Question about Boating
Yamaha outboard motor
Hard to start when cold but starts good when warn
  • 45 Answers
Try premium gas. Every small engine runs better on premium, especially 2 cycle engines.
Posted on Jun 15, 2013
Fame_Guru
  • 483 Answers
SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
Posted on Mar 20, 2009
mcgyver468
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
  • 23 Answers
SOURCE: I have a 85hp Yamaha outboard motor. It starts
sounds like the ground wire in the control box where your key switch is located is broken are disconnected. check the wiring harness plugs if it is unpluged are not pluged tight it will not shut off
Posted on Jun 19, 2009
finish line
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
  • 86 Answers
SOURCE: Evinrude outboard hard to start
If it is flooding then you need to remove the carbs and check your float level and see if your needle and seat are worn out. If you hold your carb upside down with the bowl off then your float should be level straight accross. If it is not straight accross then you can bend the tang by the needle until it is level.
Posted on Aug 09, 2009
Hi, can you tell me the year model of my Yamaha 40hp outboard? Serial number 452214.
Search Results
Yamaha Outboard Serial Number Location and Model Identification ...
https://www.perfprotech.com/.../yamaha-outboards/yamaha-outboard-serial-number-l... The Yamaha Outboard Motor MODEL, PRE-FIX and SERIAL NUMBER are stamped on a plate attached to the transom clamp bracket. When ordering parts and/or accessories from our Yamaha OEM Online Parts Catalog it's important to properly identify the exact model you are dealing with.
Yamaha Year Models - Hunts Marine
https://www.huntsmarine.com.au/pages/yamaha-year-models This Yamaha outboard year model chart will only work for Asia Pacific distributed engines. If you have a Yamaha engine that has been bought in from America or E. ... For Asia Pacific engines your year model code is found on the bottom right hand corner of your serial number decal. It will be a single letter as per the ...
Decoding Yamaha Outboard Motor Model Number and Manufacture ...
www.murrayyachtsales.com/decoding-yamaha-outboard-motor-model-number-and-... Dec 30, 2015 - Decoding Yamaha Outboard Motor Model Number and Manufacture Date (MFG Date)
Yamaha Outboard Serial Number Lookup
uvgb.you4k.top/ By Darnell Zacharias. DOWNLOAD Yamaha 60HP (60 HP) Repair Manual 1984-2009 Outboards 8.8. By Michael Hornby. HOT. How To Decode A Suzuki Outboard Serial Number 8.4. By Ralap James. Mako 261 Center Console Boat For Sale at Unreserved Auction (Inv.3368) 7.1. By Aldrich Child. yamaha 40hp 2 stroke ...
Outboard Spares YAMAHA Model Year IDENTIFICATION CODES ' eBay
www.ebay.com/gds/Outboard-Spares-YAMAHA-Model-Year...CODES-/.../g.html Outboard Spares Yamaha Outboard Model Year Identification Details needed for ordering outboard spares parts On the Serial Number Plate on most Yamaha Outboards it will be in this format 6E9-L-675634 The...
Jan 15, 2018 | Yamaha Boating
Hard starting on Yamaha 130 2 stroke. Always starts easily with ether. Choke works well.
This can have some reasons:
1 clogged carburettors. Too less fuel means a hard start.
2 Worn spark plugs
3 Loss of compression... On a 2-stroke, measuring compression is not an exact science. Have throttle wide open. No spark plugs, check compression on all cylinders. They should be all within 1bar from eachother...
Aug 02, 2017 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
Yamaha f50 outboard motor
check fuel pump diaphrams ! primer bulb not sticking !
Jun 19, 2013 | Boating
Outboard engine hard to start.
Press the key inwards to activate the Choke. Also, you only pump the bulb when the tank runs dry. Pumping after a successful run, shutdown, pump and restart can flood the engine.
If that doesn't work, claim under the warranty.
specs
Yamaha F20LEHA Outboard Motor Portable
manual, which oddly, doesn't mention a choke feature.
http://www.yamaha-motor.com/assets/service/manuals/1/LIT-18626-07-17_1378.pdf
Apr 19, 2017 | Boating
Starter motor on 130hp Johnson outboard won't
does it turn or can you hear a click as you try ? if its not turning check the starter brushes and if it clicks then replace solinoide !
Apr 04, 2012 | Yamaha Boating
We have a 1967 2 strok mercury 65 outboard motor. wont start cold
Wow.It sounds like some people I know.Late starters.Don,t get out of bed 'till 10 am.With all you have written, a check on the operation of the choke (cold start) would be worth looking at.As you crank the motor,squeeze the fuel bulb at the same time and see if that also may help.Hope this helps
Aug 29, 2009 | Sport & Outdoor - Others
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
Apr 27, 2009 | Boating
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
