Question about Samsung SP-R4232 42 in. Plasma HDTV
Inverter My SP R-4232 plasma tv would not switch on. The blue light blinks 4 times then stays dark but I can hear something like a relay clicking in and out.I replaced the mainboard and the TV was fine for 3 days after which the original problem returned. Please help!
    Top Expert:
  • Samsung Master
  • 74,634 Answers
The blinking blue light are fault indications. From the number of blinks that occurs at one time switch ON, you can get an idea about the faulty circuit section inside it. Even though you've got this idea, service to Plasma TVs are somewhat difficult one for a user, who do not have any knowledge in electronics. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong. Blinking codes to Samsung Plasma Displays are described in detail by one among the posts. Pull up older posts.
Posted on May 06, 2013
lukster
  • 217 Answers
SOURCE: blackout problems
It could be the LVDS cable that is connected between the logic main board and the main board, sometimes this cable is too short and comes loose from one of the boards, it could also be a sign that the logic main is going out or the panel itself is shorting out
Posted on Feb 17, 2007
  • 12 Answers
SOURCE: TV switch off randomly
It is a Rely in the Power Supply. Need to have it changed out. Cheap part.
Posted on Feb 11, 2008
SOURCE: dark vertical shadows
No,you can't. This is very common. I bought a new tv and i noticed right away that it had the problem you are mentioning. I took it back for an exchange and the next tv did not have this problem...until a year later. Now,of course it does have this problem,but it is out of warranty.
I think they make televisions very poorly today.
Posted on Apr 28, 2008
  • 6 Answers
SOURCE: my 40"samsung LCD turns on/off 3-4 times before staying on
You need to change the 1000uf caps in the power supply. only if you are handy with a soldering iron. Take back of remove psu. You will see them bulging at the top. Think there is 5 to change :)
Posted on Jun 17, 2009
tvtek
  • 1284 Answers
SOURCE: SSP-R4232 Plasma TV, blue light on, but tv wont turn on.
At this point it appears that your main board is probably bad. You most likely have a 5 volt scource going to the main board but its not powering up the set. The main board is part number BN94-00796A.
You might want to have a technician look at the TV to verify this as the issue before purchasing it. Please take a few moments to rate my answer. Thank you.
Posted on Nov 18, 2009
Testimonial: "I was extremely grateful to have a response in such a short amount of time, as soon as I replace the part that was suggested as bad to me, Ill post."
Samsung PN58c590 plasma tv
Short circuited component/s at its main board. These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating, to many popular brand TVs and other devices.Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Feb 24, 2014 | Samsung PN58C590 TV
Hi,i have an hitatchi p50t501 plasma and i just put in on and everything was fine,then i put it on video 1 to put on direct tv, then i put it back on cable left the room and the tv light keeps blinking...
The Blue Blinking Light Hitachi.
When the light blinks 4 times it means you can possibly have 4 problems with your plasma.
1. X-Sus
2. Y-Sus
3. Power Supply
4. Sdr U or D
A good way to determine if you can fix this problem yourself is if you can build a PC. If you cant this can cost you upwards of 600$ to fix.
First get a flat area and lay a soft blanket down and lay your TV down so the back is up. Then goto your PC and goto Google and type "P50T501 Service Manual .PDF" you can buy it or if you look hard enough you can get it for free. Next in the service manual it will have a diagram of the Circuit Boards and their locations. Take the back off your Plasma and check the 4 boards. Look for burn marks, cracks, smoke mark. Take your time and look closely. When you find the broken boards unplug it and take the part number and find the replacement online. Plug it in and you should be good to go.
When i had 4 blinking lights i had to change my SDR U and D boards. They cost 100's a piece for Refurbished boards. Keep in mind im a contractor not a techno geek, and i was able to diagnose and fix my problem rather easy.
Aug 15, 2009 | Hitachi P50T501 50 in. Plasma HDTV
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Samsung sp-r4232 power button blinks 4 times but tv wont turn on
I have this TV. My father in law tried to turn it on one day and it started making a clicking sound and never came on. So he went out and bought a new tv and gave it to me. It came on when I brought it home and worked for a couple weeks. Then just the other day it stopped working. When you hit the power button the light around it blinks four times and then you here a clicking sound. TV does not come on. Took the back panel off and I don't see any damaged caps or fuses. b435b80e-6d09-419f-a021-9b8a430e0a74.jpg
May 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Dec 29, 2007 | Samsung HP-R4262 42 in. Plasma Television
No picture
btw for anyone experiencing these problems with the infamous "is-lcdtv32" byd:sign is the same manufacuterer as insignia, its the same company with a different sticker. i know this isnt a solution, but parts for all discontinued insignia';s can be purchased thru byd:sigh(by design). hope this helps .
Oct 06, 2007 | byD sign d:4232 42 in. HD-Ready Plasma...
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Sep 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Intermitten remote sensor issue
Sounds like to me the comcast HDTV box is the issue if you are using that to change channels. Let me know.
Sep 16, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung SP-R4232 42 in. Plasma HDTV Logo
111 people viewed this question
Henry  Thomas
Henry Thomas
