Question about HP Pavilion dv7-1130us laptop
Why is my Hp Dv7 Laptop not booting up?
I have been using my laptop successfully for the past month and when i tried to turn it on the fans spin and sounds like its booting but screen stays black and wireless and mute light stay on. When i press any key on the keyboard the laptop beeps for a while. So frustrating. Any ideas?
  • HP Master
  • 32,281 Answers
Computer does not boot up
The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on May 06, 2013
3 Suggested Answers
bhagyavichar
  • 414 Answers
SOURCE: laptop turns on but screen stays black
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/addon/daughter cards..
..plz do check the following as in order:..
the Hardware part:..
1)a) in power-on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..[not applicable in case of laptop]..
b) in case of laptop try to get output from external display unit/monitor using vga port..if there's proper display in there..the problem is probably with either the 'lcd' or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic',or pwm switching regulator circuit..look for defective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
for any further assistance u may plz leave comment and or testimonials at any point of time, so that i/we can help or u think it to b helpful..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 23, 2009
  • 94 Answers
SOURCE: My HP Pavillion dv6000 laptop now the Mute is
You have two options (1) Troubleshoot the PC (2) restore factory settings
Posted on Dec 06, 2009
Testimonial: "Thanks - I had been troubleshooting to no avail. I went to HP and downloaded the BIOS which was not the right one. HP emailed me the right BIOS. "
Hp dv7-4165dx caps lock blinking, not powering up
I had the same problem with my HP DV7-4165DX. Here is the solution, although it may sound crazy.
1. Lift open the screen.
2. Take a towel and wrap it around the base of the laptop so no air can escape from the fan.
3. Turn on the laptop and let it get hot for 15-30 minutes.
4. Turn off the laptop.
5. Remove towel and power it back on. The laptop should boot up and go into Windows. This is a temporary fix - once you power it down and let it cool off, it will not turn back on and you will have to repeat the process.
6. While in Windows, you need to update the BIOS to "2013-02-26 , VersionF.29, 4.16M" Here is the link to the application:
http://ftp.hp.com/pub/softpaq/sp61001-61500/sp61028.exe
7. Run the executable file.
8. The BIOS will ask you to shutdown.
9. When you power the computer back on it will run a program to update the BIOS.
Now, I tried this last night. I turned the computer off before I went to bed and it was cold in the morning. I hit the power button and it started right up. I shut it down and ten minutes later tried it again - it started right up. Hopefully you will have the same success I did.
Sep 28, 2013 | HP Computers & Internet
Laptop turns on but fan stop running
Does anything show up on the screen? What lights come on? Any beeps?
Feb 02, 2013 | HP Pavilion dv7-1132nr Notebook PC
The fan in hp pavilion dv7-1245dx does not work
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 07, 2012 | HP Pavilion dv7-1245dx Notebook
Hp dv7 wont turn on
It sounds like your power adapter is not putting out proper voltage...
Try removing the laptop battery and see if the laptop will power on when plugged in with no battery connected. If it will not power on this way, then test with another power adapter. If still no good, then it should go in for service. Please let me know if this helps or not.
Joe
Apr 24, 2012 | HP Pavilion dv7-1137us Notebook
I have a HP Pavilion DV7 and it keeps shutting down at random times.. When I turn the laptop back on, it starts up normally besides the improper shutdown screen. It has only happened twice, but its been...
some times can be like as thermal shutdown.
you can check it when using get so hot the back side of the laptop.and you can see reduce the output
of air flow from the cooling fan.and that air flow is get very hot.
for that problem, need to service the cooling fan.
other vice need to check the battery. its go bad, via in small power drop pc goes off.
Dec 05, 2010 | HP Pavilion dv7-1240us Notebook
My HP DV7 laptop will no power on. The LED next
try pulling the hard drive loose and see if it tries to boot and comes up with no boot device found if it does the hard drive is bad if not the bios is corrupted and will need the bios reflashed.
May 08, 2010 | HP Pavilion dv7-1130us laptop
Laptop hp pavillion dv7 turns off by itself when battery is in and it is plugged in Problem
Update the BIOS and check if doesnt work, try running a recovery on the sys.
If problem still persist than contact manufacturer as the sys has to be repaired
Jan 21, 2010 | HP Pavilion dv7-1132nr Notebook PC
Laptop webcam wont turn off,
If you don't want to use it at all you can disable it in BIOS. Otherwise you can disable it in device manager, or on whatever programs runs it.
Jun 12, 2009 | HP Pavilion dv7-1130us laptop
HP Pavilion dv7-1130us laptop Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
