Wwont agitate Washer fills with water, timer slowly moves but doesnt agitate. It spins, drains and advances through the cycles. During agitate mode the motor DOES NOT make any noise or hum so it seems like the timer isnt powering the motor for agitating. This makes me believe that the transmision and belts are good. Any help is apprieciated. Maytage Model# LAT9804AAE Serial#13514212 QH
    Top Expert:
  • Washing Mach... Master
  • 51,218 Answers
In the circuit there is a module that works the agitation of the machine . It is an electronic device that moves the motor back and forth producing the agitation and is not connected to any other operation. Have it checked by a washing machine mechanic for failure.
Posted on May 05, 2013
Washer wont agitate
sorry only the local washing machine engineer is the only hope eric
Jan 01, 2018 | Washing Machines
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Jan 21, 2010 | Kenmore Washing Machines
    The washing machinge is not completing the complete cycle
    Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
    May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
    Frigidaire washing machine gets stuck on cycles
    Apr 01, 2009 | Frigidaire Washing Machines
    Whirlpool Washer will not progress to the rince cycle.
    that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
    I quote from : The cycle doesn't advance
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Washer won't advance from cycle to cycle
    * It's the timer, if your washing machine fills with water and begins agitating, but the timer never
    the timer.
    * It may be a cold-water supply problem, if the washing machine fills with water, agitates,
    Nov 16, 2008 | Danby DDW1805W Designer Series...
    Washing Machines Logo
    60 people viewed this question
    Top Washing Machines Experts
