Where can i get a copy of adapt iq audio system disk 1
I have disc 2 but need disc 1 for adaptiq audio calibration system.
  • Charlie Davis Jan 23, 2014
    Some Guy- mee too lol
2 Suggested Answers
  • 74 Answers
SOURCE: error code 10 during sound calibration
Please ensure that you have turned on the Accoustimass module, this can cause communication errors when calibrating. Also check that all connections are correctly plugged in as if one is not quite sat right this may give the error, just try unplugging them and plug them back in.
Posted on Dec 09, 2009
Went to shut off my bose system and got a message adaptiq A/B off. how do I get rid of the message
  1. Have you got the original Adapitq DVD disk? Try running the sound calibration routine again.
Apr 24, 2014 | Bose Lifestyle 48 System
Software update failed 100 call bose
Hi Brian,
Did you get this sorted as I'm having the same issues?
Regards,
G
Apr 11, 2013 | Bose Av 38 Media Center Dvd Player...
Went to shut off my bose system and got a message adaptiq A/B off. how do I get rid of the message. Anyone has an answer. Please help.
Aug 26, 2011 | Audio Players & Recorders
Got error 10 and dont know what to do
from REalMacoi your problem seems to be related with the AdaptIQ failing to do an active equalisation. HAve you connected the AdaptIq sense headphones on the AUX (left and right coz it will still fail if only one cable is connected) Also make sure tha the sense headphone cable is in the correct color orientation and none is connected to the black jack just below the red one. Try this procedure and if the system still shows error 10 do the following in sequence...
1. Turn off the media center via the"ALL OFF" button in the tray (no DVD disc inside the tray)
2. Turn off the bass module by the power switch underneath the bass module (certain versions may not apply)
3. Unplug the power adaptor of the media center and remove the power adaptor connection from the wall socket.
4. Unplug the bass module (if this has not yet been done
5. Disconnect all speaker wires (satellite speakers I mean)
6. Disconnet the data cable linking the bass module and the media center
7. Allow 10seconds to pass
After 10seconds then connect the following again in this sequence
1. Connect the media center and the bass module data cable first
2. Connect the satellite speaker cables.
3. Connect the media center adaptor (DO NOT TURN ON YET!)
4. Lastly connect the bass module power cable (DO NOT TURN ON YET!)
Once verything is connected, press power "ON" button o nthe RF remote and the media center should turn on. Only the you should switch the bass module power "ON" so that a fresh handshake is achieved.
This ERROR 10 occurs when either the ADAPTIQ process is interrrupted, the data calbe link between the bass module and the media center is loose or when the power connection is interrupted.
If all still fails, then there is a problem with the DSP board of the bass module and would require servicing.
I do hope I was able to help you
Sep 21, 2010 | Bose Lifestyle 28 System
Error code 10 during sound calibration
May 31, 2009 | Bose Lifestyle 35 Series II System
Code 10
Hi, your problem seems to be related with the AdaptIQ failing to do an active equalisation. HAve you connected the AdaptIq sense headphones on the AUX (left and right coz it will still fail if only one cable is connected) Also make sure tha the sense headphone cable is in the correct color orientation and none is connected to the black jack just below the red one. Try this procedure and if the system still shows error 10 do the following in sequence...
Apr 03, 2009 | Bose Lifestyle 18 System
Sytem recovery disc 1
1) Try to make a copy doing an "IMAGE DISK"
2) If you couldn't:
You can download all your drivers for your desktop computer
without a Restore Disk. (But You will need a copy of OS)
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVRX753&LOC=3
Oct 14, 2008 | Sony VAIO PCV-RX753 PC Desktop
How do i hook up the speakers
connect each dual in series then parallel each sub
Sep 08, 2008 | Boss IQ 3KD.1 Car Audio Amplifier
The Media Center system doesn't work and the AdaptiQ CD (2) is in the Media Center. We can't put out the CD. There's standing on the display Bose lifestyle. Has someone the solution to the problem?
Unplug the media center power at the rear power plug. Leave off for 20 seconds. Remove the AdaptIQ headsets plugged into the AUX input. Power the system back up but leave alone for about 10 minutes. After 10 minutes come back and press the "open/close" button the wait 30 seconds or more for the tray to open. Be patient, the media center is processing a huge amount of data and needs time to respond to your commands. It is important to leave the media center undisturbed for approximately 10 minutes after running AdaptIQ setup. After about ten minutes, power down the power back up. You should be ready to go after that.
Dec 23, 2007 | Bose Lifestyle 38 System
Media center not working
hi
can you please help me.How can I solve this problem.
Dec 22, 2007 | Bose Lifestyle 38 System
52 people viewed this question
 Grubhead
Grubhead
