Question about Amana D530M Dehumidifier
Repair dehumidifer running but not pulling water
The dehumidifier is running constantly but no water is being collected
Sounds like you're in a wintery environment. Most people operate a humidifier in those locations because the air is too dry. If that is your situation, I suggest you turn the dehumidifier off until Summer and save electricity. If will pull moisture out of the air in the summer.
Jan 11, 2013 | Haier 45-Pint Dehumidifier
I have a new Dehumidifer, but it is not pulling any moisture from my basement. No water is accumulating in the catch bucket. This is the second Frigidaire that I've had this problem with. The first was...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jan 23, 2011 | Frigidaire FDF50S Dehumidifier
Does not dehumidirfy
heatman101
Oct 11, 2010 | Maytag M7DH65B2A Dehumidifier
Dehumidifer Runs but doesn't collect water
Depends on he conditions of the water. These units are relatively inexpensive and typically do not justify the expense of repair. I'ld donate it to an air conditioning school and buy another one.
Jul 18, 2010 | Whirlpool AD40USR Dehumidifier
Haier dehumidifier will turn on but does not collect water.
hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Apr 14, 2010 | Haier HD656E Dehumidifier
Makes a crackling sound while running
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 02, 2010 | Whirlpool 75-Pint Dehumidifier
Runs, but no dehumidification. 6 months old.
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 30, 2009 | Haier Dehumidifiers
Maytag Dehumidifer still works, but is leaking
Well life span is 3-15 years depends how long and hard you run them. 45 pint is about 1000sqft basment. rule of thumbs bigger better. run less and do a better job. I would start by filling the bucket and place in a dry shower see if you have a crack. cant find a source for the bucket discontinued this might be your problem. http://www.repairclinic.com/SSPartDetail.aspx?s=t-M7DH45B2A-%3d%3di1025984&PartID=1025984 Repair cost are about 40-50 and hour!!!! good luck
Nov 01, 2009 | Maytag M7DH45B2A Dehumidifier
Our humidifer runs but does not collect water.
Againg, if theres no moister in the air it wont remove water. if you feel the location for exmaple a basment feels cool when entering , then mosuet exist. dehumidifer will make any location warm when removing the coolnest in the air. within summer hot months it will collect more water than in the winter months. if it does feel cool and machine dont remove the water. call a repair person.
Oct 04, 2009 | Fedders R6DH45X Dehumidifier
Amana D530M Dehumidifier Logo
Top Amana Dehumidifiers Experts
jasbo
jasbo
Gil Shultz
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
