Question about Philips 26MF231D 26 in. LCD Television
Power light on but no picture
I have the green power light on the front of the tv but when I push the on button either on the remote or on the tv nothign happens. The green light blinks indicating that it is getting the signal from the remote. I unplugged the power cord for 1 minute and plugged it in again still nothing. Any help would be appreciated.
  • Anonymous Mar 19, 2014
    connected roku to flat screen tv. Plugged in. It did not work. pushed reset, no good. power light not on
I have the schematics I paid to get them but in there it states a trouble shooting the following
3.No picture/LED is green note I will share the schemadic if requested, for free hated to buy but only way I got it
Check
power board 1088,
pin1~5=24V,pin6=
2.6V pin7=6.1V
if No Check power board
Yes
Check if
working voltage
3Q03=3.3V,3Q27
=3.3V
No
Check circuit around
each regulator and
eliminate short and
open situation
Yes
Check if clock
source 1H00
if no Replace 1H00
Yes
Check if
7J00 RGB,
clk,H/V and DE signal
output 128 bits
TTL
No
Try to replace
flash Rom
EEPROM
Check
resistors-network
No Replace bad resistorsnetwork
Yes
Yes
Replace LVDS cable
Yes
Replace LCD panel
Posted on Nov 02, 2008
  • German Isales
    German Isales Mar 11, 2011
    Hi victornew37
    I need the schematic for Magnavox 26MF231D-37 service manual. Please i have the set and i have the on/off power problem replaced the power supply and still the same so im thinking is the video board but i need to find what part on the board causes that to happen as a safety feature. Please email me a copy ([email protected]) Much appreciated thanks
  • Jeremy Themm Aug 07, 2013
    Please send me the schematic. I am having the same issue. [email protected]
I've got the same problem. No sound, no picture, just a green light. The light comes on when its plugged back in. No buttons work. Occasionally the light flashes off.
Posted on May 30, 2008
    Genius:
  • Philips Master
  • 1,691 Answers
This is most likely a power supply failure. It can be due to some other components in other areas of the set also being defective.
Jerry G.
Posted on Apr 12, 2008
    Scholar:
  • 186 Answers
Any sound when the tv is on with a black picture?
  • 4 Answers
What is nothing happens? try putting in some signals and give us a full history.
Posted on Aug 10, 2007
SOURCE:
I have a sony KDL 46xBR2 when I turn on powers up green light stays on but a dark gray screen no picture or sound
The green light merely indicates that power is getting to your TV. The symptoms you describe point to internal power supply failure
Mar 17, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
My tv has a red button on the front that flashes and no picture comes on when we try to turn it on with the remote
The Toshiba sets were well known for bad capacitors in the power supply. I recommend getting it assessed.
Mar 19, 2012 | Toshiba 32AX60 32" TV
TV does not turn on.
green light comes on when i push power button but no picture
May 31, 2010 | Panasonic TH-50PX75U Plasma HDTV
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Philips 26MF231D 26 in. LCD Television Logo
1,002 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
