Question about Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737
HLS & Service Heater LEDs
Tested heater for this season (worked well end of last season). Heater ignites and runs from anywhere from 2 minutes to 15 minutes (depending on flow rate or if the universe is happy or not). Burner shuts off. Front panel shows "Service Heater" while rear of panel shows HLS error. After a couple of minutes, heater re-fires and burns for a while and same error LEDs. My flow rate is within the parameters for the heater. I am wondering if my HLS switch has gone bad. The switch is about $40 on Amazon, but not sure how to install (I'm OK with electronics, not so much with plumbing) or if this is the issue. Any advise more than welcome before I call a service tech.
  • 3 Answers
Hello.... HLS usually means hi limits.... check the connectors at the high limit switches, to make sure they're not rusting off. If they're good, and the heater fires, but turns off after a minute or two, the problem lies usually with the temperature regulator.... it's the round cover with the 4 slits in it between the inlet and outlet. It comes out counter clockwise. It holds a spring with what would be a car thermostat attached to the end of the spring. That thermostat can be malfunctioning, and it will allow the water to get too hot coming out of the heater, which trips the hi limit. A quick fix is to remove the spring with the temperature regulator, and put the cap back in place. You definitely want to get another one to replace it, because the efficiency rating of the heater will go down considerably.... but it will do the job in the meantime with no danger. (Its like running a car with the thermostat removed, it can be done, but the engine runs too cool). They cost about 50 bucks on amazon.
Posted on Jun 21, 2015
  • 9 Answers
SOURCE: Have a Triton Millivolt pool heater pilot is lit and nothing!!
Low out put voltage from the pilot generator and/or an open circuit in the control circuit...the most common is a bad pressure switch (dirty filters can hamper pressure switch operation).
Posted on Jun 28, 2009
  • 61 Answers
SOURCE: Pool heater will not heat
Im no pro, but I know there is an air sensor behind the main board. If the fan is running you probably have a problem with that sensor. If your lucky the air hose could have just popped off.
Posted on Apr 04, 2009
  • 139 Answers
SOURCE: pool heater wont fire up
check pressure switch for continuity with pump on
Posted on Jun 20, 2009
  • 246 Answers
SOURCE: E02 error and heater will not start. Service
high limit is open this is due several factors like slow water .pump on low speed or dirty filter, also hard water, or assembly valve not working properly so make sure the filter is clean check the water chemistry an last check the valve assembly. make sure plumbing is correct water in and out from the heater
Posted on Sep 19, 2009
SOURCE: My minimax NT 400 heater will not ignite.
if none of the above don't work, put a brick on top of the vent, covering only about 1" of the vent, then try firing it up. if it works, then you aren't getting enough oxygen at the ignitor.
Posted on Aug 08, 2010
Hello, I have a Lochinvar ern 252, it was working great last season and was winterized properly... I just open the pool and now it is reading lockout ignition failure.... I can smell gas when it goes into...
two things, is it a spark igniter or hot surface?
if spark igniter is working then the pilot tube or fuel path to the igniter is plugged, a lot of times small spiders or insects will winter over in these tubes, build a small web or cocoon that restricts gas flow to the igniter. OR hot surface igniter not hot enough and will not lite the gas. can be tested with an amp probe or just replaced .
May 25, 2014 | Lochinvar ENERGY RITE 399000 BTU PROPANE...
How can i tell if my toyostove laser72 igniter is working properly after i have removed it from the unit
If the igniter is still out of the heater, it will get hot enough to burn you in just a couple of seconds if you turn the heater on. You can test the igniter with an ohmmeter. If you connect the ohmmeter to the 2 ends of the igniter you should get 10 - 17 ohms if it is good. With the igniter installed in the heater you can put a clamp on ammeter around just 1 of the leads for the igniter and should get between 2 - 5 amps if it is working. You can also feel the cap over the end of the igniter. Turn the heater on and the cap should start to get warm in 30 - 60 seconds but may take longer. Also, if the igniter is not working you will not see any flame after the 3 minute warm up the heater goes through. Of course this could also be caused by a lack of fuel. The quickest way is either the ohmmeter or ammeter and takes any guess work out it.
Dec 26, 2010 | Rinnai Toyostove Direct Vent Heater:...
Last season raypak 2100 heater would light but there was a huge whoosh sound like gas was trapped then finally ignited...this season would not fire...i have heard blocked tubes??? If so how do I...
Thank you for posting your question here on Fixya.com.
Along the manifold there will be several gas ports feeding gas into the burner tray tubes. The tubes are the narrow steel tubes that extend under the heater from the gas line. We use a piece of #12 solid wire and run it in and out of the tubes from under the manifold. Spiders like nesting in the tubes and their silk blocks the gas flow. Once the gas migrates over from further away from the pilot you get the 'whoosh' of ignition. As you clean the tubes and recheck the heater be sure you pay attention to the flame color. Anywhere you see orange flames above a tube you need to shut down and then clean the tube. Orange flame means poor combustion and needs to be fixed to prevent sooting.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 10, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Sta-Rite Max-e-Therm pool heater -- cycling and HLS
make sure that you have adequate water flow going through the heater and that your water chemistry is balanced.
Jan 09, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Lightning Strike - Master Temp 250
I have dealt with similarly damaged boards, I can testify that while they can be repaired, the cost of labor is the most significant factor and some parts may be tough to get. I would have never undertaken it but the company which manufactured the control board (this was a sophisticated electric security gate) couldn't ship us the board in the time we could afford to wait so I repaired it. Once. The second time lightning hit it, I replaced the board and ordered the installation of a 'whole house' surge arrester.
Aug 29, 2009 | Pentair Mastertemp Pool & Spa Heater Dual...
Mr heater 75,000 btu kerosene heater
HLS should stand for high limit switch(control) this model does show one in the parts diagram.
Feb 27, 2008 | Mr. Heater MH75KT
Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737 Logo
264 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
