Question about Dishwashers
KITCHENAID DISHWASHER MODEL NUMBER KUDSO3STSS2
TOP ARM NOT SPINNING
  • 7 Answers
SOURCE: Top Arm not spinning on Whirlpool DU1145
It looks like there is not enough water pressure to spin the spray arms. Loss of pressure may be due to various things, like damaged seal, cracked tubes, clogged filters, screens etc.
I suggest you take a look at the technician repair sheet that should be stored inside the front panel at the bottom of the door. Remove that panel under the door with screw driver. Inside, attached to the panel, you should find a troubleshooting guide and solution for technician. But it is easy to follow. Look at the section under "poor wash" and follow its recommendation. I had exact same problem - not enough water pressure. In my case, the chopper screen was clogged and the chopper assemply was broken. I followed the repair instruction above to remove the chopper assembly, cleaned the chopper screen and the washer now is as good as new. I will need to replace the chopper when the part arrives.
Good Luck
/Dara
Posted on Nov 27, 2007
SOURCE: GE triton dishwasher middle spin arm not spinning
I had the same problem and found two things which were causing it
-The O-ring was missing off of the tube connection on the back of the dryer that inserts into the sprayer tube. I found a size 11 O-Ring at Home Depot and it worked
-The openings on the underside of the spray arm are what propels the sprayer to spin. I found small pieces of plastic debris in the openings and cleaned them out.
Now the middle arm spins like it should.
Posted on Dec 23, 2008
here2helpBSH
  • 27 Answers
SOURCE: top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Posted on Mar 19, 2009
SOURCE: Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Posted on Apr 21, 2009
SOURCE: top spinner arm of dishwasher keeps falling off
did you solve this. we have the same problem. the piece that the arm is connected to is slightly broken. I don't want to pay for a service call. let me know what you did.
Posted on Sep 10, 2009
Dishes in top not clean- arm in top does not spin
Hello bue.... The top arm spins due to water pressure. pull your top drawer out and inspect the rubber tube that feeds water to the top arm. Usually they have a split in them so the water does not get to the arm to spin it. The fix is to replace that rubber tube. You will need the model number of your machine to order the correct part. I usually get my dishwasher parts from searspartsdirect.com
Joe
Thanks for choosing Fixya!
Jan 30, 2011 | KitchenAid Dishwashers
The top washer is not spinning
Look at the top spray arm and see if it moves freely. Inspect the middle part of the spray arm. Sometimes a tall dishes can prevent the arm from moving. Put the spray arm at 12 o'clock position and have a cup right side up in the dishwasher. Run a cycle. During the cycle the cup should be filled to the top with in 20sec and the spray arm should have moved from its position. If not then change out the spray arm and Delivery tube.
Thanks, Please rate your experience
Dec 11, 2010 | KitchenAid Dishwashers
We have an older KitchenAid dishwasher (Model e) that cleans dishes on the lower rack just fine but not the ones on top. Anyone have any ideas why or fixes?
Be sure you are not blocking the spray arm for the top rack. If your dishwasher has a telescoping spray arm in the botton center that retracts when the dishwasher is off, be careful about covering it with the dishes
Sep 17, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
My top shelve sprayer arm does not spin
its just clipped over the cap remove and clean also check the seal is not damages on the pipe that goes into case.
Jun 18, 2017 | KitchenAid 24 in. KUDI02IRBS Stainless...
TOP SPIN ARM NOT SPINNING TO CLEAN TOP RACK OF MY KITCHEN AID DISHWASHER. IT IS ONLY 1 1/2 YEARS OLD AND MY TOP TACK IS SUDDENLY NOT CLEANING
Hi.
First ensure that the arm is not getting stuck, and check that the orifices are free.
When the top arm is not spinning you may need to replace pump and motor assembly. First it is good looking for blockage in pump hose.
If the appliance is less than two year old, then it may be covered by limited warranty. Call Kitchenaid at the number listed in the owners manual to verify your warranty status.
Regards.
Nov 20, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
KitchenAid dishwasher Lower wash arm
if its a newer model the sprayer sits on top of a plastic screw that just needs to be tightned
Feb 04, 2009 | KitchenAid Dishwashers
Wash Arms not spinning --Dishes not clean
Without the model number of your Maytag number, I can not determine if when you order a wash pump motor you also get the impeller.
Sounds like you are on the right path to getting your dishwasher to wash dishes again.
Oh, while you have the dishwasher open, check that the heating element has not failed using a Multimeter.
Good Luck!
Feb 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Upper rack dishes not cleaning well
Yes, run an empty load with 1/4 cup vinegar. It sounds like there is mineral build up in the arm. Try to take the arm apart that supplies water to the top rack of the dishwasher. You can soak this in vinegar water once removed.
Jan 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
Owen Barnes
