Question about Sharp MX-3501N All-In-One Printer
F2-71(cyan) being displayed that i cannot remove. have used toner chips from other cartridges that work and even swapped the faulty toner chip that throws up the error on to another cartridge and it works ok. The only chip that works is the spent one that is constantly showing toner empty. It seems that any chip showing a decent quantity of toner causes the F2-71 to come up. Just downloaded most recent firmware to try, but any suggestions would be most grateful! thanks in advance
  • san3409jl Jan 08, 2014
    Hi Jamie , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Are you trying chips from the color type?
Bizhub c650 cyan toner chip error
Take the cyan image unit out, clean the contacts on the chip remove any oil from your and interfering with the electrical contacts. Is the toner cartridge Third party or OEM??? if third party get a OEM. Sure it does not say Cyan Image Unit not Toner Cartridge?
Aug 30, 2015 | Konica Minolta BizHub C650 Copier
Samsung CLP620 Printer says: Not Compatible Cyan Toner after storm June 5, 2014 at 6:00 am, we had a very heavy storm with lighting for several hours, it rained lightly earlier. We turned printer off at...
It depends of what is wrong. Perhaps the storm has nothing to do with having an empty cartridge. Perhaps lightening, induced a little current in the printer or in the chip on the toner cartridge.
You only can find out, by placing another toner cartridge in its place. And don't wonder if the error still is there. But then you have to call in an service engineer, because something serious can be wrong.
At least i hope you at least remover the cartridge once, to see if all contacts on the chip (and in the printer) are still clean and shiny.
Only clean contacts with a dry cloth or a cotton swab. Vever use anything sharp.
Jun 12, 2014 | Universal Office Ink Tank Cartridge for...
Magicolor 3730DN toner not installed
I had something similar happen with a Magenta cartridge. My only option was to call Minolta. After hours on the phone they finally agreed to replace the faulty cartridge.
I suspect that from time to tame we receive a cartridge with a faulty chip.
Aug 21, 2012 | Konica Minolta magicolor 3730DN Color...
Ricoh CL4000DN. I recharged the magenta toner using the OEM cartridge. I replaced the chip as instructed and all elements snapped together without difficulty. However, now there is a "check toner...
Hi, the chip on those toner bottles stores information about how much toner is left, so once that chip registers an empty toner bottle, it won't work even if you attach it to a new toner bottle. You'll need the chip from a new toner bottle, or one that hasn't registered no toner.
Jan 22, 2011 | Ricoh CL4000DN Laser Printer
Xerox phaser 6180. Printing 3 blue horizontal lines spaced evenly apart on printed page. New toners. Could it be fuser? transfer roller?
Just because they are new toners, doesn't mean they can't be faulty.
Faults that show in just a single colour are almost always related to THAT colour toner cartridge.
TRY THIS
If you still have your old cyan toner, swap the chip from your new toner and put the old toner in the printer, then test.
If the lines are gone, it's the NEW cyan toner cartridge.
Jan 07, 2011 | Office Equipment & Supplies
Have Dell 3115cn printer, installed an Innovera cyan cartridge, and the dell keeps saying restart, will not read the cartridge
Probably a chip problem.
Its worth taking the cartridge out (with the printer switched on), close front door, wait for 'Insert C cartridge' message, switch off printer, put new cartridge in, close door, switch on - may clear the problem.
I've seen this before with these cartridges, there was a bad batch of chips around.
If still have your old cartridge, swap the chips over, and try your new toner with the old chip (and for completeess, your old toner with the new chip. If the message changes, the chip that was on the new cartridge is faulty. If it doesn't there's something wrong with the cartridge.
Either way, if there's a cartridge problem, it needs a word with the supplier.
Dec 01, 2009 | Dell 3110cn Laser Printer
We have a Phaser 7400. It continues to give us
If you've already changed out the toner cartridge and the problem persists, then it could be several other parts that are either defective, dirty or blocked.
You may want to contact a certified Xerox technician and have them look at the Imaging Unit Agitator Bar and the Low Toner Sensors for Cyan/Magenta. There could also be a faulty toner supply motor.
Sep 10, 2009 | Xerox Phaser 7400/DT Laser Printer
CLP 300 toner cartridges invalid toner
the drum has chips encoded,need cartridges with chips.
May 29, 2009 | Samsung CLP 300 Laser Printer
Minolta 2400W - Put cyan / black toner
hey, the problem is that toner cartridge reading chip is dirty.
take out Pc drum and remove all toners, clean toner chips with alcohol. then locate a 3 pin reading chip under the toner rack left side and use pressure air to clean it. reinstall everything. if its not helping, replace the chip, its not expencive
Jun 28, 2008 | Konica Minolta magicolor 2400 Laser...
Toner and Imaging Unit issues
If this IS a CLP-510, first make an information confirmation print.
Press MENU, then press ENTER, and ENTER again.
Look at the counter for the imaging unit, is it a low count confirming that you have indeed replaced it ?
If not you will need to reset the counter.
Check the counters for the toner cartridges, and check the capacity of the cartridge. On a CLP-510 the image counter for the toner is held on the chip on the cartridge (which also identifies the capacity of the cartridge).
There have been some faulty (oiginal Samsung chips), and of course re-manufactured cartridge chips could fail (many re-manufacturers don' test their cartridges before dispatch, they don't have the facility to do so without starting the count on the chip (or 'bowing' the reset fuse on a CLP-500 cartridge). VERY few re-manufacturers can test these cartridges without starting the count.
Sometimes the 'replace xxxxx toner' messages are caused by toner on the three contacts on the side of the cartridge, or their mating contacts inside the printer. Rarely, this can be caused by a faulty circuit board.
Dec 20, 2007 | Samsung CLP-510 Laser Printer
Sharp MX-3501N All-In-One Printer Logo
35 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
