 2010 | 2000 Chevrolet Cavalier
My viper remote starter cranks engine but car doesnt start. Seems like strater does not crank long enough. Then it re-tries but never starts the car (Grand AM)
Did you connect the tach wire of the unit to your car? if not you need to refer to your documentation to turn on or off the tachless operation for the unit to work correctly.
Jan 12, 2010 | Remote Start System
1997 gmc truck remote start system not letting truck start with in ,i un plug and it fires right back up,if i plug remote start in it wont start with key but will with remote ,i unplug remote key will...
IF ENGINE CRANKS BUT NOT START -, sounds like a short in the tach wire, plug remote starter in and cut the tach wire to the engine for the remote starter. if the truck starts then you remote starter module is faulty.
IF ENGINE WON'T KRANK -, then there is a starter kill hooked in with it. if you bypass this you should be fine. just follow yellow wire from ignition switch till you find where it is cut. rejoin these two yellow wires and you should be good to go
Mar 07, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
Vehicle Parts & Accessories Logo
73 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Ruben Diaz
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
