Question about Electrical Supplies
3-speed switch? I don't remember what colors go where.#
    Problem Solver:
  • 11 Answers
Ok start from the black wire that will be ur #1 pink #2 yellow #3 don't worry about burning them it wont happen all 3 wires are switches.
Posted on May 11, 2013
Motherboard connections (to front panel)
remember the colored wire is +, the + and - should be printed very small on the board near the connectors as well as what they are example (HDLED is hard drive LED) or (PWRLED is power LED) or (PWRSW is power switch) these are examples yours may differ slightly
Jan 31, 2013 | Gateway (4000811) Motherboard
Replace speedometer cable 1995 tord taurus
Don't you have a speed sensor on the transaxle?
It should be about the only item sticking up on top,
you can see with wires going to it.
Don't remember any cable
Sep 29, 2012 | 1995 Ford Taurus
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Sep 16, 2011 | Speed Ceiling Fan 3-speed Switch By...
Windshield wipers work but interminent settings don't
most likely cause is the wiper switch has gone bad and unable to 'time' the intermittent speeds.the intermittent speeds work on a resistor type system where low and high speeds add direct voltage.
Jul 30, 2011 | 2000 Toyota Avalon
Is there a fuel reserve switch on the 2000 750 gsxr ?
If I remember I don't think they have a manual switch you can switch to reserve on/off. Like everyone's saying it works off vacuum. The only warning you have is when the idiot light comes on, time to refuel. You should take a note the next time you fill up and figure out what type of mileage you are getting, that way you know when to fill up before you're stranded somewhere you don't want to be.
I believe the idiot light means you're now in reserve.
Jul 05, 2011 | Suzuki T 350 Motorcycles
My gears are P- park R- reverse D- drive (2 Drives one with a box or circle around it) what is each D for
  • D with no circle is just "Drive." this a lower geared drive and best used around time as it provides a better pick up and over all response.
  • OD is "Over Drive" and used for cruising speeds ove 50+ MPH down the highway. Over Drive allows the vehicle to cruise at a more sustained speed with less engine speed and provides better fuel consumption.
  • While you are in Drive going down the highway and your speed reaches 50 MPH just switch gears into Over Drive and you will notice your car "relax" a bit. Remember you don't want to switch from Over Drive to Drive until you get down to around 45MPH or it can be a little rough on your engine and transmission.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 17, 2011 | Buick Regal Cars & Trucks
I have a Vita Mix 3600. I was making a fruit smoothie (banana, blueberry, raspberry), milk, small scoop of protein powder . Speed was on 1. I depressed the lever to reverse. I don't remember if I had...
Yes that is strange, if you let it cool down and try it again with pushing the re-set button and still does not work, try plugging it into a different outlet. Find something in your place that you know outlet is working, lamp, toaster you know. If does work in another out let, then you of course griped that breaker. Then check your breaker box to see what breaker is tripped, and switch it back on, might just of had a power surge based on putting on reverse. If that don't work, I suppose possibly something in motor or switch went out. Please let me know, if it works, I will take a banana smoothie LOL
Jun 09, 2011 | Vitamix Vita-Mix 1364 3-Speed Blender
I don't have a manual. The bike is older, it is a Huffy Blades, Hampton Cruiser. I don't know how to use the gears. Can I find instructions on-line? Thank you
I try to find some, but it is pretty simple. It is probbly a 10-speed...you don't say. On a typical 10-speed, it has a lever for the front sprocket and a lever for the rear. The front ususally has 2 choices and the rear 5 choices.Some just have 10 sprockets on the rear.
The thing to remember is that the bigger the sprocket...the harder it is to peddle. When going uphill you need to use the smaller sprockets.
I did find this general guide for Huffy multi-geared bikes:
http://www.huffybikes.com/pdf/ownersmanuals/fa11eeae-2ed4-4bbb-ae27-1dcf442f58ff.pdf
Thanks for using Fixya.
Jun 04, 2011 | Huffy Cycling
I need the color codes for rear speakers in a 1996 thunderbird lx.
positive wire is red, yellow wire is positive on ignition okey for the speakers remember the solid color like green green w/ black line is negative follow the other coding w the solid colors
Apr 12, 2008 | Pioneer DEH-P6800MP CD Player
Electrical Supplies Logo
117 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
