Question about Electrical Supplies
Dashboard the lights quit working
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 51 Answers
Hi, why dont you visit a licenced mechanic to help you diagnose the fault? Things like problems in the fuse box or wiring could cause that but a mechanic will give you better explanation after diagnosis. Cheers
Posted on May 06, 2013
Why have all my dashboard lights quit working in my 2000 chevy impala?
Chech your dimmer switch ,make sure it is turned up if not the problem change bulbs that have burnt out. make sure you have rear running lights if not replace fuse all should work then.dash lights and running lights are on same circut.
Sep 17, 2014 | Cars & Trucks
Dash lights quit working
When the dashboard lights in your vehicle malfunction or cease to operate, the resulting effects can range from being a mere annoyance to posing a safety hazard. Locating the problem and finding a remedy is essential. To fix dashboard lights that won't light, follow these suggestions
Evaluate the problem methodically. Begin the process by trying the simplest of solutions first. Most vehicles have a dashboard lights control switch that will dim the dashboard lights, as well as turn them off. Check the control switch, which should be located on the console near the steering column, make sure its in the correct position to have the lights on.
Check the dashboard light fuse. A blown fuse can disable the vehicle's dashboard light. The fuse box may be under the hood, or on the floor, near the brake pedal, or there may be 2 fuse boxes in both places. Refer to the diagram on the fuse box cover to locate the correct fuse. Replace the dashboard light fuse if necessary.
If all of the above don't fix it, then replace your light switch.
Dec 09, 2013 | 2001 Dodge Ram 3500 Truck
Honda civic dashboard lights
can be various problem a) fuse replace b) wires loose or corroded clean it c) ribbon cables insides is faulty or bad contact or faulty replace or clean. d) the dasboard light faulty.e) switch dirty or faulty test with VOM.f) the IC faulty and replace see the diagram attached.0fbac013-4f7f-4338-b2b4-aa0dc2c2a3e6.jpeg
God bless you
Jul 08, 2013 | Cars & Trucks
Gauges on dashboard quit working
I would suggest you remove the dash light dimmer control rheostat (In most cases part of the main headlight switch) and test it for continuity, I think it may be defective, please perform the testing before replacing any parts.
Jun 05, 2012 | 1997 Isuzu Rodeo
1998 Plymouth Grand Voyager.........Dashboard instruments quit working and don't light up. Speedo, tach, fuel gauge, temp gauge, and mileage indicators and lights for same stopped working. ABS...
You have some wiring problems shorting out that is coming from the dash board so if you or anyone you know how to use a multimeter to check the wireing harnesses plus check any connectors that might be just very touching the connector of dashboard which means a bad connection to dashboard.
Jun 04, 2011 | 1998 Plymouth Voyager
Break lights work but not the tail lights, also the dashboard light quit working to
check the fuse, the tail and dask lights are tied together but you may have a short in the system that caused the problem.
Jan 30, 2010 | 1990 Ford F150
Turn signals quit working, both ways, all at once
if turn signals light but do not flash,suspect turn signal flasher,located behind dashboard panel below steering column.if they aren't lighting check fuse,also below dash on drivers side.
Oct 17, 2009 | 1995 Lincoln Town Car
Electrical Supplies Logo
109 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
