Question about Maytag Atlantis MDE7400AY Electric Dryer
Mde7400ayw timer knob
I need to replace a broken knob for my Maytag Atlantis MDE7400AY Electric Dryer. What is the part number and how much would I expect to pay and where do I get it?
How do you remove a timer knob on a maytag atlantis electric dryer
Just pull it straight out towards you... I will come very hard...
heatman101
Aug 30, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Mde7400ayw wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Knob is broken off, dryer works but repair tech said needs new timer. How much should that cost?
depending on brand, timers can run anywhere from 80-140 dolllars...price varies from model to model
Mar 10, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag MDE7400AYW taking 2 or 3 cycles to dry
it's probably your sensor assembly. go to www.repairclinic.com/Appliance-Parts?s=t-MDE7400AY-%3d%3d&z=100 . That is the best possible solution and not too expensive. Good luck.
Apr 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
MAYTAG ATLANTIS DRYER TIMER SWITCH
the key is to dismantle the font ofthe knob assy( the small plastic center of knob pulls out) it also acts as a locking ring /clip to hold unto the new timer shaft
Mar 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I pull the knob on dryer Maytag MDE7400AYW and it won't start.
yeathe start switch is bultdirrectly into the timer assembly youll need to replace the timer.
Feb 17, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer mde7400ayw won't run
I believe this last one has it right. the timer may be bad or worse, the board could be bad.
Jan 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
The dryer has power but the start cycle knob only buzzes
IF THIS MODEL USES THE TIMER TO START THE MACHINE BY PULLING OUT ON THE KNOB, I HAVE HAD TO REPLACE QUITE A FEW TIMERS FOR THIS PROBLEM. SOMETIMES BY MOVING THE KNOB UP AND DOWN AND SIDE TO SIDE WHILE PULLING WILL START THE MACHINE. IF SO, REPLACE TIMER.
Nov 20, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Removing Timer Knob on Maytag MDE7400AYW dryer
Can anyone help me? I have a Maytag Atlantis that my parents just gave me and my wife. Unfortunately, they accidently removed the model number sticker in the door area. I need to buy a new timer but no one can find which timer to get without the model number. Via the internet, I think I narrowed it down to either the MDE7400AYQ or the MDE7400AYW....but they both look identical to me. Can anyone tell me what the difference between the two is so I can go get the part?
Mar 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
124 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
