Question about Husqvarna 960 43 01-11 - YTH26V54 54" 26HP Lawn Tractor 2012 Model
Bushhog double gas tanks can not draw from 2nd tank
    Top Expert:
  • Husqvarna Master
  • 49,967 Answers
Fit a cap to the second tank that allows air into the tank to prevent a vacuum forming as the fuel is drawn off
Posted on May 05, 2013
I need digam for a chainsaw gas line from tank to carbater
Give me your make and model... if you can snap off a pic that would help as well.... do you have a double nipple primer bulb set up? I have a drawing I can send you
Oct 10, 2015 | Garden
A 94 f 350 fuel exchanging between tanks
there is no equalising between tanks and all the return fuel from the injectors is being contained in one tank. Try shifting the fuel return line to the tank that you are not drawing out of so that the fuel then flows into the tank that the pump is drawing from. Check that the tap/ s between tanks is turned on.
Mar 08, 2014 | Cars & Trucks
Blower stops running after approximately 10 minutes
many times gas tank vent gets clogged then engine will run until engine creates a huge vacuum in tank and can't draw gas.
Loosen gas cap to Vent the tank to see if that's the issue
Dec 01, 2013 | Stihl Garden
I changed the primer bulb and now it's not getting
sounds like you hooked the lines up backwards, when you press the primer it is supposed to squirt gas into the tank on the return line cause what it does is draw fuel through the carb and back to the tank....filter line from tank goes to fuel pump side of carb and return line on carb goes to primer bulb then opposite line on bulb to tank...... so when you press bulb it draws fuel through filter in tank through carb and back to tank ! good luck! 2StrokeJim
Jun 17, 2011 | Homelite Garden
Im switching gas from rear tank to front tank or from front to back and it is causing overflow
sounds like the switching valve for the gas to draw out one tank first then the other tank is bad and needs replacing.this can cause gas to be pumped into the other tank causing it to overflow.
Apr 20, 2011 | Ford F-150 Cars & Trucks
Does the valve on the auto switch over lp regulator shut off the gas or switch tank to other side
If your talking RV tank regulator. The lever or dial points at tank it's drawing from, and when that tank is empty, the indicator (if it has one) will turn from green to red, and start drawing from opposite tank. When you move the lever over to point at full tank, indicator should turn green again. Only shut off is at tanks.
Feb 13, 2011 | Heating & Cooling
My reliance natural gas water heater overheats causing scalding water to come out of my faucets. I have had authorized service companies come out three times to replace and retrofit different controls and...
Information below is for tank-type electric or gas heater only.
There is a condition called stacking.
This might apply to your water heater or not.
Having authorized service people to your house 3 times suggests more complicated mix of problems.
Stacking is caused when there are repeated short draws of hot water.
As you know, each time any hot water is drawn out of faucet, cold water immediately enters bottom of tank through the dip tube. The dip tube is connected to cold water inlet and runs to bottom of tank.
So all cold water enters bottom of tank close to the gas water heater thermostat.
See illustration of dip tube, that also shows copper thermostat sticking into tank that is connected to gas valve.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
Let's say your water heater if fully heated and burner is off.
A short draw of hot water causes cold water to enter tank.
Another short draw. And then another short draw, each draw happens close to same time as other draws.
Water at top of tank is plenty hot, but bursts of cold water get near thermostat and cause thermostat to turn on burner.
Burner heats water and more hot water rises to top of tank. Water at top of tank becomes overheated each time stacking occurs.
Again, a stacking situation may not be the cause of your problem.
However, remember if single-handled faucet is opened straight upward, then that draws both hot and cold water. And cold water immediately enters tank.
Only when the single-handled faucet is lifted with the handle all the way to the right, does it draw only cold water. Even so, some single-handled faucets have bleed-over between hot and cold sides, so hot water is drawn anyway.
Another possibility is that the dip tube ends at or near thermostat, instead of going all the way to bottom of tank. The dip tube should go straight down from cold water inlet, but dip tubes are made of plastic, and some self-cleaning tanks have a curved dip tube or dip tube with perforations that create currents designed to stir sediments off bottom of tank (although this is not proven to be effective deterrent to sediment formation).
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | RELIANCE ELECTRIC WATER HEATER
My dayton 375000 torpedo keep freezing the propane tank. What can I do to stop it?
You are drawing gas too fast for the tank to vaporize. You either need to hook the heater to a larger tank, warm your existing tank or tie two tanks together and keep one tank empty.
Feb 07, 2010 | Dayton Heating & Cooling
Original gas tank replaced because of holes. New
It sounds like the new gas tanks do not have a breather fitted to them.
As you remove gas from the tank it needs to be replaced with air if not it creates a vacuum and natures way of filling a vacuum it to compress the space it is in
Fill a plastic soda bottle with fairly hot water , give it a minute then pour the water out and quickly screw the top on , watch the effect , that is your gas tank
There is either a metal or rubber tube or even a vent in the filler cap to allow air in
You did something to alter that ?
Jun 30, 2009 | 1998 Chevrolet K2500
¿¿¿Engine computer Dead???
hi as for the fuel tank problem ? this is a vacumm problem created by the fuel pump workinh hard to draw fuel thus creating a vacuum inside tank suggest you ckeck the ventilation pipe from tank (under n/s/r wing along side filler pipe to see it is not kinked or blocked preventing tank to breath as pump draws fuel ?? as for excess fuel consumption? have you checked the air filter? remove it and check underneath ! this will give smoke you mention and you will have to press throttle more to overcome restriction air flow so more gas is more fuel used and little air to engine ? if you say engine stalls this is probably a result of tank vacuum and more fuel than air ?? hope this helps you sort it?
Oct 01, 2008 | 2000 Hyundai Accent
Husqvarna 960 43 01-11 - YTH26V54 54" 26HP Lawn Tractor 2012 Model Logo
47 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
