Question about Titan 440 Impact Airless Paint Sprayer 440i 805-015
Titan sprayer 44i will not start at all
I have power right through to the board, fuse OK etc but there is no LCD screen at all.
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
Why isn't my tv getting power?
Check the AC mains cord. If it is OK; The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 19, 2017 | Proscan Televison & Video
What would make a paint sprayer lose suction while beeing used
Wore out packings You have a little titan
Check to see if you have flat valves or balls flat valves are better but the packing kit is around 60.00 dollars also check the prime knob it also has seals .
The KEY is to always clean the mechine after use and oil the pistion with throught oil and it will last forever if you repack it every 2or 3 hundred gallons or so and use good tips
Mar 01, 2015 | Titan Advantage 100 Airless Paint Sprayer
Titan 640 keeps blowing 15amp fuse
It could be a short in the unit from getting wet, pump may be getting seized by dried paint in pump or your using too small of a extention cord
Aug 29, 2014 | Titan Impact 640 Skid Airless Paint...
Does a titan airless paint sprayer require oil
Yes throught oil to be filled at the top of the pistion read on mechine ware
May 03, 2014 | Titan Paint Sprayer. Advantage 350 Airless...
Blank screen on LCD TV
either the backlight power board or the power board itself isn't powering up the backlight power board
or your backlights are burnt... this is where testing comes in
Dec 30, 2013 | Televison & Video
Titan 640i wont prime
If you still have a problem with a Titan 640i please give us a call. We introduced this sprayer to the UK back in 1985. Lion Industries UK Ltd 01543 251 560
Dec 31, 2012 | Titan 440 Impact Airless Paint Sprayer...
No power
Got no power on my tv need sone advice as change fuse still not working
Sep 07, 2011 | Sansui HDLCD3200 TV
Titan 440 Impact Airless Paint Sprayer 440i 805-015 Logo
62 people viewed this question
Top Titan Air Tools & Compressors Experts
JOHN LAPIER
Steve Pack
Steve Pack
Vernon Taylor
Are you a Titan Air Tool and Compressor Expert? Answer questions, earn points and help others
