Question about Dryers
Fridge air gas dryer
Fridge-air gas dryer has no gas flow through regulator. How do I clean it
  • 26 Answers
You need to replace it. Once a regulator stops working, you can fix it.
Posted on May 06, 2013
aborcass
  • 2651 Answers
SOURCE: Amana ALG443RAW Gas Dryer will not heat up.
you can remove the lower acess panel (2) 5/16 screws along bottom. youll get a good view of workings there. turn on dryer (make sure a heat cycle is selected. you should see the ignitor light with in a few secs. if not unplug the ignitor(small white connector maybe 6inhes back from ignitor itself) and with a meter ck for 110v in that connection when unit is turned on, if you do have 110volts , you hav abad ignitor. ifyou dont get 110 volts you need to check the thermostat(s) located on top of the heater box right above the ignitor, if no continuity you need a new thermo.
Posted on Mar 12, 2008
SOURCE: gas dryer runs for 3 mins and then no more hot air
mjm_III1,I have the same problem and did what you did (replacing the gas valve solenoid coil). My problem is history.
Cheers!
Posted on Aug 27, 2008
  • 175 Answers
SOURCE: Dryer won't Heat up - Kenmore Elite HE4 Gas Dryer
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Posted on Jun 09, 2009
jimappliance
  • 42 Answers
SOURCE: ge profile harmony gas dryer- no air flow in or out no heat
Replace the blower motor. Check condition of blower wheel and replace if found defective
Posted on Feb 13, 2010
  • 37 Answers
SOURCE: Gas Dryer won't stay hot
There is a thermoelectric eye that says it is OK to keep the gas burner on. If this sensor is defective or blocked from "seeing" the gas flame is properly lit, it will turn off the gas flow (safety) override solenoid. With the unit unplugged make sure that the optical path on the upper right (1:30 CW position) flame tube inside sensor window is clean. The rattle you hear is probably the safety gas shut-off solenoid engaging. If you need more help, please ask -- SWT
Posted on Aug 04, 2010
I have a gas dryer that when cycle begins it heats but after a while it stops heating and it takes too long for clothes to dry...Why is this happening?
I would check the the vent hose first. It might be clogged with lint or stopped up some other way or even crimped where the air won't flow. Turn on the dryer and go outside and be sure there is a good flow of air coming out of the vent. If there's not much air flow dis connect the hose and clean it out
Dec 13, 2014 | Whirlpool WGD4800XQ Whirpool 29" Gas Dryer...
How do I clean the lint from my Model #110.72952100 gas dryer
Hello Bob;
My name is Peter. I am a retired field service appliance technician.
I assume you are not referring to the lint filter on the top of your dryer.
Behind your dryer is a elongated hot air distribution manifold. Looking from the back of your dryer it is on the left. The manifold is fixed to the back of the dryer with screws. Unscrew the screws and remove the cover.
In the bottom of this manifold is where air flow blockage occurs. Clean this inlet out.
At this location you will not be exposed to any electrical or moving parts.
Cleaning this outlet will enhance the dryer air flow and dryer performance.
Nov 02, 2014 | Kenmore 73952 Gas Dryer
Dryer runs but no heat this is a gas dryer
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Jan 25, 2011 | Whirlpool LGR3624JQ Gas Dryer
To day I was using the oven it was working ok but suddenly it shut off and I was trying to turn on the oven it was shutting off again and again
First of all check your gas connection, the flow to the range. If Ok then there is dirt accumulation to choke the AIR FLOW into the burner. Use a tooth brush with some good degreasing spray to remove the burner, clean off weell so that the seating of the burner to the bottom stem is fitting. if not repeat , use a soft water paper if required to achieve this -- due to constant wearing.
If the gas flow is not establised now then you must clean the regulator jet. Remvoe the regulator, use a good air jet to spray out dirt or crusting and makea clean passage.
Once the gas flow is establised with the burner in place with the work done earlier, you must get a good flame.
Sep 17, 2010 | Magic Chef 31000 Gas Kitchen Range
Have had a repair man out 3 times. Replaced igniter and gas regulator. Dryer will heat for a few minutes then stop heating. When I try to turn it back on, it will not turn on at all for about 10 minutes.
Are you saying the dryer will not start again after a few minutes? That is a motor [problem. Replace motor.
Are you saying dryer starts after a few minutes but will not heat? That is an air flow problem or a gas valve coil problem. Thoroughly clean EVERY single air passage in the dryer and vent tube. If that does not cure it, then replace gas valve coils if the igniter comes on and off.
Jul 02, 2010 | GE DCVH515GF Gas Dryer
Have a Maytag Atlantis Gas Dryer & the flame ignites when you begin a cycle but goes out shortly after. I have replaced the Hi-Limit Thermostat but the same thing happens. Any idea's?
IT COULD BE THE FLAME EYE BLACK BOX OR THE TO COILS ON THE REGULATOR 2 ROUND BLACK THINGS I WOULD JUST REPLACE ALL PARTS UNLESS YOU ARE GOOD WITH OHM MEATER
Jan 31, 2010 | Dryers
Gas dryer quit heating
Good Luck!!
Nov 01, 2009 | Whirlpool GGQ8831L Gas Dryer
I have whirlpool dryer that the heat seems to kick on and off it is gas dryer
If heats for a few minutes then cuts off (heat) , then the 2 coils on the burner valve are probably bad . OR check the vent hose to the outside for good air flow . Sometimes , a dryer is pushed too far back , and it kinks the vent hose . If coils are bad , when dryer cools down , then restarting , cool coils will heat again for a few minutes , then stop heating till they cool off again .
Aug 01, 2009 | Dryers
Gas dryer runs for 3 mins and then no more hot air
Cheers!
Jun 28, 2008 | Whirlpool GGQ8831L Gas Dryer
May 03, 2008 | Dryers
Dryers Logo
44 people viewed this question
Top Dryers Experts
